    Thành viên mới kidz.alonez's Avatar
    Mặc định Flash sámung E2730
    How To Flash
    SAMSUNG E2730
    Hotfile.com: One click file hosting: PNX49xx_Downloader_v0.3_TSAR3000.com.rar
    1- You need to get E2730 Downloader to flash this phone.
    2- Turn On the phone and connect it to your PC via USB cable, then install drivers.
    3- Now Turn Off the phone and disconnect it from PC & Cable, Take its Battery Out and in again and keep it off.
    4- Take the S20 Pin (Swift) serial cable (SGH-T409 DM+USB) and connect it together with an serial to USB adapter to the PC’s USB port.
    5- Run E2730 Downloader and check this settings :
    - In Serial Port section you have to select Com number that your cable takes and Speed must be 460800.
    - You have to select 3 files each one in its field ( BIN - TFS - CSC ).
    - Mark the option : With Common CSC ( Beside CSC File Selection Field ).
    6- After that press the START button and immediately connect the phone to the Swift cable, While the buttons gets de-activated, you have to power on the phone manually.
    7- If you can see the message, that the phone is ready to DOWNLOAD, you can click on the DOWNLOAD button and the program starts to update the phone.
    8- Wait until the downloader is finish and disconnect the phone.
    9- Take out and in the battery and start the handset.
    10- FULLY reset: *2767*3855# and DONE
    nhocbokute ForumMysamsungVietnam
    please Thank me if statement response real help useful for you.
  1. nhờ ae hướng dẫn Flash sámung M2513 bằng HWK
    By kennyphan in forum Phần mềm Samsung
    Bài viết cuối: 14-03-2012, 15:05
  2. giúp mình flash may sámung i8320
    By DAKLAK-GSM in forum QUALCOMM Models (3G)
    Bài viết cuối: 10-03-2012, 21:03
  3. cần file flash sámung u600 chay n box
    By fericso in forum Phần mềm Samsung
    Bài viết cuối: 09-03-2012, 17:41
  4. hướng dẫn flash sámung x640
    By thuan5000 in forum Các loại máy khác của Samsung
    Bài viết cuối: 01-09-2009, 09:25
  5. sámung P270 FREE FLASH AND FLASHER...
    By bylorci in forum Agere System
    Bài viết cuối: 29-08-2009, 16:18
