    Thành viên chính thức nguyễn kisu's Avatar
    Feb 2012
    cái bè_tiền giang
    Mặc định 3110c gắn sim vào máy báo " đã hạn chế điện thoại"
    như tiêu đề ...3110c ''đã hạn chế điện thoai'' em đã dùng mxkey lash và đây là log ..xin mấy anh hướng dẫn cách khắc phục và cách sữa lổi vì em chưa từng làm bệnh này bao giờ...thank all
    HƯỚNG DẨN SỬA LỔI :''CONFIG_DATA: FFFFFFFFFFFFFFFF''
    ''PROFILE_BITS: FFFFFFFFFFFFFFFF''
    VÀ ĐÂY LÀ LOG MXKEY ...
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085373B
    Using device: USB Phonet and HTI, FW ver: 00.50, SN: 000036D4
    Connection status: UHCI:HUB::USB 2.00 (Full-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
    Processing MCU file: 3110c_TV_OK.mcusw
    [BB5,BB5 ALGORITHM] size: 14.49 MB
    Supported Ids: 0103192101001101, 010C192101001101
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000010000022600010006
    010C192101001101 [RAP3G ver: PA 1.x]
    CMT EM0 ID: 00000232
    CMT EM1 ID: 00000353
    CMT PUBLIC ID: 1160021621E87E5692FBBD7D8E0EC10A1EBFEE64
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH:
    BAF3A9C3DBFA8454937DB77F2B8852B1
    CMT ROM ID: 191EC665DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x38C0 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 95145A8
    Verifying communication to device OK.
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.859 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.844 s
    CMT FLASH,NOR area [00020000-0007FFFF] erased in 2.453 s
    CMT FLASH,NOR area [00080000-000DFFFF] erased in 2.250 s
    CMT FLASH,NOR area [00100000-001FFFFF] erased in 6.000 s
    CMT FLASH,NOR area [00200000-0031FFFF] erased in 7.125 s
    CMT FLASH,NOR area [00320000-0105FFFF] erased in 1 min 21.016 s
    CMT FLASH,NOR area [01060000-01067FFF] erased in 0.844 s
    CMT FLASH,NOR area [01068000-0107FFFF] erased in 0.828 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    Programming completed in 1 min 0.704 s
    Processing PPM file: 3110c_TV_OK.ppm_v
    [BB5,BB5 ALGORITHM] size: 4.35 MB
    Erase size: 4.62 MB
    CMT FLASH,NOR area [01080000-0151FFFF] erased in 27.875 s
    Programming completed in 18.203 s
    Processing CNT file: 3110c_TV_OK.image_ora_pl_games_128_128
    [BB5,BB5 ALGORITHM] page size: 128 K size: 4.63 MB
    Erase size: 10.75 MB
    CMT FLASH,NOR area [01520000-01FDFFFF] erased in 1 min 20.250 s
    UCP page size is 128 K.
    Programming completed in 17.422 s
    Total time for flashing process(boot+erase+write) was 5 min 43.047 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdc\Nokia 3110 classic USB Phonet, PORT_ID: 2A084D3
    Phone type: RM-237 (Nokia 3110c)
    SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
    Imei plain: 35322503528874-1
    Product code: 0514949
    Battery voltage: 3721 mV, current: 102 mA
    Language Pack:
    - not available.
    SLPA ver[1]: PA_SL (15 digit NCK)
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 353225035288741
    Version: SIMLOCK SERVER VERSION 63
    Counter: 0/3, 0/10
    BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
    Market items is empty, please select the correct products path !
    Sống trên đời phải Tin và phải biết Tha thứ...
    Moderator TÚ CÒI's Avatar
    hà nội
    Dạng máy chưa mở mạng á
    repair SD-->SX nạp pm 01,309-->Update simlock nữa là ok
  3. ( TÚ CÒI ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    nguyễn kisu (23-09-2012)
    Thành viên chính thức ktvcuongnb's Avatar
    Mar 2010
    ca mau
    làm như bác tú còi ok đó
    Thành viên mới gà thế kỷ's Avatar
    mở tool crack JAF ra . tích vào BB5 tool . hiẹn ra mục unlock . cho máy vào infor rồi unlocker cái là donce đã làm nhìu với này rùi
    Feb 2012
    cái bè_tiền giang
    heyzzzzz bệnh chưa đụng tới nên chưa có kinh nghiệm ...em tìm hoài mà không thấy phần đó ...anh Tú Còi có thể hướng dẩn chi tiếc cho dùm em nha anh...em mới ra nghề sử dụng box chưa rành cho lắm ..chỉ biết lash thôi ..
    hà nội
    Bạn có mx đó
    Cần gấp thì liên hệ yahoo để mình giúp
    *Qua yahoo minhkhang_mobileangiang@yahoo.com mình làm cho...
  9. #8
    Vi phạm nội quy Hai_GSM_Pro's Avatar
    Hà Nội & Sài Gòn
    hiện mxkey đang lỗi sever ko sx4 dc
  10. #9
    Thành viên chính thức trinh_a7_2009's Avatar
    May 2011
    check cái cho qua unlock cái đc luon it con pai sx4 với write 1and 309
  1. Trả lời: 0
    Bài viết cuối: 19-07-2013, 22:52
  2. Trả lời: 2
    Bài viết cuối: 15-08-2009, 12:48
  3. Trả lời: 9
    Bài viết cuối: 31-12-2008, 21:33
  4. Trả lời: 12
    Bài viết cuối: 12-12-2008, 20:50
  5. 3120 gắn sim vào " hạn chế điện thoại"
    By kvmobile in forum DCT4 - WD2
    Bài viết cuối: 11-04-2008, 13:58
