MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C087AD77
Using device: HTI, FW ver: 00.50, SN: 0100A342
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0790000A7D9A005243D3E25F205485239E6F414F
ASIC MODE ID: 00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
CMT PAPUBKEYS HASH: 96B8EDD55BE6A0011D2BA3B5A4D8D82F58BBFD93
Original Imei: 35154904420215
Original Product code: 0575707
Bluetooth ID: 20D6075DECB3
SIMLOCK PA identifier:
[0] PA_SL2
[1] PA_SL3
Phone type: RM-343 (Nokia E66)
SW version: V ICPR71_09w47.10 20-01-11 RM-343 (c) Nokia
Imei plain: 35154904420215-9
Product code: 0566412
Battery voltage: 4692 mV, current: 19 mA
ApeCoreSw: 510.21.009
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351549044202159
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
máy lên nokia nháy nháy mất nguồn
