anh em xem hộ em cái log con 1800 này, sao vẫn ko lên nguồn.
Backup saved to "C:\mobileEx\3.5\data\backup\XGOLD_RM-653_88CECA5450AC95CC_IMEI.back"
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0860020
Using device: HTI, FW ver: 00.50, SN: 00016067
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits]
CFI information:
Flash settings: 0/1, size: 0x00800000
2 Block regions:
127 x 0x00010000 = 0x007F0000
8 x 0x00002000 = 0x00010000
EBL ready !
Processing file: rm653_006.510
Downloading item CODE:hw_b2_rm653_r06.510.fls, num block: 3, size: 4.14 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 39.562 s
Erasing area 0x00C60000-0x00E734FE ...OK
Programming completed in 40.094 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.156 s
Checksum verified (0xD2D6)
Processing file: rm653_006.51mr
Downloading item CUST:hw_b2_rm653_006.51mr.fls, num block: 1, size: 1.90 MB
Erasing area 0x00210000-0x003F4ABE ...OK
Programming completed in 36.703 s
Checksum verified (0xB261)
Processing file: rm6530_nai06.51mr
Downloading item CUST:hw_b2_rm6530_nai06.51mr.fls, num block: 1, size: 314.45 KB
Erasing area 0x00EB0000-0x00EFDCBE ...OK
Programming completed in 5.984 s
Checksum verified (0xF7F3)
Total time for flashing process(boot+erase+write) was 3 min 31.125 s
After Flash Processing ...
Reseting Factory Values OK.
Phone type: RM-653
SW version: V 06.51 13-05-11 RM-653 (c) Nokia
Imei plain: 35538604651888-6
Product code: 0594922
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MR
Language Pack:
- not available.
Imei net: 35538604651888
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
FULL FACTORY... OK
Completed in 1.282 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 2.172 s
