2700 mất nguồn...giờ em chạy lại lên nguồn rồi ra logg như vậy là sao cac bác..như vầy có lên nguồn kô ạ
MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0871D8F
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100B1EC
Connection status: UHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Processing MCU file: rm561__09.97.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 260001132CB203560B8F4AA7E6A3781BBE0A61EA
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 1479EE96
Verifying communication to device OK.
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF] erased in 0.844 s
CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.859 s
CMT FLASH,NOR area [00040000-000BFFFF] erased in 3.109 s
CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.906 s
CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 57.297 s
CMT FLASH,NOR area [01380000-0151FFFF] erased in 10.750 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 1 min 16.890 s
Processing PPM file: rm561__09.97.ppm_v
[BB5,BB5 ALGORITHM] size: 6.90 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF] erased in 54.047 s
Programming completed in 28.641 s
Processing CNT file: rm561__09.97.image_v_red
[BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 27.344 s
CMT FLASH,NOR area [02160000-03FBFFFF] erased in 3 min 42.172 s
Programming completed in 55.578 s
Total time for flashing process(boot+erase+write) was 10 min 53.844 s
Open device failed: FFFFFFFF (4) The system cannot open the file
Phone not found, retrying ...
Device connected: nmwcdc\Nokia 2700 classic USB Phonet, PORT_ID: 2D4E83AF
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.97 18-06-10 RM-561 (c) Nokia
Imei plain: 35594204994749-6
Product code: 059D1B1
Battery voltage: 3904 mV, current: 79 mA
Language Pack:
- not available.
Camera config: NIMMIIIIRRFF0A021001, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355942049947496
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
Market items is empty, please select the correct products path !
