Kết quả 1 tới 3 của 3
    Thành viên mới duclongdt88's Avatar
    Jan 2011
    Mặc định e71-1 rm-346 chạy phần mềm báo lỗi
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C085D87E
    Using device: HTI, FW ver: 00.50, SN: 01006933
    Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
    Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
    Processing MCU file: rm346_510.21.009_prd.c00
    [BB5,XSR 1.5] size: 67.83 MB
    Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 1C90011414AA8B527A95A28FE9A6BCCCCBF36854
    ASIC MODE ID: 00
    ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
    ROM ID: 4B9B75103E691FF8
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
    CMT PAPUBKEYS HASH: 52570A2086C79E6965175815B5388535CDD5C6F7
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning ...OK
    Erase size: 122.56 MB
    CMT FLASH,MuxOneNAND area [00040000-007FFFFF]
    CMT FLASH,MuxOneNAND area [00A00000-0759FFFF]
    CMT FLASH,MuxOneNAND area [0F1C0000-0F8BFFFF]
    Formating partition ...
    Prog.status for Asic CMT ...
    NAND: OK
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 52570A20 [RAP Certificate 101 v1] sent
    CMT SOS*UPDAPP block sent
    CMT SOS*DSP0 block sent
    CMT SOS*ISASW block sent
    CMT SOS*CORE block sent
    CMT SOS+ROFS block sent
    NAND: Status reported bad blocks.
    Programming completed in 2 min 19.853 s
    Processing PPM file: rm346_510.21.009_prd.v29
    [BB5,XSR 1.5] size: 22.51 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 33.56 MB
    CMT FLASH,MuxOneNAND area [05420000-0759FFFF]
    NAND: OK
    CMT SOS+ROFX block sent
    Programming completed in 47.820 s
    Processing CNT file: rm346_510.21.009.08U
    [BB5,XSR 1.5] size: 18.06 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 64 KB
    NAND: OK
    NAND: OK
    Programming completed in 39.293 s
    Total time for flashing process(boot+erase+write) was 4 min 8.342 s
    nhờ các anh xem hộ em nó lỗi ở đoạn nào mà không lên nguồn với.em đã chạy đủ các kiểu rồi
    Máy ban đầu bị gì bạn cho chút thông tin nửa đi,kiểm tra cáp và pinout sạch sẻ không được thì thay qua box khác xem sao.
    Thành viên kỳ cựu dinhhieu444's Avatar
    ĐỒNG NAI
    flash fbush xem sao không thì Phoenix vesion cao nhất , nếu máy lên treo flash (blank_504KB_pmm_10) chọn mục mcu
  1. Trả lời: 0
    Bài viết cuối: 26-02-2012, 13:32
  2. thay ic nguồn Qmobile có phải chạy lại phần mềm ko?
    By gamoi.gsm in forum Sửa chữa phần cứng
    Bài viết cuối: 23-10-2011, 07:35
  3. Phần mềm nhận biết sài chung cáp khi chạy phần mềm
    By vohuyvu1981 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 10-07-2011, 07:48
  4. Thảo luận cách chạy phần mềm và sự cố trong lúc chạy phần mềm
    By KIM HUNG in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-05-2008, 20:38
