    Thành viên kỳ cựu dinhhieu444's Avatar
    ĐỒNG NAI
    Mặc định Xin giúp nokia 5530 lên rung hepl
    KHACH NÓI ĐANG SÀI RESET MÁY THẾ LÀ GIÒ BẬT CHỈ RUNG CÁI EM FLASH USB HWK RỒI VẪN VẬY , CHECK HWK BÁO LỖI , FLASH USB MX DONE KHÔNG ĐÒNG BỘ ĐƯỢC , FLASH FBUS MX VẪN VẬY FLASH Phoenix BÁO LỖI KHI CHỌN FILE
    LOG EM NÓ MX BOX
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0859F1D
    Using device: HTI, FW ver: 00.24, SN: 00010A5C
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14102(15-06-2012)
    Processing MCU file: RM-504_40.0.003_prd.core.C00
    [BB5,XSR 1.5] size: 105.24 MB
    Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 02200110BC810052F007D276DC47AD2E1256803A
    ASIC MODE ID: 00
    ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
    ROM ID: 4B9B75103E691FF8
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.2.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.2.0 revision: 2.0 size: 0x8B45D
    CMT PAPUBKEYS HASH: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning ...OK
    Erase size: 158.19 MB
    CMT FLASH,MuxOneNAND area [00040000-00082FFF]
    CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
    CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
    CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
    CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
    Formating partition ...
    Prog.status for Asic CMT ...
    NAND: OK
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: F2B05364 [RAP Certificate 168 v.1] sent
    CMT SOS*UPDAPP block sent
    CMT SOS*ENO block sent
    CMT SOS*DSP0 block sent
    CMT SOS*ISASW block sent
    CMT SOS+CORE block sent
    CMT SOS+ROFS1 block sent
    NAND: Status reported bad blocks.
    Programming completed in 4 min 54.765 s
    Processing PPM file: RM-504_40.0.003_prd.rofs2.V20
    [BB5,XSR 1.5] size: 17.87 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 32 MB
    CMT FLASH,MuxOneNAND area [07360000-0935FFFF]
    NAND: OK
    CMT SOS+ROFS2 block sent
    NAND: OK
    Programming completed in 51.250 s
    Processing CNT file: RM-504_40.0.003_C06_prd.rofs3.fpsx
    [BB5,XSR 1.5] size: 6.07 MB
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 11 MB
    CMT FLASH,MuxOneNAND area [09360000-09E5FFFF]
    NAND: OK
    CMT SOS+ROFS3 block sent
    NAND: OK
    Programming completed in 17.484 s
    Total time for flashing process(boot+erase+write) was 6 min 28.844 s
    LOG CHECK
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Selected firmware certificate matched.
    Original Imei: 35802203531911
    Original Product code: 0573249
    Bluetooth ID: 1886AC209CB3
    SIMLOCK PA identifier:
    [0] PA_SL3
    DINHHIEUMOBILE444 _ WELLCOM SỬA CHỮA ALL MOBILE
    444 TRẢNG BOM-ĐỒNG NAI : 0909613891
    ĐỒNG NAI
    LOG CHECK HWK
    1ST BOOT : C0,07 [Rm-504] [2.2.0.0]
    CMT ASICID: 000000010000022600010006400C192101051105
    EM 1 ID : 00000296
    EM 2 ID : 00000B22
    CMT PUBID : 02200110BC810052F007D276DC47AD2E1256803A
    CMT MODE : 00
    CMT HASH : B8C3ADECFC997FCD8081D3DEAF870B8C
    CMT ROMID : 4B9B75103E691FF8
    CMT 1ST Boot OK
    Cannot Find KEYS CERT
    BAD BOOT
    ERR: CMT 2ND Boot File not Found
    IMAGE : RM-504_40.0.003_prd.core.C00
    V.I.P DAKLAK-GSM's Avatar
    Aug 2010
    dòng này thiếu áp cấp cho cpu , ( nếu backup xóa full )chạy lại fw cao nhất, vê sinh sạch sẽ không thì dò sơ đồ xem sao bạn nhé, nhà lầu tính sau cùng
    127 quang trung . phước an. krongpak . daklak
    0982.419.419 yahoo. minhthien883
    ĐỒNG NAI
    Trích Được post bởi DAKLAK-GSM Xem bài viết
    chưa đồng bộ nên không bakup được , muc vesion cao nhất rồi giờ không được chắc upp không thay cặp qua
    Thành viên chính thức langbam's Avatar
    Mar 2012
    log mx thấy chưa đồng bộ được
    lỗi này đôi khi do cáp cũng có
    điều trước tiên back up full rồi flash không được box này thì chuyển box khác rồi tính tiếp
    rw thử rpl có chứa hwc_ccc\hwc_ccc xem có gì vui ko
    ĐỒNG NAI
    Trích Được post bởi QUỐC MẠNH Xem bài viết
    em chua thu nữa a co file up cho em múc thử xem sao lỡ rồi hiến xác cho khoa học làm chuột bạch luôn
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    Cứ từ từ mà làm,hôm trước gặp 1 con,chạy các kiểu vẫn rung...xoẹt phát. Chạy bằng phoenix thì lại đc
    ĐỒNG NAI
    làm mát trời luôn vẫn vậy đành trả khách hix thaks ae forum
  1. Trả lời: 2
    Bài viết cuối: 07-08-2013, 16:01
  2. C5-00 flash đủ kiểu chỉ lên rung hepl
    By dinhhieu444 in forum BB5
    Trả lời: 15
    Bài viết cuối: 04-12-2012, 19:16
  3. nokia 5530 lên nokia rồi tắt !!!
    By vinhbinh12a7 in forum BB5
    Trả lời: 13
    Bài viết cuối: 17-05-2012, 18:47
  4. Trả lời: 1
    Bài viết cuối: 17-01-2012, 19:52
  5. 5530 lên chữ NOKIA trắng rồi tắt
    By nguyendong_mobi in forum BB5
    Trả lời: 16
    Bài viết cuối: 19-11-2011, 12:26
