tình hình là em có con IP4 ver 6.0 em muốn hạ xuống 5.1.1 để JB nhưng em thấy mọi người bảo phải có SHSH nhưng em ko có vào TU để xem có SHSH nào ko thì thì nó báo như thế này Mong ae giúp đỡ "
Request SHSH from cydia is currently set. this can cause issues if you are trying to save current SHSH as cydia is no longer able to reliably proxy SHSH requests. please change yuor setting in the advance tab and click the apply changes’ button or use the edit menu to apply changes.
you currently have set hosts to cydia on exit set. if you having issues restoring you need to uncheck this box and apply changes .be waened !if you restore stock apple firmware,your baseband can and likely will be updated
cannot start Tss service do not try restoring your device Tinyumbrella must run as adminstrator
dìng IOS 6 tốn pin lắm hả
