Kết quả 1 tới 10 của 16
    Thành viên kỳ cựu newnice's Avatar
    Mar 2012
    hải dương
    Mặc định 2700 mất nguồn.cần ae giúp
    em có con 2700 bị mất nguồn mất nguồn em thay cặp sang chạy lại phần mềm thì nó báo như thế này ,,mong các bác giúp thaks
    Basic Phone Information
    MCU Version: V 09.98 06-09-10 RM-561 (c) Nokia
    IMEI Plain : 358324038103166
    IMEI Spare : A358324038103160
    IMEI SV : 33583240381031655F
    Phone Model: Nokia 2700 classic
    Category : Classic Phone
    Phone Type : RM-561
    SX4 Custom Keys Stand Alone Edition
    *** WARNING: Current Super Dongle Keys are Invalid! ***
    Attempting to write New Super Dongle Keys...
    Phone Type : RM-561
    Super Dongle RPL Stand Alone Edition
    Generating Super Dongle RPL...
    Sending Superdongle RPL...
    OK: Super Dongle RPL Accepted
    Successfully done.
    >>> : SX4 Auth Successfull
    Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-561.pm
    Start Uploading PM...
    Field : 1 Sub : 0 Byte(s): 12 - Ok
    Field : 1 Sub : 1 Byte(s): 70 - Ok
    Field : 1 Sub : 2 Byte(s): 70 - Ok
    Field : 1 Sub : 3 Byte(s): 70 - Ok
    Field : 1 Sub : 4 Byte(s): 70 - Ok
    Field : 1 Sub : 5 Byte(s): 276 - Ok
    Field : 1 Sub : 6 Byte(s): 276 - Ok
    Field : 1 Sub : 7 Byte(s): 276 - Ok
    Field : 1 Sub : 8 Byte(s): 276 - Ok
    Field : 1 Sub : 9 Byte(s): 384 - Ok
    Field : 1 Sub : 10 Byte(s): 384 - Ok
    Field : 1 Sub : 11 Byte(s): 384 - Ok
    Field : 1 Sub : 12 Byte(s): 384 - Ok
    Field : 1 Sub : 13 Byte(s): 384 - Ok
    Field : 1 Sub : 14 Byte(s): 384 - Ok
    Field : 1 Sub : 15 Byte(s): 384 - Ok
    Field : 1 Sub : 16 Byte(s): 384 - Ok
    Field : 1 Sub : 17 Byte(s): 32 - Ok
    Field : 1 Sub : 19 Byte(s): 16 - Ok
    Field : 1 Sub : 20 Byte(s): 32 - Ok
    Field : 309 Sub : 0 Byte(s): 4 - Ok
    Field : 309 Sub : 1 Byte(s): 2 - Ok
    Field : 309 Sub : 2 Byte(s): 12 - Ok
    Field : 309 Sub : 4 Byte(s): 12 - Ok
    Field : 309 Sub : 5 Byte(s): 12 - Ok
    Field : 309 Sub : 7 Byte(s): 12 - Ok
    Field : 309 Sub : 8 Byte(s): 12 - Ok
    Field : 309 Sub : 17 Byte(s): 12 - Ok
    Field : 309 Sub : 22 Byte(s): 12 - Ok
    PM Upload Done!...
    Phone Type : RM-561
    WARNING: Current Simlock Type is SL3 !
    SL1/SL2 Simlock RPL Stand Alone Edition
    Generating Simlock Data RPL...
    ERROR: Wrong Simlock RPL data
    Đã edit tiêu đề dùm
    Đời___Là__Bể___Khổ
    Bạn có Mx-key không bạn check cho dể nhìn tí.
  3. ( Lính Khang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    newnice (15-08-2012)
    chạy vẻ cao nhất nạp rpl pm full ko hết thay cặp kac
  5. ( hachanyen ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Mar 2012
    hải dương
    em chạy ver cao nhất ùi ..write rpl như thế nào vậy ???? các bác em chưa làm bao giơ.... các bác chỉ em với
    Đời___Là__Bể___Khổ
    Thành viên tích cực NT.mobile's Avatar
    bạn flash chưa chuẩn rồi lấy box khác múc lại đi bạn hiền.
    làm cả đời !! hết một giờ
  8. ( NT.mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    Mar 2012
    hải dương
    sao lại the ha? anh trai ...em flash đúng ui mà .... em nghĩ nó bị bay sim loc ui huhu
    Đời___Là__Bể___Khổ
  10. #7
    Mar 2012
    hải dương
    ko có ai giúp em với ak/\????????
