ddasdasdas
    Mặc định PEGASUS BOX 1.2.9 - really massive update!
    PEGASUS BOX 1.2.9 IS OUT!
    As you remember Pegasus Team was the first to released "no patch/flash mode" solution for Swift phones. So here is the next revolutionary update for this platform.
    PEGASUS BOX 1.2.9 RELEASE NOTES:
    • E1200 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1200M - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1200T - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1205L - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1202 - world's first super fast Unlock Code Reading/Unlock/Primary IMEI Repair/Secondary IMEI Repair/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1085L - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1086L - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1086i - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1086il - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1080 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1080f - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1080i - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1080w - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1050 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1150 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1150i - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1153 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1155L - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1170 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1170i - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1170t - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1172 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1180 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1190 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1195 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • C3330 - Read Unlock Codes/Unlock/Repair IMEI/Write Firmware/Convert Original Firmware
    • C3312 - Read Unlock Codes/Unlock/Primary IMEI Repair/Secondary IMEI Repair/Write Firmware/Convert Original Firmware
    • S5839I - Read Unlock Codes/Unlock/Repair IMEI
    • S5270K - Read Unlock Codes
    • I827 - Direct Unlock/Repair IMEI
    Download Pegasus Box v1.2.9
  2. ( Lính Khang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    trankimhong (12-11-2012)
  1. Samsung Tool 14.7 & 14.8 Update. Massive Update.ZRoot.New phones. First in the world
    By hungphongmobile™ in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 21-06-2013, 21:06
  2. Polar Box Update V 3.21 Ready [MASSIVE UPDATE INSIDE]
    Bài viết cuối: 26-04-2013, 14:01
  3. Medusa Box v1.3.3 - massive update!
    Bài viết cuối: 13-01-2012, 22:33
  4. Pegasus Box v1.0.4 - massive update!
    By GIALAI_GSM in forum Pegasus Box
    Bài viết cuối: 31-05-2011, 22:47
  5. Octopus Box massive update - V1.2.0 is out!
    By TuấnPhát_GSM in forum Octopus/Octoplus Box
    Bài viết cuối: 16-03-2010, 19:11
