    Thành viên tích cực tai nokia's Avatar
    Oct 2010
    Mặc định 1209 sóng yếu cần gúp gấp?
    em nhận 1209 đi xa cột sóng thì mất sóng .ở gần thì mọi thứ điều ok,em nghi là phần mềm chạy nó báo thế này.mong mọi ngườiGetting MCU ID
    MCU ID: 0x2292
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_06.000
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
    Loader size is 0x5548; Loader chk: d9
    Loader is ready...
    MSID: 84F42F39A1C4E52F4795E56CB8
    MSID decoded: 3E4EBAE90015878CA8000000
    FAID: 818056A2A9926F54668E877D
    Erasing...
    Found 5 interval(s) to erase
    Operation took 0 minutes 34 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 19 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_06.00mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 844D5B255D8AE2C6792476C916
    MSID decoded: 3E4EBAE90015878CAA000000
    FAID: 6280D288E339EC614458DE17
    Erasing PPM...
    Found 2 interval(s) to erase
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai6.00mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Operation took 0 minutes 2 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 2 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Changing mode...
    Failed!!! gúp em cách khắc phục sóng yếu này thank
    Thành viên tích cực TV.Mobile™_SGM™'s Avatar
    Jun 2012
    Bạn câu 2 sợi râu cho nó xem,mình làm nhiều cây rồi sóng vi vu luôn
    TV.MoBile™-YM!:pinky.master205@yahoo.com.vn
    Thành viên kỳ cựu ♠mobilebien™♂'s Avatar
    Nov 2011
    chạy lại bằng box khác cho nó done đi rùi cho nó cái pm full xem sao.
    Nơi làm việc: kythuatphone.vn
    Thành viên tích cực 246_GMS's Avatar
    Bạn câu 2 sợi dây đồng xem sao.
    Nov 2011
    làm mềm ko đc thì làm cpu nhé.
    Thành viên tích cực honghai.com's Avatar
    Xóa flash chạy lại rồi nạp pm chuẩn cho nó,nếu vẩn không được thì làm u
    Thành viên tích cực abc020010's Avatar
    cao lãnh ĐỒNG THÁP
    sog yếu là do tiếp xúc của bạn đó bạn câu 2 sợi dây ra làm tăng tính hiệu sóng thu và sóng phát.chúc bạn thành công
    dòng này câu ko ăn thua ji log như trên là chưa đồng bộ đc ko lên đc nguồn lên náy có lên nguồn thì cũng treo che chân vpppp lại rùi chạy lại ok tiếp đến thay con lọc phát trc ko đc thì làm uppp và PA chúc thành công
    Thành viên tích cực khicon_29_06's Avatar
    làm như anh duchanh xem nha nha bạn a hướng dẫn chính xác do.khoan hãy làm upp.kiểm tra loc thu lọc phát ok liền ah,mỉnh thủ rồi
  1. Nokia 1209 nạp file 1208 mất sóng ..........
    By AnNam_Mobile in forum DCT4 - WD2
    Bài viết cuối: 22-11-2010, 19:10
  2. xin file sóng 1209
    By TINHDATDOMIENDONG in forum DCT4 - WD2
    Bài viết cuối: 21-11-2009, 19:01
  3. l7 mất sóng cần gúp
    By thenguyenkhanhhoa in forum Acer - ODM - Old models
    Bài viết cuối: 19-05-2009, 21:02
  4. ae mình có con 6070 mất sóng cân gúp đở.
    By phongmobile_hongtrang in forum BB5
    Bài viết cuối: 13-12-2008, 13:35
  5. N95 mất sóng cần gúp đỡ .
    By HEOSUA in forum BB5
    Bài viết cuối: 20-10-2008, 19:07
