Kết quả 1 tới 10 của 12
    Thành viên chính thức mr.trungmobile's Avatar
    Mar 2012
    Mặc định 3110c bi ma han che
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 294001142ED87E56CD5CBEDCE255D746BD235DC4
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
    TransmissionMode: DDR&TX2
    Erasing CMT NPC ... OK
    Updating WARRANTY ...error 0x0
    Updating PROD ...error 0x0
    Updating BT ...error 0x0
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C085E842
    Using device: HTI, FW ver: 00.50, SN: 01006B65
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x]
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Updating CMT NPC ...OK
    Updating CMT CCC ...OK
    Updating CMT HWC ...OK
    Prog.status for Asic CMT ...
    NOR: OK
    Phone type: RM-237 (Nokia 3110c)
    SW version: V 07.21 05-11-08 RM-237 (c) Nokia.
    Imei plain: 12345610654321-?
    Product code: 0552816
    Battery voltage: 4806 mV, current: 60 mA
    Language Pack:
    - not available.
    SLPA ver[1]: PA_SL (15 digit NCK)
    SIMLOCK seems to be valid
    SUPERDONGLE_KEY invalid!
    - WD timer enabled, phone will reboot itself after 3 min.
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Imei plain is invalid !!!
    Imei net: 12345610654321?
    Version: SIMLOCK SERVER VERSION 63
    Counter: 0/3, 0/10
    CONFIG_DATA: FFFFFFFFFFFFFFFF
    PROFILE_BITS: FFFFFFFFFFFFFFFF
    BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    SIMLOCK_TEST passed
    Counter: 0/3, 0/10
    Repair SD-unlock-SX4-Write pm. Từng bước mà làm
    Vào Repair SD xong rồi>>>Super SD + Write PM 1&309 + Reset All = Done
    Thành viên chính thức mjnhtuan123's Avatar
    Nov 2010
    Language Pack:
    - not available.
    ime đep rồi làm gì nữa,thay căp đi
    Moderator Thuyết Vũ's Avatar
    Gia lai
    còn backup thì restore cho nó cái imel rồi làm theo các bác kia ! ko thì thay cặp khác nhé!
    Iphone Shop Thu Vân-sửa chữa apple Chuyên Nghiệp
    507 Nguyễn Huệ Núi Sập Thoại Sơn An Giang.YM: phong_vugl mobile: 0974444438
    Tài Khoản Vietcombank Gia Lai chủ tài khoản : Vũ Tiến Thuyết 0291002263263
    V.I.P BinhMinhGSM's Avatar
    Apr 2008
    Vĩnh Long->Đà Nẵng
    các bác chẳng chú ý gì cho chủ topic.imei lung linh thì có bk cứu đc,k thì change cặp,chứ repair gì nữa?
    Moderator TÚ CÒI's Avatar
    hà nội
    thuyet_mobile
    NguyểnKhangMobile™
    V.I.P
    Có imei đâu mà repari với cả SX vậy
    Trích Được post bởi TÚ CÒI Xem bài viết
    thuyet_mobile
    NguyểnKhangMobile™
    V.I.P
    Trích Được post bởi BinhMinhGSM Xem bài viết
    Em chỉ coi log ở dưới mà không để ý tới imei ... cho em xin lổi
    Apr 2008
    Ku kòi mắt tinh dữ ???
    Mar 2012
    nam định
    12345...?. ko backup thì 1 cặp
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
