em mới nhận 1 cây 2700 tình trạng của nó là như này.
bật nguồn lên hiện cài đặt ngày và giờ rồi trắng màn tắt luôn.
e đã chạy lại phần mềm vẫn vậy.đây là log của nó
Version from phone: 09.98
Version from file: 09.98
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C086CF06
Using device: HTI, FW ver: 00.50, SN: 00016ECA
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35153204496407_BA CK.rpl).
Processing MCU file: rm561__09.98.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1970020CA7C746503C0B4C240268272F2F38CADD
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
eBB5ProtocolType: OLD
Storage0: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
TransmissionMode: DDR&TX2
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [00140000-0137FFFF]
CMT FLASH,NOR area [01380000-0151FFFF]
erased in 1 min 13.000 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 36.641 s
Processing PPM file: rm561__09.98.ppm_x
[BB5,BB5 ALGORITHM] size: 6.91 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF]
erased in 27.125 s
NOR: OK
NOR: OK
Programming completed in 36.437 s
Processing CNT file: rm561__09.98_008.image_x_ctv_id_v2_96897
[BB5,BB5 ALGORITHM] page size: 128 K size: 14.27 MB
NOR page size in the phone is 128 K.
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF]
CMT FLASH,NOR area [02160000-03FBFFFF]
erased in 1 min 27.828 s
NOR: OK
Converting UCP blocks to 128 K.
NOR: OK
Programming completed in 1 min 10.531 s
Total time for flashing process(boot+erase+write) was 7 min 13.953 s
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35153204496407-7
Product code: 0579808
Battery voltage: 4599 mV, current: 6 mA
Language Pack:
- not available.
Camera config: NIMMIIIIRRFF094B2F01, ver: 002.014
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351532044964077
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
và e Buz Check nó báo như này
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Selected firmware certificate matched.
Original Imei: 35153204496407
Original Product code: 0579808
Bluetooth ID: 3CF72A4FC358
SIMLOCK PA identifier:
[0] PA_SL3
Battery voltage: 4650 mV, current: 9 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
