Kết quả 1 tới 4 của 4
    Thành viên tích cực tony.haokiet's Avatar
    Jan 2010
    Mặc định x3-02 chóp tắc
    em vừa nhận x3-02 mở nguồn lên rung chưa lên dc chử nokia màn hình chóp tác liên tục mình tưởng bị phần miền , đưa vào mx-box thì báo như thế nầy
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C08747B1
    Using device: USB Phonet and HTI, FW ver: 00.24, SN: 00015137
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
    Processing MCU file: rm639__05.60.mcusw
    [BB5,XSR 1.6] size: 30.46 MB
    Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
    Waiting for USB ROM device ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 5CF93AD
    CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
    CMT EM0 ID: 00001051
    CMT EM1 ID: 00001060
    CMT PUBLIC ID: 11B001058CA803442241412C65ADA534DD7D3C8D
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
    CMT ROM ID: E693EF0DAC22615B
    Loading CMT secondary boot code
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
    Update server code loaded.
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    FUR: Adding Asic CMT as client OK.
    Reading CMT NPC (0x190 bytes).
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35538004293876_CE RT.rpl"
    CMT PAPUBKEYS HASH: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 45.06 MB
    CMT FLASH,MuxOneNAND area [00020000-000203FF]
    CMT FLASH,MuxOneNAND area [00060000-0009FFFF]
    CMT FLASH,MuxOneNAND area [000A0000-0041FFFF]
    CMT FLASH,MuxOneNAND area [00420000-0069FFFF]
    CMT FLASH,MuxOneNAND area [006A0000-006DFFFF]
    CMT FLASH,MuxOneNAND area [006E0000-0123FFFF]
    CMT FLASH,MuxOneNAND area [02060000-020BFFFF]
    CMT FLASH,MuxOneNAND area [02CC0000-0333FFFF]
    CMT FLASH,MuxOneNAND area [07540000-07B3FFFF]
    CMT FLASH,MuxOneNAND area [01240000-0205FFFF]
    Formating partition ...
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 23B57C26 [RAP Certificate v1 260] sent
    CMT RAP3NAND block sent
    CMT UPDAPP block sent
    CMT LDSP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT MCUSW1 block sent
    CMT GENIO_INIT block sent
    CMT ISA+DYNSW block sent
    Programming completed in 7.421 s
    Processing PPM file: rm639__05.60.ppm_v
    [BB5,XSR 1.6] size: 8.50 MB
    Erase size: 12 MB
    CMT FLASH,MuxOneNAND area [020C0000-02CBFFFF]
    Programming completed in 1.984 s
    Processing CNT file: rm639__05.60.image_v_0598287_004
    [BB5,XSR 1.6] size: 34.53 MB
    Erase size: 66.06 MB
    CMT FLASH,MuxOneNAND area [03340000-0753FFFF]
    Programming completed in 8.563 s
    Total time for flashing process(boot+erase+write) was 49.875 s
    Phone not found, retrying ...
    Warning: Phone did not reboot to normal mode.
    cần sự giúp đỡ của anh em thanks
    Thành viên tích cực NT.mobile's Avatar
    lấy box khác flash lại đi bạn.tex cáp khác luôn nha.
    làm cả đời !! hết một giờ
    Thành viên tích cực TV.Mobile™_SGM™'s Avatar
    Jun 2012
    Thử cái màn trước đi bạn ơi
    TV.MoBile™-YM!:pinky.master205@yahoo.com.vn
  4. ( TV.Mobile™_SGM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tony.haokiet (20-08-2012)
    Jan 2010
    làm ok rồi . mình cũng không ngờ bị hư socket màn hình thanks ae nhiều
  1. máy samsung e2120 vina cắm sạc màn hình chóp chóp
    By thanh tuyền in forum DCT4 - WD2
    Bài viết cuối: 25-02-2012, 09:00
  2. 8310 lên chóp chóp cuc pin
    By Toan_MoBiLe_TN in forum DCT4 - WD2
    Bài viết cuối: 05-12-2010, 23:19
  3. Màn Hình N80 5 giây chóp 1 lần
    By keylove779 in forum BB5
    Bài viết cuối: 24-11-2010, 14:20
  4. 2300 mh chóp chóp...!
    By kvmobile in forum DCT4 - WD2
    Bài viết cuối: 15-11-2007, 23:43
  5. 6020 chóp chóp màn hình...!
    Bài viết cuối: 05-10-2007, 08:04