    Đời___Là__Bể___Khổ
  11. #8
    V.I.P BinhMinhGSM's Avatar
    Apr 2008
    Vĩnh Long->Đà Nẵng
    tiêu đề:mất sóng mà vào trong là mất nguồn
    Nếu thay cặp sang thì k cần phải flash nhé.đóng chuẩn 1 phát ăn ngay.đóng qua mà không lên nguồn thì cần xem lại đã chuẩn chưa,chứ chưa chuần mà cứ đem flash thì lại banh tùm lùm.
  12. ( BinhMinhGSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  13. #9
    Mar 2012
    hải dương
    nhưng em đóng nó lên ui ....nhưng mà ko có sóng bác ak
    thế mí khổ chứ
    Đời___Là__Bể___Khổ
  14. #10
    Mar 2012
    hải dương
    scan phone nó báo như thế này các bác ak????
    Please update your Box Firmware
    * Follow these Instructions
    1. Disconnect any phones connected to ATF Box
    2. Go to "Product Support Tab"
    3. Go to "Box Tools" Section
    4. Click "Update Firmware" button
    * Make sure you put ATF Software in Windows
    FireWall Exclusion List
    * Make sure you put ATF Software in your
    Virus Scanner Exclusion List
    Box Successfully Initialized
    VBATT Powering Down <<<<
    VBATT Powering Up >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    Forcing Test Mode via BUSCHECK...
    Booting Phone via FBUS...
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 030C1921
    ID DWORD 4 : 01033000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 23600009
    ID DWORD 1 : 8EB68C56
    ID DWORD 2 : F84B3BE1
    ID DWORD 3 : FC57B6B5
    ID DWORD 4 : 6096F729
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum C0
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    Boot File - Version 010.042.00
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    Secondary Loader Sent...
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0089 ->
    Device ID : 8982 -> NU48F512
    Extended/Fixed ID : 0000
    Revision ID : 8A31
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : 00000000000000000000
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Checksum : 51
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
    Flash Descriptor
    Device ID : 8982
    Revision ID : 0000
    Size : 04000000 (64 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 64
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    Algorithm File - Version 010.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    OLD Protocol Detected... Using Turbo Mode...
    Pabub KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    3EA22A1DDA660002E56108DB5072A10F8709443F
    Scanning Simlock Applet Type...
    OK
    PA_SL3 Applet detected
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    Waiting for Phone to Go Online...
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    Phone Type : RM-561
    Extended Phone Information
    Product Serial Number: DAT520107
    Product Code : 0579808
    Module Code : 0204245
    Basic Production Code: 0577212
    Long Production SN : 0
    PPM SW Version : V 09.98 06-09-10 RM-561 (c) Nokia V
    BT MCM Version : 2222-302
    MCU SW Version : V 09.98 06-09-10 RM-561 (c) Nokia
    HW Version : 1000
    RFIC Version : 06560601
    DSP Version : ICPR72_09w26
    LCD Version : SEIKO
    Content Pack Version : Content: v_black V 09.98 06-09-10 RM-561 (c) Nokia
    AHNE Version : 30
    RETU Version : 16
    TAHVO Version : 22
    Bluetooth ID : EC:9B:5B:4D:98:21
    CS Type : GSM850, GSM900, GSM1800, GSM1900
    Simlock Information
    CONFIG KEY : 0000000000000000
    PROVIDER KEY : 2440700000000000
    NETWORK NAME : Nokia Default;Finland
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SIMLOCK STATE : Not Locked
    SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SECURITY_CODE : 12345
    PHONE_MODE : TEST
    Dynamic Camera Configuration
    DCC ID : NIMMIIIIRRFF0A021001
    DCC Ver: 002007
    Status : OK
    Selected VPL File:
    RM561_0581057_09.98_032.vpl
    Variant Details : RM-561 SEAP_V_GRAY_STROKE_VIETNAM
    Software Version : 09.98
    Product Type : RM-561
    Product Code : 0581057
    Variant Version : 032
    Đời___Là__Bể___Khổ
  1. 2700 mất nguồn xin giúp ...
    By thaibao113 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 15-10-2012, 19:50
  2. 2700 gọi đi là mất nguồn cần giúp
    By tuyen_mobile1709 in forum BB5
    Trả lời: 17
    Bài viết cuối: 01-09-2012, 13:32
  3. Trả lời: 6
    Bài viết cuối: 07-03-2012, 18:55
  4. 2700 hao nguồn xin giúp
    By 99999 in forum BB5
    Bài viết cuối: 06-03-2012, 20:37
  5. 2700 mất nguồn xin giúp thank
    By nguyenlaluong in forum BB5
    Bài viết cuối: 22-12-2011, 08:43
