máy cắm xạc vào báo không hổ trợ bộ xạc. log củ nó đây nhờ ace chỉ giúp
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C0855BC7
Using device: HTI, FW ver: 00.50, SN: 000162C3
Connection status: OHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 16300119B44402561927C2C5B5D5774EE5B22643
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
eBB5ProtocolType: OLD
Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Imei: 35434404570537
NPC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35434404570537_NP C.rpl"
Erasing CMT NPC ... OK
Prog.status for Asic CMT ...
Applying BB5 SW Downgrade patch ...
Reading signatures ...OK.
PM backup saved to "C:\mobileEx\3.5\data\backup\35434404570537_201207 23185325_308.1.PM"
ERROR: BB5 SW Downgrade patch failed !
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Updating CMT NPC ...OK
NOR: OK
Phone type: RM-495 (Nokia 5130c-2)
SW version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 35434404570537-7
Product code: 0578115
Battery voltage: 4991 mV, current: 61 mA
Language Pack:
- not available.
Camera config: NIMMIIIIRRFF094B2F01, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354344045705377
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
			 5130 báo không hổ trợ bộ xạc
