Kết quả 1 tới 10 của 10
    Thành viên chính thức duongphuchoang's Avatar
    Mặc định anh em xem giúp co bi lổi đâu không mà cứ vào hộp thư đến là tắt nguồn
    Card life counter: 99.99%
    FBUS INTERFACE NOT CONNECTED!!!
    USB Cable Driver version: 7.1.69.0
    Changing mode...Done!
    Detected P-KEY: 9000AAC9
    Init usb communication...
    Found
    Init usb flashing...
    Reading flashid... 128k flash detected.
    CMT: 220800EC <=> SAMSUNG (SEC) -> K8F5615ETM/K5G5629ATD
    APE: 00000000 <=> Flash -> not detected
    Done!
    Searching for phone...Detected P-KEY: 9000AAC9
    Found
    MCU SW version: V 07.30
    07-05-09
    RM-217
    (c) Nokia.
    HW version: 0614
    PCI version:
    RFIC version:  17211721
    DSP version:
    ICPR61_08w10
    PPM version: V 07.21
    05-11-08
    RM-217
    (c) Nokia.
    V
    BT MCM version: 06cc-P9.1
    Retu version: 32
    Tahvo version: 53
    Content Pack version: Content: b_black
    V 07.30
    07-05-09
    RM-217
    (c) Nokia.
    Production serial number: CMI678229
    Product code: 0554579
    Module code: 0203166
    Basic production code: 0555543
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 358288038595897
    IMEI spare to net: 3A 85 82 08 83 95 85 09
    IMEI SV to net: 33 85 82 08 83 95 85 29 F7
    LOCK STATUS:
    CONFIG KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Loading INI list...
    Reading product code...
    Product Code: 0554579
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\
    Checking path: C:\Program Files\Nokia\Phoenix\Products\Products\RM-217\
    Scanning ini files...
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.ppm_b
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.30.image_b_black
    APE Variant file: NONE
    Languages in ppm: English,German,French,Polish,Romanian,Hungarian
    Done!
    Thành viên mới codonmotvisao_2212's Avatar
    log nay ổn mà.bạn chay lại đuôi ppm_v xem.xong pormat pactory cho nó cái thữ xem
    tuan mobile 0983.732.391-0979.260.686
    có khi nao sim của khách co tin nhắn tăt nguôn không bác nhỉ em chay đu kiêu rồi mà trả khách về dùng nó lại bảo vào tin nhắn là tắt nguồn!
    Thành viên tích cực ATmobile_qn's Avatar
    Aug 2011
    Flash lun cho em nó phát đi bạn
    Yahoo:thanhtruyenmobile ĐT: 0989 413 413
    phoenix dead usb jaf e đả flash cả rồi bác! e thấy lock ôn các bác xem lock lôi gi ko ý kiến e vởi
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    bạn còn box nào nữa thì đem ra flash lại cho nó đí bạn ..bệnh đó thì lỗi sw thôi
    V.I.P Lão_Đại's Avatar
    hải phòng
    (có khi nao sim của khách co tin nhắn tăt nguôn không bác nhỉ em chay đu kiêu rồi mà trả khách về dùng nó lại bảo vào tin nhắn là tắt nguồn!)
    Tại sao không thử sim khác
    Trường hợp này bạn Downgade ver 7.21 chắc OK
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    reset all cái coi sao rồi chạy chọt sau
    Thành viên tích cực LongMy_Mobile79's Avatar
    Feb 2012
    kô biết sao chứ hôm bữa mình khôi phục cài đặt góc cái là ok hà
    0917752979_new member
    ok rồi may bác. flash đả đời không được bực bội đá u phát đươc nun! hì
