Kết quả 1 tới 4 của 4
    Thành viên tích cực theanhdienbien's Avatar
    Nov 2010
    sỐ nhà 129-tỔ 9-P.Mường Thanh-TP.Điện Biên
    Mặc định n95 8gb Rm-421 chớp tắt
    e có c0n n95 8gb chớp rồi tắt,ae xem log hộ e cái.xem nó bị sa0?thanks all
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    Number of Sub Blocks 11 (0x0B)
    1 SYSTEM_ASIC_ID 01
    Block Length : 5 (05)
    BB ASIC Index : 1 (01) APE
    ID DWORD 0 : 24200705
    2 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    3 PUBLIC_ID 12
    Block Length : 21 (15)
    ID DWORD 0 : B76D9075
    ID DWORD 1 : 139255E9
    ID DWORD 2 : 9117F4A6
    ID DWORD 3 : E1E711AF
    ID DWORD 4 : 58B89420
    4 ROOT_KEY_HASH 14
    Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00
    5 SYSTEM_ASIC_ID 01
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 400C1921
    ID DWORD 4 : 01021103
    6 EM_ASIC_ID 02
    ID DWORD 0 : 00000295
    7 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    8 PUBLIC_ID 12
    ID DWORD 0 : 15200215
    ID DWORD 1 : EECB0158
    ID DWORD 2 : E36D43EF
    ID DWORD 3 : 8109B9BD
    ID DWORD 4 : A30E5591
    9 ASIC_MODE_ID 13
    Mode Id : 00
    10 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE
    11 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : A8C1D671
    CRC 1 : 3E691FF8
    Checksum D6
    NOR Chip Detected... Nitro Flashing Disabled
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAPIDOv11_2nd.fg
    Boot File - Version 01.037.01
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    Secondary Loader Sent...
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0001 ->
    Device ID : 0035 -> 72NS128N
    Extended/Fixed ID : 0000
    Revision ID : 6921
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : FFFFFFFFFFFFFFFFFFFF
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Checksum : F0
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :0001 DevID :0035 ExtID :0000 RevID :6921
    Flash Descriptor
    Device ID : 0035
    Revision ID : 0000
    Size : 01000000 (16 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAPIDOv11_algo.fg
    Algorithm File - Version 01.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    Pabub KEY Request
    No PAPUBKeysHash Returned
    Searching for APE Boot File..
    SearchForBootstrap_DCT5...
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\omap2420_m1_2nd.fg
    Boot File - Version
    Boot File - Revision 0x (2)
    eBB5ProtocolType == New
    SuggestedType : 04 DDR & 2TX
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
    ReturnedType : 04 DDR & 2TX
    SendAPECodeRequest_DCT5..
    SendAPECodeRequest_DCT5 FLS1_NO_ERROR..
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    BB ASIC Index : APE 01
    Device Type : NAND 01
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0040 -> KAT00F00RA
    Extended/Fixed ID : 0022
    Revision ID : 0000
    2 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 20
    Data : OMAP2420 UNISTORE-II-1.5.1 ALG
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Checksum : BC
    Searching for APE Algorithm File..
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    Size : 10000000 (256 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\teflon_sam_nand_xsr15 1_m1.fg
    Algorithm File - Version 01.052.00
    APE Algorithm Sent
    Pabub KEY Request
    Scanning Simlock Applet Type...
    Simlock Type is UNKNOWN
    Điện Thoại Di Động Thế Anh
    ĐT:0989757372
    Nov 2010
    em chạy máy báo lỗi
    Processing Image File :
    C:\Program Files\Nokia\Phoenix\Products\RM-421\RM-421_35.2.002_PR.C0R
    CMT Type : BB5
    CMT Algorithm : XSR 1.5
    Secondary Sending Speed : 51000 Hz
    Algorithm Sending Speed : 6500000 Hz
    Program Sending Speed : 6500000 Hz
    Message Reading Speed : 98000 Hz
    APE PHONE Type : BB5
    APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG
    APE Supported Hardwares :
    > 24200705
    Number of Blocks : 442
    Entry Point : 0x026E
    Page Format : 128K
    Maximum Page Size : 0x00030000
    Changing MODE : FLASH
    Booting Phone via FBUS...
    VBATT Powering Down <<<<
    VBATT Powering Up >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    BootFlashMode_DCT5
    TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded after 3 Attempts
    1 SYSTEM_ASIC_ID 01
    2 ASIC_MODE_ID 13
    Mode Id : 00
    3 PUBLIC_ID 12
    4 ROOT_KEY_HASH 14
    5 SYSTEM_ASIC_ID 01
    6 EM_ASIC_ID 02
    7 EM_ASIC_ID 02
    8 PUBLIC_ID 12
    9 ASIC_MODE_ID 13
    Mode Id : 00
    10 ROOT_KEY_HASH 14
    11 ROM_ID 15
    CRC 0 : A8C1D671
    CRC 1 : 3E691FF8
    Checksum D6
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    Device Index : 00
    Revision ID : 6921
    Block Length : 13
    Device Index : 00
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Checksum : F0
    SendAlgoCode_DCT5..
