Kết quả 1 tới 4 của 4
    Thành viên mới TANKHUNGKONTUM88's Avatar
    Mặc định 6230i chạy pm báo lỗi cần giúp
    *** lên chơpf tắt lúc được lúc không chay lai thi đến như log bên dưới đứng im anh em xem dùm mình với thankk all
    Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.880
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.88A
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.88.ucp_A
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.880
    Booting phone...
    MCU ID: 0x2051
    BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
    Boot size is 0x2398
    Boot is ready...
    FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
    FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Flash ID is 0x22E800EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
    Loader size is 0x84A0; Loader chk: 4c
    Loader is ready...
    MSID: 84659DB2EA1D99DA2CDED8FFC0
    MSID decoded: 91DFBAE900081278A8000000
    FAID: E0439BC80E85957DE4791169
    Operation took 0 minutes 18 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 009FFFFF...
    Error erasing area: 001F0000 - 0020FFFF
    kiểm tra lại cáp, vẫn not ok thì cho vô MX rồi đưa cái log buscheck lên coi sao
    Mar 2012
    nam định
    chuyển box kahcs flash lại
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
    cho vào HWK thì thế nay` đây các bác
    1st Boot: Ok, TIKU, UPP: 2051 [Rm-72] [2.2.0.2]
    2nd Boot: te_2nd.fia, Ver: 4.76.0
    Fl0: 0x00000000-0x00FFFFFF,00EC22E8,Sam K8S2815ETB
    Fl1: 0x02000000-0x03FFFFFF,00EC0010,Sam OneNAND256
    Algorithm: te_amd_b.fia, Ver: 4.76.0
    Algorithm Ok, MSID: 84659DB2EA1D99DA2CDED8FFC0
    Decoded MSID: 91DFBAE9-00081278-A8000000
    Encoded FAID: E0439BC8-0E85957D-E4791169
    IMAGE: rm72_73_11003.880
    Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00
    Erasing: 0x00010000-0x009FFFFF ...
    Erasing Error: 6, at: 0x00200000-0x0021FFFF, Time: 00:49
    con HTI MXkey thi Mất nguồn không nhận
  1. 6230i chạm nguồn cần giúp
    By bbtrangmobile in forum DCT4 - WD2
    Bài viết cuối: 19-11-2014, 07:01
  2. xin giúp 6230i chạy phần mềm báo lỗi
    By thuan_dth in forum DCT4 - WD2
    Bài viết cuối: 08-09-2011, 10:38
  3. 6230i chạy báo lỗi
    By bomngoc in forum DCT4 - WD2
    Bài viết cuối: 26-12-2009, 10:19
  4. 6230i chạy chương trình lăn ra chết
    By tranquoctan2007 in forum DCT4 - WD2
    Bài viết cuối: 20-02-2008, 08:51
  5. 6230i chạy chương trình ko dc
    By nguyenhai2310 in forum DCT4 - WD2
    Bài viết cuối: 24-09-2007, 21:40
