Kết quả 1 tới 10 của 11
    Thành viên tích cực LongMy_Mobile79's Avatar
    Feb 2012
    Mặc định 101 thay cặp x1
    101 bị lỗi cặp..em thay cặp x1 qua nhưng ct không đồng bộ được ...chạy file 101 hay x1 bác...log em nó chạy file 101 nhưng khong đồng bộ được.....
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0871D8F
    Using device: HTI, FW ver: 00.50, SN: 0100B1EC
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.24
    EBL version: Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbit/s
    Flash ID: 00EC 2404 - 23280002 [Samsung K5N2833ATM,128 Mbits]
    CFI information:
    Flash settings: 0/1, size: 0x01000000
    2 Block regions:
    255 x 0x00010000 = 0x00FF0000
    8 x 0x00002000 = 0x00010000
    EBL ready !
    Processing file: rm769_006.650
    Downloading item CODE:hw_f3_rm769_r06.650.fls, num block: 3, size: 5.58 MB
    Erasing area 0x00000000-0x00005FFE ...OK
    Programming completed in 0.578 s
    Erasing area 0x00800000-0x00BEFFFE ...OK
    Programming completed in 1 min 17.313 s
    Erasing area 0x00C5D000-0x00DFB6FE ...OK
    Programming completed in 31.843 s
    Checksum verified (0x5824)
    Processing file: rm769_006.65mr
    Downloading item CUST:hw_f3_rm769_006.65mr.fls, num block: 1, size: 5.07 MB
    Erasing area 0x00100000-0x006109FE ...OK
    Programming completed in 1 min 39.516 s
    Checksum verified (0x0D4B)
    Processing file: rm7690_nai06.65mr
    Downloading item CUST:hw_f3_rm7690_nai06.65mr.fls, num block: 1, size: 700.58 KB
    Erasing area 0x00E60000-0x00F0E53E ...OK
    Programming completed in 13.547 s
    Checksum verified (0xD33E)
    Total time for flashing process(boot+erase+write) was 5 min 41.843 s
    0917752979_new member
    Feb 2012
    up upu up ae trả lời em với
    PHÚ ĐIỀN-TÂN PHÚ-ĐỒNG NAI
    x1 thay 101 thì nghe nói ok đó ,còn 101 thay ngược cho x1 thì ko pit thế nào ,chủ thớt thử dùng box khác flash lại xem sao
    yahoo :nhathuy_mobile2009
    Thành viên tích cực thuy1986's Avatar
    thử rồi nhưng không được do main lỗi ? thay x1 sang 1280 thấy ok
    0977 331 786 yahoo :tinhcodon_phuong TK 220 720 511 1155
    Thành viên tích cực BacLieuGMS's Avatar
    Bạc Liêu
    sài ko dc flas ko dc đúng rùi
    Yahoo:baclieutieusai
    Super Moderator tuanhoang's Avatar
    Sep 2007
    có khi lỗi main từ đầu ,lấy cặp 101 từ đầu đó cất để dành test sau !
    TRUNG TÂM SỬA CHỮA DTDD TUẤN HOÀNG - GIA TÂN 1-THỐNG-NHẤT-ĐỒNG NAI-QL-20
    Chuyên SW & HW all Mobile -LH_ ĐT:0613778888-3867722-0902442220-0966907790
    Bank-plus Cua VT:9990110214707_Vũ Tiến Hoàng : NH Agribank số TK:5915205023902
    Feb 2012
    em làm mãi mà kô đc...chạy cỡ nào cũng kô cho đồng bộ
    Thành viên chính thức Duc Thuan GSM's Avatar
    Jul 2011
    Phú Thứ Tiên Hiệp Phủ Lý Hà Nam
    ko đồng bộ dc đâu e thử làm rồi not ok
    Lời Nói Chẳng Mất Tiền Mua _ Lựa Lời Mà Nói Cho Nòi Tiền Ra
    Jul 2011
    a thử back up pm lay rpl thay con flats khac xem wrie rpl va file pm cua máy chạy phần mềm vào nhớ bỏ file 302 nhé ko mất inmei
    Feb 2012
    nó có info đc đâu mà wire zí backup
  1. Trả lời: 9
    Bài viết cuối: 08-10-2013, 09:05
  2. Trả lời: 5
    Bài viết cuối: 07-10-2011, 10:36
  3. Trả lời: 8
    Bài viết cuối: 28-07-2011, 09:01
  4. Sam sung thay cpu có thay flash ko
    By tranhoanggiang57 in forum Các loại máy khác của Samsung
    Bài viết cuối: 22-05-2011, 20:36
  5. Trả lời: 6
    Bài viết cuối: 21-07-2009, 15:39