    Flash Descriptor
    Device ID : 0035
    Revision ID : 0000
    VPP Info : 0009
    Erase10s : 28
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    Pabub KEY Request
    Boot File - Version
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Block Length : 20
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Checksum : BC
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    APE Algorithm Sent
    Pabub KEY Request
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : APE 1
    Certificate 2
    ASIC Index : APE 1
    Certificate 3
    ASIC Index : APE 1
    Certificate 4
    ASIC Index : APE 1
    STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 01 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 01 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 01 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 01 CF
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    1 PARTITION_INFO_BB5
    BB ASIC Index : 0x01 APE
    Device Type : 0x01 NAND
    Device Index : 0x00
    Partition Version : 00010000
    Spare : FFFFFFFF
    Num Partitions : 00000004
    Partition 1
    Attribute : 00000002 RO
    Start Address : 00A40000
    Partition 2
    ID : 00000004 DEMANDONOS
    Start Address : 03A40000
    Partition 3
    ID : 00000008 FILESYSTEM
    Attribute : 00000001 RW
    Start Address : 06F40000
    Partition 4
    ID : 00000009 FILESYSTEM1
    Start Address : 0F880000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000 000200A4000003000000000000040000000203A40000035000 00000000080000000106F40000089400000000000900000001 0F880000001A000077
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
    VPP Enabled by Software
    Using Internal VPP
    StartErase_DCT5...
    BlockLength : 0x63 (99)
    ERASE Blocks : 0x02 (2)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x1B (27)
    BB ASIC Index : 0x00 CMT
    Device Type : 0x00 NOR
    Device Index : 0x00
    0 : 00080000-007CF605
    1 : 00000000-0005FFFF
    2 : 00880000-00FDFFFF
    1 ERASE_AREA_BB5 0x12
    Block Length : 0x43 (67)
    Device Index : 0x00
    0 : 00000200-0000AFFF
    1 : 0000B800-000AFFFF
    2 : 00000000-00000FFF
    3 : 0000D800-0000E9FF
    4 : 00080000-000BFFFF
    5 : 000E0000-0045FFFF
    6 : 004C0000-0073FFFF
    7 : 00A40000-06F3FFFF
    Erase_SendEraseBlock_BB5_NOR
    Task in Progress... Please Wait...
    Status_BB5 STATUS_REQUEST_BB5..
    1 Sub Block ID : 14 STATUS_NOR_OK_BB5
    Block Length : 01
    BB ASIC Index : 00
    2 Sub Block ID : 15 STATUS_NAND_OK_BB5
    Block Length : 0F
    BB ASIC Index : 01
    Device Type : 03
    Device Type : 00
    Num Bad Blocks : 00000001
    Additional Bad : 00000001
    Correctable ECC : 00000001
    Erase_SendEraseBlock_BB5_NAND
    Block Length : 01
    BB ASIC Index : 00
    Block Length : 0F
    BB ASIC Index : 01
    Device Type : 03
    Device Type : 00
    Successfully erased..
    Time Taken to Erase : 00:00:05
    Flashing Speed: 5.00 Mhz
    Processing : RM-421_35.2.002_PR.C0R
    Total blocks to write : 442
    FBUS Cable RX2 PIN Diagnostics
    Block Length : 01
    BB ASIC Index : 00
    Block Length : 0F
    BB ASIC Index : 01
    Device Type : 03
    Device Type : 00
    INFO: RX2 PIN is OK
    >> CMT Rootkey Hash CERT : NOLO
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS
    >> CMT Rootkey Hash CERT : UPDAPP
    >> CMT Rootkey Hash CERT : DSP0
    >> CMT Rootkey Hash CERT : MCUSW
    >> APE Rootkey Hash CERT : X-LOADER
    >> APE Rootkey Hash CERT : KEYS
    >> APE Rootkey Hash CERT : PRIMAPP
    >> APE Rootkey Hash CERT : SOS+XZIP
    >> APE Rootkey Hash CERT : PASUBTOC
    >> APE Rootkey Hash CERT : PAPUBKEYS
    >> APE Rootkey Hash CERT : SOS+UPDAPP
    >> APE Rootkey Hash CERT : SOS+CORE
    >> APE Rootkey Hash CERT : SOS+ROFS
    ContinueFlash_DCT5 Complete
    Block Length : 01
    BB ASIC Index : 00
    Block Length : 0F
    BB ASIC Index : 01
    Device Type : 04
    Device Type : 08
    Num Bad Blocks : 00000000
    Additional Bad : 00000000
    Correctable ECC : 00000000
    Block Length : 01
    BB ASIC Index : 00
    Block Length : 0F
    BB ASIC Index : 01
    Device Type : 03
    Device Type : 00
    Continue Flash Complete : : No Error - 0 (0x00)
    Time Taken to Flash : 00:01:14
    C:\Program Files\Nokia\Phoenix\Products\RM-421\RM-421_35.2.002_PR.v28
    CMT Type : BB5
    Secondary Sending Speed : 650000 Hz
    > 24200705
    Number of Blocks : 114
    Entry Point : 0x0159
    Page Format : 128K
    Partition Info
    Device Index : 0x00
    Spare : FFFFFFFF
    Partition 1
    Partition 2
    Partition 3
    Partition 4
    ProcessPartitionInfo_DCT5 : Error
    Operations Failed....
    ĐT:0989757372
    Nov 2010
    không ai giúp e à?
    ĐT:0989757372
    Thành viên kỳ cựu setot_thoi's Avatar
    Sóc Trăng
    tình trạng ban đầu ra sao . nếu lúc đầu chớp tắt thì múc qua bõ khác xem
    MẩnMobile .Y/H : Jimmyphong10
