Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\phoenix\Products\110i\rh93_06.400
Phone Type:
PPM Flash file: C:\Program Files\Nokia\phoenix\Products\110i\rh93_06.40md
Phone Type:
CNT Flash file: C:\Program Files\Nokia\phoenix\Products\110i\rh930_nai6.40md
Setting local mode...
Reading IMEI...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\phoenix\Products\110i\rh93_06.400
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x7E2A0100
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x7518; Loader chk: c6
Loader is ready...
MSID: 8418138741849649A4AC21D8CA
MSID decoded: 3E4EBAE900454B43A9000000
FAID: 555B02CFEE63A432B818C21B
Operation took 0 minutes 6 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 0 minutes 31 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: C:\Program Files\Nokia\phoenix\Products\110i\rh93_06.40md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 84346A818B0B40CB84918B691D
MSID decoded: 3E4EBAE900454B43A8000000
FAID: AD097166069A319DD7683AE4
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\phoenix\Products\110i\rh930_nai6.40md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013BFFFF...
Operation took 0 minutes 2 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 1 minutes 55 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Failed! Aborting!...IMEI
E lúc đầu chạy cũng như thế và máy đã lên nguồn -nhưng đc 1 lúc em lắp Sim vào máy thì lại bị contact sv!!!E đã làm lại Upp nhưng vẫn not ok!!!Anh nào biết chỉ giáo em với ạ!E thank trước nhé!E mới vào nghề ạ
