giờ tình trạng máy mất boot ko check bằng cáp fbus được chỉ chạy usb thôi . đã xóa full đi chạy về 5233 ok sửa lỗi log đẹp ồi mà máy vẫn tình trang bật lên nokia được tý hiện dòng chữ phone start-up failed contsct the retailer trên màn hình mong ae chỉ giúp đây la log :
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C0855532
Using device: USB ROM and HTI, FW ver: 00.50, SN: 000096FD
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 1280000698AE0052C8DD0FB5EBBCB77DD8048A3E
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0xFF bytes).
Reading CMT CCC (0xFF bytes).
Reading CMT HWC (0xFF bytes).
Reading CMT R&D (0xFF bytes).
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet, PORT_ID: 3293B45B : thấy lạ ở dòng này vẫn la 5800
Verifying communication to device OK.
Phone type: RM-625 (Nokia 5233)
SW version: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia
ApeCoreSw: V 51.1.002
Imei plain: 35626404923954-6
Battery voltage: 3675 mV, current: 299 mA
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356264049239546
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
