mình vừa nhận 5310 lên nguôn khởi động máy không cần thể sim , chấp nhận rồi bị contact service rồi tắc , em vừa chạy lại không biết báo lỗi gì . nhờ anh em giúp đỡ thanks .
Version from phone: 07.97
Version from file: 07.97
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C08747B1
Using device: HTI, FW ver: 00.24, SN: 00015137
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
Reading RPL backup ...
Reading Phone IDs ...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 07B0010D35407E56202708947C5C472CEE8A7575
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage2: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
Algorithm: RAP3Gv30_XSR14_alg.fg [BB5 ALGORITHM] version: 11.34.0 revision: 3.0 size: 0x81324
CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
PRIVATE ID: 1E2092AF41A9118BBA276589C4C43F18D989F419
E-FUSE: C5D5525E
SEC ROM CRC: DFAAF68F
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
eBB5ProtocolType: OLD
Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Flash Imei: 35605303839917
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35605303839917_BA CK.rpl"
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Processing MCU file: rm495__07.97.mcusw
[BB5,BB5 ALGORITHM] size: 18.20 MB
Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [00140000-0137FFFF]
CMT FLASH,NOR area [01380000-0151FFFF]
erased in 1 min 36.875 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 0C917F11 [RAP Certificate 164 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 29.250 s
Processing PPM file: rm495__07.97.ppm_v
[BB5,BB5 ALGORITHM] size: 7.71 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF]
erased in 41.156 s
NOR: OK
NOR: OK
Programming completed in 36.906 s
Processing CNT file: rm495__07.97_002.image_v_ctv_vn_9D1D9
[BB5,BB5 ALGORITHM] page size: 128 K size: 12.89 MB
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF]
CMT FLASH,NOR area [02160000-03FBFFFF]
erased in 2 min 6.156 s
NOR: OK
NOR: OK
Programming completed in 1 min 10.344 s
Total time for flashing process(boot+erase+write) was 8 min 8.156 s
Phone type: RM-495 (Nokia 5130c-2)
SW version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 35605303839917-5
Product code: 059D1D9
Battery voltage: 3470 mV, current: 19 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
Camera config: NIMMIIIIRRFF094B2F01, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
