mới nhận em 1200 chạy chậm đem flash lại thì ko đồng bộ dc, chạy ko hết file cnt và báo lỗi . đem qua hwk, jaf rồi vẫn ko dc, xóa full flash lại rồi, đóng lại U,lắc UEM, FLASH rồi vẫn vậy. ae xem dùm
MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0872970
Using device: HTI, FW ver: 00.50, SN: 0100D05E
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: 8508 100A 0224 0122 1C50 4980 0922 6404
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
UEM ID: 00823DADA3BDA66
ASIC type: 11
UEM Imei: 35641302271758
Flash Imei: A99AA44AC1DCD1
Invalid imei checksum !
Processing MCU file: rh99_05.230
[DCT4,DCT4 ALGORITHM] size: 2.26 MB
Supported Ids: 2292
UEM ID: 00823DAD:2984DA60
Area [01000000-0100FFFF] erased in 0.578 s
Area [01010000-013AFFFF] erased in 32.937 s
Area [013B0000-013EFFFF] erased in 2.391 s
Area [017C0000-017EFFFF] erased in 0.032 s
Area [01FC0000-01FEFFFF] erased in 0.031 s
Flash programming ...
Programming completed in 19.812 s
File processed in 1 min 3.094 s
Processing CNT file: rh990_nai5.23mr
[DCT4,DCT4 ALGORITHM] size: 110.54 KB
Supported Ids: 2292
Area [01380000-013AFFFF] erased in 1.703 s
Programming completed in 0.984 s
Content extract fail, continue anyway ...
File processed in 1 min 35.734 s
Processing PPM file: rh99_05.23mr
[DCT4,DCT4 ALGORITHM] size: 1.12 MB
Supported Ids: 2292
Area [01240000-0124FFFF] erased in 0.515 s
Area [01250000-0137FFFF] erased in 11.047 s
Programming completed in 9.828 s
File processed in 28.672 s
Total time for flashing process(boot+erase+write) was 3 min 7.500 s
A3BDA66
