Kết quả 1 tới 10 của 10
    Thành viên tích cực uyếnhà's Avatar
    Oct 2011
    Mặc định phần mềm 7210c
    đây là long của nó Version from phone: 07.23
    Version from file: 07.23
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C08593E1
    Using device: HTI, FW ver: 00.50, SN: 0100BCDF
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
    Reading RPL backup ...
    Reading Secure Storage ...
    Reading Important data ...
    Reading SIMLOCK data ...
    Reading CERT data ...
    CMT Data :
    EM0 ID: 00000295
    EM1 ID: 00000B22
    PUBLIC ID: 0FA001187C6E575095F41B45B1B6F48203ECC8EB
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 10.42.0 revision: 0.0 size: 0x3C40
    eBB5ProtocolType: OLD
    Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.40.0 revision: 0.0 size: 0x23550
    CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
    TransmissionMode: DDR&TX2
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Flash Imei: 35574302385599
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    SIMLOCK_DATA saved OK
    SIMLOCK_KEY_DATA saved OK
    SUPERDONGLE_KEY_DATA saved OK
    CMLA_KEY_DATA saved OK
    WMDRM_PD_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    LOCK120_DATA saved OK
    BB_DATA is empty.
    RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35574302385599_BA CK.rpl"
    CMT Data :
    EM0 ID: 00000295
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Processing MCU file: rm436__07.23.mcusw
    [BB5,BB5 ALGORITHM] size: 18.06 MB
    Erase size: 19.12 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00040000-000BFFFF]
    CMT FLASH,NOR area [000C0000-0013FFFF]
    CMT FLASH,NOR area [00140000-0119FFFF]
    CMT FLASH,NOR area [011A0000-0133FFFF]
    erased in 1 min 13.937 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: F1DCA5EA [RAP Certificate 142 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    NOR: OK
    Programming completed in 1 min 5.922 s
    Processing PPM file: rm436__07.23.ppm_v
    [BB5,BB5 ALGORITHM] size: 7.68 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01340000-01BDFFFF]
    erased in 31.266 s
    NOR: OK
    NOR: OK
    Programming completed in 25.594 s
    Processing CNT file: rm436__07.23.image_v_ny
    [BB5,BB5 ALGORITHM] page size: 128 K size: 9.89 MB
    Erase size: 35.87 MB
    CMT FLASH,NOR area [01BE0000-01F7FFFF]
    CMT FLASH,NOR area [01F80000-03FBFFFF]
    erased in 3 min 37.985 s
    NOR: OK
    NOR: OK
    Programming completed in 33.094 s
    Total time for flashing process(boot+erase+write) was 7 min 35.719 s
    Phone type: RM-436 (Nokia 7210 Supernova)
    SW version: V 07.23 17-07-09 RM-436 (c) Nokia
    Imei plain: 35574302385599-8
    Product code: 0566926
    Battery voltage: 4506 mV, current: 28 mA
    Language Pack:
    - not available.
    SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
    Camera config: NIMMIIIIRRFF094B2F01, ver: 002.010
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Imei net: 355743023855998
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Jun 2012
    SECURITY_TEST failed! máy bi j vây ban log bi lổi ở chổ dó ban cho biết tình trang máy di
    Oct 2011
    bật nguồn lúc lên lúc cheo khi lên thi hiện cotacsev mình chua làm bao giờ
    Oct 2011
    uppppp cho các bác vào giúp em nào
    Thành viên tích cực PHÁT TÀI's Avatar
    Repair SD=>super SD Auth=>PMM AUth=>write pm 1+309=>ok
    ccydia / manage / sources / edit / add / iphone.gsm.vn
    Raw file system -> var -> root -> media -> cydia -> AutoInstall
  6. ( PHÁT TÀI ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    uyếnhà (13-09-2012)
    Jun 2012
    Repair SD=>super SD Auth=>PMM AUth=>write pm 1+309=>oklam2 ntn này ok nhé ban
  8. ( NGỌC HÒA_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    uyếnhà (13-09-2012)
  9. #7
    V.I.P ĐƠ_NGUYỄN's Avatar
    có video cho bạn luôn
  10. ( ĐƠ_NGUYỄN ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    cuchimobile (14-09-2012)
  11. #8
    Thành viên tích cực TRUONGMOBILE-123's Avatar
    Aug 2012
    chạy mềm mà kg hết thì bị cặp là chắc rồi bạn ơi...
  12. #9
    Thành viên tích cực Phungmobi's Avatar
    Sep 2010
    được chưa....qua yh mình xem thử
    buôn ma thuột,daklak....y/h : vangtrangcodon_tny145
  13. #10
    Oct 2011
    mạng chố em kémpMM AUth dc
  1. 7210c phần mềm lỏi xin giúp
    By hungmobile_90 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 13-10-2011, 13:12
  2. 7210c chạy phần mềm báo lỗi
    By hoang_ha03 in forum BB5
    Bài viết cuối: 11-03-2011, 18:29
  3. Trả lời: 9
    Bài viết cuối: 01-02-2011, 18:56
  4. Trả lời: 2
    Bài viết cuối: 31-01-2010, 10:17
  5. càn phần mềm Flash 7210C
    By nguyentuan4987 in forum BB5
    Bài viết cuối: 26-09-2009, 15:15
