tình hình là máy vẫn ok nhưng chỉ thiếu máy tính " khách yêu cầu mình chạy có máy tính em đã flash 5.60 nhưng không ok" nhờ AE ra tay giúp em một phát "
và đây là long em nó " mấy anh đọc giúp em với"thank all ạ
Version from phone: 05.60
Version from file: 05.60
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0873B70
Using device: HTI, FW ver: 00.50, SN: 00016175
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35482702124616_BA CK.rpl).
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1E80021540940254427C9057D4C59981C5173AD8
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
eBB5ProtocolType: OLD
Storage0: 00EC 2208 - 0000 0121 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 2F36DDC4990FD844712A61A80C033211BD9602E3
TransmissionMode: DDR&TX2
Processing MCU file: rm123_145_30005.600.mcusw
[BB5,BB5 ALGORITHM] size: 16.29 MB
Erase size: 17.75 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0000FFFF]
CMT FLASH,NOR area [00010000-0007FFFF]
CMT FLASH,NOR area [000A0000-0021FFFF]
CMT FLASH,NOR area [00220000-011DDFFF]
CMT FLASH,NOR area [011DE000-011DEFFF]
CMT FLASH,NOR area [011DF000-011DFFFF]
erased in 43.234 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 2F36DDC4 [Rap certificate 24 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT PMM_CONF block sent
CMT SBIF_CONF block sent
NOR: OK
Programming completed in 1 min 22.391 s
Processing PPM file: rm123_145_3005.60.ppm_v
[BB5,BB5 ALGORITHM] size: 4.84 MB
Erase size: 5 MB
CMT FLASH,NOR area [011E0000-016DFFFF]
erased in 12.562 s
NOR: OK
NOR: OK
Programming completed in 25.234 s
Processing CNT file: rm123_145_30005.60.image_v
[BB5,BB5 ALGORITHM] page size: 64 K size: 3.25 MB
Converting UCP blocks to 128 K.
Erase size: 9 MB
CMT FLASH,NOR area [016E0000-01E7FFFF]
CMT FLASH,NOR area [01E80000-01FDFFFF]
erased in 23.297 s
NOR: OK
NOR: OK
Programming completed in 16.609 s
Total time for flashing process(boot+erase+write) was 3 min 32.281 s
Phone type: RM-145 (Nokia 6233)
SW version: V 05.60 14-09-07 RM-145 (c) Nokia
Imei plain: 35482702124616-8
Product code: 0536490
Battery voltage: 4613 mV, current: 94 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354827021246168
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 8000000000000002
