1280 chạy 10 hay nhiều máy full đều báo như vậy suốt.
1- đã cài đủ các ver
2- trước đó chạy bình thường,và bây giờ chạy máy khác bt nguyên 1280 là báo như thế này. và có con thì lên nguồn có con lại không lên. cho sang ATF done hết.
ae ai có cách khắc phục chỉ mình nhé..thanks.
log của em nó đây ạ...!
Backup already exists(C:\mobileEx\3.5\data\backup\XGOLD_RM-647_CB6CA67655479262_IMEI.back)
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0859F85
Using device: HTI, FW ver: 00.50, SN: 0000C4B5
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits]
CFI information:
Flash settings: 0/1, size: 0x00800000
2 Block regions:
127 x 0x00010000 = 0x007F0000
8 x 0x00002000 = 0x00010000
EBL ready !
Processing file: rm647_006.500
Downloading item CODE:hw_b2_rm647_r06.500.fls, num block: 3, size: 4.04 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 43.047 s
Erasing area 0x00C60000-0x00E5933E ...OK
Programming completed in 41.188 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.172 s
Error reading checksum!
Processing file: rm647_006.50mr
Downloading item CUST:hw_b2_rm647_006.50mr.fls, num block: 1, size: 1.10 MB
Erasing area 0x00210000-0x003288BE ...OK
Programming completed in 20.469 s
Checksum mismatch: Phone calculated 0x0033, software calculated 0x52F7
Processing file: rm6470_nai06.50mr
Downloading item CUST:hw_b2_rm6470_nai06.50mr.fls, num block: 1, size: 305.83 KB
Erasing area 0x00EB0000-0x00EFBA3E ...OK
Programming completed in 5.625 s
Checksum mismatch: Phone calculated 0x00F0, software calculated 0x342D
Total time for flashing process(boot+erase+write) was 3 min 27.828 s
Nơi làm việc: kythuatphone.vn
