log em nó nè...
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0871D8F
Using device: HTI, FW ver: 00.50, SN: 0100B1EC
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20713(27-03-2012), Library ver: 1.0.0.13992(27-03-2012)
ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690
UEM ID: 00832D44:2984DA60
ASIC type: 2
UEM Imei: 35273701643163
Flash Imei: 35273701643163
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35273701643163_BA CK.rpl"
Processing MCU file: rh37__06.220
[DCT4,DCT4 ALGORITHM] size: 8.01 MB
Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143, 3161, 3160
UEM ID: 00832D44:B789DA60
Area [01000000-0101FFFF] erased in 1.297 s
Area [01020000-0181FFFF] erased in 1 min 19.250 s
Area [01E60000-01FDFFFF] erased in 14.719 s
Flash programming ...
Programming completed in 50.625 s
File processed in 2 min 33.234 s
Processing CNT file: rh37__06.22.image_v
[DCT4,DCT4 ALGORITHM] page size: 64 K size: 2.31 MB
UEM ID: 00832D44:0BDFDA6A
Area [01A40000-01E5FFFF] erased in 40.922 s
Converting UCP blocks to 128 K.
Programming completed in 13.719 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 0.141 s
File processed in 1 min 19.282 s
Processing PPM file: rh37__06.22v
[DCT4,DCT4 ALGORITHM] size: 1.67 MB
Area [01820000-01A3FFFF] erased in 20.781 s
Programming completed in 10.704 s
File processed in 38.890 s
Total time for flashing process(boot+erase+write) was 4 min 31.406 s
Phone type: RH-37 (Nokia 3220)
SW version: V 06.22 23-05-07 RH-37 (c) Nokia.
Imei plain: 35273701643163-8
Imei OTP: 35273701643163
Product code: 0518283
Cellular system: GSM
ASIC ID: 0x2142, type: 2
Ppm Id: V
Language Pack:
Engliah,Chinese Simp,Chinese Trad,Vietnamese
Master code: 4363305456
Imei net: 35273701643163
Version: SIMLOCK SERVER VERSION 58
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000002
chạy ok nhưng vẫn trắng màn hình rồi tắt nguồn..hiz
