    Thành viên kỳ cựu newnice's Avatar
    Mar 2012
    hải dương
    Mặc định c5-06 cần các bác xem hộ cái log ...thaks all
    em có con c5-06 ...máy nghe gọi vẫn bt ..sử dụng được 1 lúc thì ..máy tối đen màn hình và khởi đọng lại
    em chạy lại phần mềm bằng usb thì nó báo như thế này
    Number of Image Files: 4
    Processing Image File :
    RM-816_23.6.015_prd.core.C00
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed : 650000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 13000000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 468
    Entry Point: 0x01E2
    Page Format : -1
    MAX PAGE : 0x00040000
    RM-816_23.6.015_C01_prd.rofs3.fpsx
    CMT Type : BB5
    Number of Blocks : 8
    Entry Point: 0x00E1
    Page Format : -1
    RM-816_23.6.015_prd.rofs2.V20
    CMT Type : BB5
    Number of Blocks : 79
    Entry Point: 0x00E7
    Page Format : -1
    RM815_816_004_U001.uda.fpsx
    CMT Type : BB5
    Number of Blocks : 34
    Entry Point: 0x00E7
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000003
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010007
    ID DWORD 3 : 600C1921
    ID DWORD 4 : 02031104
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00001040
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00001060
    4 PUBLIC_ID 12
    ID DWORD 0 : 28600112
    ID DWORD 1 : 0C0D5940
    ID DWORD 2 : ABE3BFA8
    ID DWORD 3 : 1D97F4F7
    ID DWORD 4 : 870A7CA3
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : DA 55 0B 5B AA B5 17 40 90 88 A3 E4 F3 EB 53 AC
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : E693EF0D
    CRC 1 : AC22615B
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_2n d.fg
    Secondary Loader Sent....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> Type not in database
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0040 -> Type not in database
    Revision ID : 0241
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data :
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    Size : 10000000 (256 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_XS R17_alg.fg
    Algorithm Loader Sent...
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok
    START READING RPL DATA
    IMEI: 358295042912273
    Reading : NPC... OK!
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : R&D... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\358295042912273\3582950429122 73_53521.rpl
    Pabub KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    FCA5CA3CB2B6BE0DD4FAD6075AFCBB8D7972103C
    ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-816\
    ImageFilename: RM-816_23.6.015_prd.core.C00
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    1 PARTITION_INFO_BB5
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    Partition Version : 00020000
    Spare : FFFFFFFF
    Num Partitions : 00000004
    Partition 1
    Attribute : 00000002 RO
    Start Address : 000A0000
    Partition 2
    ID : 00000004 DEMANDONOS
    Start Address : 02E80000
    Partition 3
    ID : 00000008 FILESYSTEM
    Attribute : 00000001 RW
    Start Address : 0A340000
    Partition 4
    Start Address : 0F640000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF00000004000000030000 0002000A000002DE0000000000040000000202E80000074C00 0000000008000000010A34000004F400000000000A00000001 0F640000003C000050
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0x4F (79)
    ERASE Blocks : 0x02 (2)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x1B (27)
    Device Index : 0x00
    0 : 00020000-0003FFFF
    1 : 00060000-004DFFFF
    2 : 008E0000-0A33FFFF
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x02000000
    Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5003120B000300000200000003FFFF120B0003000006000000 4DFFFF120B000300008E00000A33FFFF7F
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000000000 0002000000640000000B000000020000000100000000000000 0033
    Successfully Erased...
    Total blocks to write : 468
    >> CMT Rootkey Hash CERT : ADA
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : RAP3NAND
    >> CMT Rootkey Hash CERT : SOS+PMML
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS
    >> CMT Rootkey Hash CERT : GENIO_INIT
    >> CMT Rootkey Hash CERT : SOS*UPDAPP
    >> CMT Rootkey Hash CERT : SOS*DSP0
    >> CMT Rootkey Hash CERT : LDSP
    >> CMT Rootkey Hash CERT : SOS*ISASW
    >> CMT Rootkey Hash CERT : SOS+CORE
    >> CMT Rootkey Hash CERT : SOS+ROFS1
    ImageFilename: RM-816_23.6.015_C01_prd.rofs3.fpsx
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    ERASE Blocks : 0x01 (1)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 09940000-0A33FFFF
    ERASE_REQUEST_BB5 : 5001120B000300099400000A33FFFF06
    Total blocks to write : 8
    >> CMT Rootkey Hash CERT : SOS+ROFS3
    ImageFilename: RM-816_23.6.015_prd.rofs2.V20
    StartErase_DCT5...
