Hồi sáng e nhận khách cây N70 bị trắng màn hình treo, e câu kéo hết rồi nhưng ko dc, e bỏ vào MX check thì ko có vấn đề gì nhưng khi flash thì lại bị lỗi.... ae xem log rồi giúp e với....tks ae nhìu....
Version from phone: 05wk07v48.1
Version from file: 50737301.c0
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C087ABBF
Using device: HTI, FW ver: 00.24, SN: 00015BBA
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012)
Reading RPL backup ...
Reading Phone IDs ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1DC001172316565150E5E237622BAEAA6D1FD880
ASIC MODE ID: 00
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FCEA7B19D
SecondaryBoot: RAP3Gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
eBB5ProtocolType: OLD
PRIVATE ID: 3A4CB7B7E0FCD6C0CBAEF2EB9AF6914CC5E228E0
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Storage0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
TransmissionMode: DDR&TX2
Reading CMT VARIANT (0x4E9 bytes).
Reading CMT CCC (0x0 bytes).
Reading CMT HWC (0x0 bytes).
Reading CMT R&D (0x0 bytes).
Flash Imei: 35186301539436
NPC_DATA saved OK
VARIANT_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35186301539436_BA CK.rpl"
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Processing MCU file: rm84_50737301.c0
[BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 29.41 MB
Supported Ids: 17100701, 17100702
Partitioning ...OK
Erase size: 68.92 MB
CMT FLASH,NOR area [00000000-0052B515]
CMT FLASH,NOR area [006A0000-006BFFFF]
CMT FLASH,NOR area [006DF000-006EFFFF]
CMT FLASH,NOR area [00700000-007EFFFF]
erased in 39.391 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 0F72BF9D [Rap certificate3] sent
Error while programming [01] at 0x00000000, Result: 0000
