đây là log flash bằng mx MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C08747FC
Using device: HTI, FW ver: 00.50, SN: 0100C15D
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
UEM ID: 0093F69AA3BDA66
ASIC type: 11
UEM Imei: 35684502208981
Flash Imei: 35684502208981
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\3568450220898 1_BA CK.rpl"
Processing MCU file: rh99_05.230
[DCT4,DCT4 ALGORITHM] size: 2.26 MB
Supported Ids: 2292
UEM ID: 0093F69A:2984DA60
Area [01000000-0100FFFF] erased in 0.563 s
Area [01010000-013AFFFF] erased in 31.860 s
Area [013B0000-013EFFFF] erased in 2.469 s
Area [017C0000-017EFFFF] erased in 0.047 s
Area [01FC0000-01FEFFFF] erased in 0.031 s
Flash programming ...
Programming completed in 20.641 s
File processed in 1 min 3.140 s
Processing CNT file: rh990_nai5.23mr
[DCT4,DCT4 ALGORITHM] size: 110.54 KB
Supported Ids: 2292
Area [01380000-013AFFFF] erased in 1.657 s
Programming completed in 1.078 s
Content extract fail, continue anyway ...
File processed in 38.157 s
Processing PPM file: rh99_05.23mr
[DCT4,DCT4 ALGORITHM] size: 1.12 MB
Supported Ids: 2292
Area [01240000-0124FFFF] erased in 0.563 s
Area [01250000-0137FFFF] erased in 10.563 s
Programming completed in 10.297 s
File processed in 29.046 s
Total time for flashing process(boot+erase+write) was 2 min 10.343 s
em chưa làm gì cả xin chỉ giáo
