Kết quả 1 tới 10 của 16
    Thành viên tích cực pEtrAngXinh's Avatar
    May 2012
    bmt daklak
    Mặc định anh em coi hộ em cái log chech 6700c với
    tình hình náy khác mang vào kẹp nguôn len xanh mh em check không dc em chạy lai nhưng không đồng bộ đc song em chech đc thế này
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0874392
    Using device: USB Phonet and HTI, FW ver: 00.24, SN: 00015515
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPUYAMA ver: 1.1]
    CMT EM0 ID: 00000C34
    CMT EM1 ID: 00000C30
    CMT PUBLIC ID: 1480010AAF850344B55F01D4FD649EB04F6AF735
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
    CMT ROM ID: 3E273BF637BE26FA
    Loading CMT secondary boot code
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 0098 0040 - 0000 0031 [Toshiba NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
    Update server code loaded.
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 11834FD8
    FUR: Adding Asic CMT as client OK.
    CMT PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6
    Original Imei: 35269604883451
    Original Product code: 0571231
    Bluetooth ID: D4CBAF000A55
    SIMLOCK PA identifier:
    [0] PA_SL3
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Phone type: RM-470 (Nokia 6700 classic)
    SW version: V 13.21 12-01-11 RM-470 (c) Nokia
    Imei plain: 35269604883451-8
    Battery voltage: 3788 mV, current: 193 mA
    Language Pack:
    - not available.
    Market items is empty, please select the correct products path !
    yêu em vất vả kết quả trắng tay
    yêu anh vất vả em được tayga..:D
    Thành viên kỳ cựu dinhhieu444's Avatar
    ĐỒNG NAI
    flash usb vesion cao nhất luôn xem sao bạn
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    phonix múc lại phát coi sao bác
    bạn chọn file chuẩn ver đụng nóc rồi mang qua box khác chạy lại cho e nó chắc ok thôi. good luck
    May 2012
    cho vào phoenix chọn ver cao nhất quất cho nó cái là tỉnh ngủ thôi mà
    May 2012
    bmt daklak
    mình không biết chạy phoenix mình chay hwk với mx box
    lấy mxbox chiến usb ver cao nhất xem sao bạn
    yh chanyenmobile_led1202
    ctk hà Văn Yên face hachanyen
    sdt zalo..0972444489
    BỘ ngoại giao trùm các 4r
    ĐỒNG NAI
    lên mạng seach có hưỡng dãn luôn bạn
    Thành viên chính thức hoangtrien's Avatar
    chạy phoenix dễ thôi
    May 2012
    bmt daklak
    em múc ver cao nhất rồi nó vẫn thế
  1. anh em coi hộ em cái log chech 3110c với
    By pEtrAngXinh in forum BB5
    Bài viết cuối: 06-09-2012, 18:49
  2. 6700c mất đèn phím
    By yenbaimobile in forum BB5
    Bài viết cuối: 02-05-2010, 12:38
  3. anh em xem hộ cái log chech 3110c
    By van_ninh_mobile in forum BB5
    Bài viết cuối: 06-03-2010, 20:16
  4. 5610d chech tu dong len nguon
    By hieutrung in forum BB5
    Bài viết cuối: 15-01-2009, 09:07
  5. how to find charger pin and SPD cpu pinout chech here!
    By qiuxu in forum Máy Trung Quốc
    Bài viết cuối: 24-06-2008, 19:36
