Khách đưa vào bị chớp tắt, em chạy bằng mxbox
nhờ anh em xem giùm em cái log xem nó bị gì ko?
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C08746E3
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100D1C5
Connection status: UHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
Processing MCU file: rm343_510.21.009_prd.c00
[BB5,XSR 1.5] size: 68.80 MB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 07C0001408B98B52A8C94C0DF8A958702FEC79E1
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 122.56 MB
CMT FLASH,MuxOneNAND area [00040000-007FFFFF]
CMT FLASH,MuxOneNAND area [00A00000-0759FFFF]
CMT FLASH,MuxOneNAND area [0F1C0000-0F8BFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 96B8EDD5 [RAP Certificate 102 v1] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS*CORE block sent
CMT SOS+ROFS block sent
Programming completed in 19 min 24.250 s
Processing PPM file: rm343_510.21.009_prd.v17
[BB5,XSR 1.5] size: 20.77 MB
Erase size: 33.56 MB
CMT FLASH,MuxOneNAND area [05420000-0759FFFF]
CMT SOS+ROFX block sent
Programming completed in 6 min 3.703 s
Processing CNT file: RM343_ENO_0741.10_08wk42.a26.fpsx
[BB5,XSR 1.5] size: 1.54 MB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 400C192101031103, 4003192101031103, 4003192101051103, 400C192101051103
Erase size: 64 KB
APE SOSENO
CMT SOS*ENO block sent
Programming completed in 26.954 s
Processing CNT file: dawn_erase_y_drive.fpsx
[BB5,XSR 1.5] size: 236 Bytes
Erase size: 1.62 MB
CMT FLASH,MuxOneNAND area [0F020000-0F1BFFFF]
Programming completed in 0.000 s
Processing CNT file: rm343_510.21.009.09U
[BB5,XSR 1.5] size: 21.55 MB
Erase size: 64 KB
Programming completed in 6 min 17.750 s
Total time for flashing process(boot+erase+write) was 32 min 33.843 s
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3B6AB29E
Device connected: nmwcdc\Nokia E66 USB Phonet, PORT_ID: 2DDA70FF
Open device failed: FFFFFFFF (4) The system cannot open the file
Warning: Phone did not reboot to normal mode.
Hiện nó vẫn lên nhưng mà cứ chớp tắt màn hình, em đã up ver cao nhất.
