Kết quả 1 tới 2 của 2
    Thành viên tích cực KIÊN NGUYỄN MOBILE's Avatar
    Feb 2010
    TP HCM
    Mặc định ACE coi dùm cái log E72
    ACE coi dùm em cái coi nó còn cứu vớt được không , đây là log của em nó MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C084B543
    Using device: HTI, FW ver: 00.24, SN: 00010AEA
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
    CMT Data :
    SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPUYAMA ver: 1.1]
    EM0 ID: 00000C34
    EM1 ID: 00000C30
    PUBLIC ID: 1C30020FB28C034487AC0462D124C9E355341B14
    ASIC MODE ID: 00
    ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
    ROM ID: 3E273BF637BE26FA
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B40
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 3.0 size: 0xD4029
    CMT PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E
    Original Imei: 35378404767387
    Original Product code: 0598498
    Bluetooth ID: 303855E5993C
    SIMLOCK PA identifier:
    [0] PA_SIMLOC30
    Phone type: RM-530 (Nokia E72-1)
    SW version: V ICPR82_11w16.3 19-05-11 RM-530 (c) Nokia
    Imei plain: 35378404767387-8
    Product code: 0599641
    Battery voltage: 4329 mV, current: 0 mA
    ApeCoreSw: 071.004
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    SUPERDONGLE_KEY[MX] seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Imei net: 353784047673878
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    đã backup được PM full mà khi Write thì báo lỗi vùng 309 bác nào có cách khác phục thì giúp mình cái nha
    Nó bị Contact Service hay bị gì vậy bạn,thử Super SD + Write 1&309 rồi reset all cho em nó coi hết không,not ok thì đem qua HWK hay MT-Box sử em này ngọt như mía
  3. ( Lính Khang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    KIÊN NGUYỄN MOBILE (12-11-2012)
  1. Anh em xem dùm con 6085 bus check bị lỗi gì dùm em với
    By hunglangtu_qb in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-08-2013, 09:11
  2. Xin a/e check dùm con 3gs và tư vấn dùm e
    By keylove779 in forum iPHONE 3Gs
    Bài viết cuối: 03-08-2013, 11:47
  3. Anh em chỉ dùm hộp mt-box
    By trangvinh in forum MT-Box
    Trả lời: 27
    Bài viết cuối: 26-12-2012, 10:37
  4. mấy anh xem dùm em cái log N70 với
    By liencuongmobile in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 04-04-2010, 11:33
  5. Mấy anh xem dùm log n-gate qd dùm
    By minhkhoa_iphone in forum DCT4 - WD2
    Bài viết cuối: 14-12-2009, 14:42
