Máy bấm nguồn thì nhích lên 2 rồi đứng luôn không thấy dao động gì ...
Cho vào mxbox check thì báo lỗi thế này anh em biết nó bị sao không để em biết hướng sử lý ...
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C086018E
Using device: HTI, FW ver: 00.50, SN: 0000BF5B
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012)
CMT Data :
SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
EM0 ID: 00001051
EM1 ID: 00001060
PUBLIC ID: 1BE001089C6C5140494606F20D3A1AA0433B8D0D
ASIC MODE ID: 00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.2.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.2.0 revision: 3.0 size: 0xD44E9
ERROR: Packet Error(0xAA), code 0xA4000002
			 X3-02 mất nguồn
 X3-02 mất nguồn
