    Thành viên tích cực caokyit's Avatar
    Nov 2010
    468 Hùng Vương-Tam Kỳ - Quảng Nam
    Mặc định Nokia N8 chạy chương trình báo lỗi (Warning: Phone did not reboot to normal mode.) cần giúp gấp
    MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0874A13
    Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100AF22
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012)
    Processing MCU file: RM-596_111[1].040.1511_79u_prd.core.fpsx
    [BB5,XSR 1.6] size: 125.50 MB
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
    CMT EM0 ID: 00000C35
    CMT EM1 ID: 00000C30
    CMT PUBLIC ID: 27300218E77057405DFF59954344F1FBCE544B5E
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
    CMT ROM ID: E693EF0DAC22615B
    Loading CMT secondary boot code
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
    Update server code loaded.
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 37E070A8
    FUR: Adding Asic CMT as client OK.
    Reading CMT NPC (0x190 bytes).
    Reading CMT CCC (0x1D8 bytes).
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35623704706589_CE RT.rpl).
    CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231
    Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 228.06 MB
    CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
    CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
    CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF]
    Formating partition ...
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT SOS+PMML block sent
    CMT SOS+DECOMP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent
    CMT GENIO_INIT block sent
    CMT SOS+IVE3A block sent
    CMT SOS*UPDAPP block sent
    CMT SOS*DSP0 block sent
    CMT LDSP block sent
    CMT SOS*ISASW block sent
    CMT SOS+CORE block sent
    CMT SOS+ROFS1 block sent
    Programming completed in 26.250 s
    Processing PPM file: RM-596_111[1].040.1511_19.01_Vietnam_79u_prd.rofs2.fpsx
    [BB5,XSR 1.6] size: 22.61 MB
    Erase size: 64.25 MB
    CMT FLASH,MuxOneNAND area [09A40000-0DA7FFFF]
    CMT SOS+ROFS2 block sent
    Programming completed in 5.157 s
    Processing CNT file: RM-596_111[1].040.1511_U03.01_79u.uda.fpsx
    [BB5,XSR 1.6] size: 119.13 MB
    Erase size: 262 MB
    CMT FLASH,MuxOneNAND area [0EA00000-1EFFFFFF]
    Programming completed in 19.625 s
    Total time for flashing process(boot+erase+write) was 1 min 6.266 s
    Phone not found, retrying ...
    mang qua box khác múc thử xem sao...
    Mar 2012
    nam định
    mag qua phoenix chạy lại xem.mx box cà tứng gặp mấy con đời cao nhăn răng ra
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
    Sóc Sơn - Hà Nội
    con này lỗi không thể khởi động lại để đồng bộ ! máy lúc đầu làm sao hả bác ? dòng này em backup full rồi toàn cho vào phoenix chiến chưa đầy 5p' ok !!!!
    Nov 2010
    máy lúc đầu lâu lâu reset bạn ơi!mình cho vào mxbox flast báo lỗi giờ mở nguồn không lên luôn. mình mang qua phoenix thì đến khi chọn file là nó báo lỗi,giờ sao phải làm sao đây mấy ae
    Mar 2012
    nam định
    reset thì cần gì phải flash lại. lấy dây usb chọn file mcu rồi buschek
    +đồng bộ là dk
    phoenix chọn file lỗi là sao. load cả bộ file trên navifimwar về xem nó có báo lỗi nữa ko
    Mar 2012
    nam định
    phoenix mà ko dk thì mang qua best toll
  1. x2-01 chạy phần mềm lỗi: Warning: Phone did not reboot to normal mode cần giúp
    By caokyit in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 10-08-2014, 18:02
  2. Trả lời: 5
    Bài viết cuối: 20-10-2012, 12:36
  3. Trả lời: 0
    Bài viết cuối: 22-06-2011, 06:45
  4. Trả lời: 2
    Bài viết cuối: 19-11-2010, 15:56
  5. ko vào được chế độ local mode hoặc tét mode
    By dongxoai mobile in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 19-09-2009, 20:32
