ae coi giúp e cái log con này xem nó bị làm sao.máy tình trang ban đầu ko lên nguồn đã thay thử cáp+màn chạy lại báo vậy, bi giờ khởi động lên màn tối thui MCU ID: 0x2292
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Phone Type:
Phone Type:
MCU Flash file: C:\Documents and Settings\Administrator\Desktop\rh105_06.000
Phone Type:
PPM Flash file: C:\Documents and Settings\Administrator\Desktop\rh105_06.00mr
Phone Type:
CNT Flash file: C:\Documents and Settings\Administrator\Desktop\rh1050_nai6.00mr
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Documents and Settings\Administrator\Desktop\rh105_06.000
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
Loader size is 0x5548; Loader chk: d9
Loader is ready...
MSID: 849B83E3BA7C28D01B376A41C7
MSID decoded: 3E4EBAE9009698B3A8000000
FAID: 0EF11C050DDF34EAE253E60C
Erasing...
Found 5 interval(s) to erase
Operation took 0 minutes 34 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 19 seconds...
Restarting MCU...
PPM: C:\Documents and Settings\Administrator\Desktop\rh105_06.00mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
First 16 bytes: 00 89 88 72 00 01 01 21 00 89 BF CF 00 01 00 01
Loader size is 0x5548; Loader chk: f9
Loader is ready...
MSID: 84C2A917C2F6D83BABE51EF93C
MSID decoded: 3E4EBAE9009698B3AA000000
FAID: E788C83627CD83003E96F7EA
Erasing PPM...
Found 2 interval(s) to erase
Writing...
Error cmd: 14!
Addr: 01240000
			 log 1208 cần giúp
 log 1208 cần giúp