    Device Index : 0x00
    0 : 077D0000-0993FFFF
    ERASE_REQUEST_BB5 : 5001120B000300077D00000993FFFFC0
    Total blocks to write : 79
    >> CMT Rootkey Hash CERT : SOS+ROFS2
    ImageFilename: RM815_816_004_U001.uda.fpsx
    StartErase_DCT5...
    Device Index : 0x00
    0 : 0A340000-0F27FFFF
    ERASE_REQUEST_BB5 : 5001120B0003000A3400000F27FFFF6C
    Total blocks to write : 34
    ContinueFlash_DCT5 Complete
    Continue Flash Complete : : No Error - 0 (0x00)
    Status_BB5 STATUS_REQUEST_BB5..
    1 Sub Block ID : 15 STATUS_NAND_OK_BB5
    Block Length : 0F
    BB ASIC Index : 00
    Device Type : 03
    Device Type : 00
    Num Bad Blocks : 00000003
    Additional Bad : 00000003
    Correctable ECC : 00000000
    FlashInfo.RestartMode : 1
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:19
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    SW: V ICPR82_11w25.10 08-06-12 RM-816 (c) Noki
    CONFIG KEY : 0000000000000000
    PROVIDER KEY : 2440700000000000
    NETWORK NAME : Nokia Default;Finland
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SIMLOCK STATE : Not Locked
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SUPER_DONGLE_TEST : FAILED
    > REPAIR USING FBUS CABLE
    > Try "Customized SX4 with SD Repair"
    > Then Write PM 1 and 309
    SL3 Phone detected
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    FACTORY SET TO : Full Factory Set
    OK
    FACTORY SET TO : User Data
    OK
    FACTORY SET TO : Leave Factory
    OK
    FACTORY SET TO : Service Center
    OK
    FACTORY SET TO : Software Upgrade
    OK
    FACTORY SET TO : Production Tune
    OK
    RESET LIFE TIMER TO : 0000:00
    OK
    Đời___Là__Bể___Khổ
    Moderator TÚ CÒI's Avatar
    hà nội
    Lấy cáp FBus(ko có ốp thì dùng đa năng) sửa cái lỗi này đi nhé
  3. ( TÚ CÒI ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    newnice (22-09-2012)
    *Có cáp áp lưng thì sửa lổi lại nha bạn,USB không sửa được đâu...
  5. ( Lính Khang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    nó đã chỉ lỗi & cách khắc phục luôn rồi đây
  7. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  8. #5
    Mar 2012
    hải dương
    vâng cảm ơn các huynh .nhé ...trân thành cảm ơn ...
    Đời___Là__Bể___Khổ
  9. #6
    Mar 2012
    hải dương
    các bác ơi ai có pm của con c5-06 cho em với ...
    Đời___Là__Bể___Khổ
  10. #7
    Mar 2012
    hải dương
    em tim trong atf nhưng ko có ... giờ phải lam sao đây
    Đời___Là__Bể___Khổ
  1. Trả lời: 6
    Bài viết cuối: 30-05-2013, 08:24
  2. Trả lời: 9
    Bài viết cuối: 14-05-2013, 10:48
  3. x6 liệt phím cần giúp thaks all
    By newnice in forum BB5
    Bài viết cuối: 13-03-2013, 08:30
  4. mx box cần các bác giúp thaks
    By newnice in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 23-08-2012, 14:38
  5. e75 cần giúp!!!! thaks
    Bài viết cuối: 24-07-2012, 15:27
