Superboot - how to root the HTC Desire C
Introducing.... Superboot!
Superboot is a boot.img that when booted, will root your device the first time you boot (installing su and the superuser APK). No need to flash any partitions, no need to mess around with ADB, no messing with the contents of your data partition, no overwriting the shipped ROM on your device, just boot the boot image using the instructions below and you're done!
APPLY THIS AT YOUR OWN RISK!
The superboot image is also 'insecure', allowing you to use 'adb remount' as well as having full ADB root access to your device until such time as you reboot after running this process (it's a non permanent ADB root as it's a 'fastboot boot' and not a 'fastboot flash').
- Superboot r1 - DOWNLOAD (ROMraid) - MD5: 577610795783761d56b95e024793b8cf
How to use Superboot - Windows, Linux and OSX
- Download the Superboot zip file above and extract to a directory
- Put your device in bootloader mode - Turn off the phone then turn on with the 'volume up' and 'volume down' buttons both pressed to enter the bootloader (as pictured below)
- WINDOWS - double click 'install-superboot-windows.bat'
- MAC - Open a terminal window to the directory containing the files, and type 'chmod +x install-superboot-mac.sh' followed by './install-superboot-mac.sh'
- LINUX - Open a terminal window to the directory containing the files, and type 'chmod +x install-superboot-linux.sh' followed by './install-superboot-linux.sh'
Original link
Note: If you are using a retail device, you need to unlock your bootloader via HTCdev first!
Download Hxc pro Tool V3.17
More Updates are on the way
Br
Faisal_Computer
We Need Good Supporters for HXC Dongle. if you interest & you think you can Handle HXC Dongle section please send me pm
			 [ HXC Pro Tool V3.17 ] Added HTC Desire C, HTC Golf
