con này của mình bật nguồn lên bi contactsevie. kể cả là cho bỏ sim ra bật nguồn khởi động máy không sim là bị luôn. đây là log mình chạy bằng mxbox.
Version from phone: 09.98
Version from file: 09.98
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0855CB3
Using device: HTI, FW ver: 00.50, SN: 0000BD69
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012)
Reading RPL backup ...
Reading Phone IDs ...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 02E00114C6214E50CF198EE6CAE7A90382DDE4CF
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage2: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
Algorithm: RAP3Gv30_XSR14_alg.fg [BB5 ALGORITHM] version: 11.34.0 revision: 3.0 size: 0x81324
PRIVATE ID: D8FA6FC967A621706CACCD4DF43C7BEB4064BB9F
E-FUSE: C5D5525E
SEC ROM CRC: DFAAF68F
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
eBB5ProtocolType: OLD
Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Flash Imei: 35270304564893
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA is empty.
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35270304564893_BA CK.rpl"
Processing MCU file: rm561__09.98.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [00140000-0137FFFF]
CMT FLASH,NOR area [01380000-0151FFFF]
erased in 1 min 36.187 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 32.219 s
Processing CNT file: rm561__09.98_008.image_x_ctv_id_v2_93748
[BB5,BB5 ALGORITHM] page size: 128 K size: 14.27 MB
NOR page size in the phone is 128 K.
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF]
CMT FLASH,NOR area [02160000-03FBFFFF]
erased in 3 min 30.407 s
NOR: OK
Converting UCP blocks to 128 K.
NOR: OK
Programming completed in 1 min 7.891 s
Total time for flashing process(boot+erase+write) was 8 min 20.094 s
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35270304564893-1
Battery voltage: 4104 mV, current: 6 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
Camera config: NIMMIIIIRRFF094B2F01, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
E-FUSE: C5D5525E
productData saved.
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA is empty.
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 21 MB
NOR: OK
CMT NOLO block sent
CMT KEYS block sent
CMT DSP0 block sent
NOR: OK
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 34 MB
NOR: OK
NOR: OK
Language Pack:
- not available.
SIMLOCK invalid!
			 2700 cần ae giúp.
 2700 cần ae giúp.
			 Nơi làm việc:   kythuatphone.vn
