như tiêu đề bác nào đi ngang qua xem giúp em cái log này với chân thành cảm ơn
MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C087B39E
Using device: HTI, FW ver: 00.50, SN: 01008AE7
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00D450D5A3BDA66
ASIC type: 11
UEM Imei: Empty
Flash Imei: 35831003224552
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\_BACK.rpl"
Processing MCU file: rh112_004.030
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
UEM ID: 00D450D5:2984DA60
Area [01000000-0100FFFF] erased in 1.063 s
Area [01010000-013AFFFF] erased in 1 min 2.141 s
Area [013B0000-013EFFFF] erased in 4.359 s
Area [017C0000-017EFFFF] erased in 0.016 s
Area [01FC0000-01FEFFFF] erased in 0.015 s
Flash programming ...
Programming completed in 14.235 s
File processed in 1 min 42.141 s
Processing CNT file: rh1120_nai04.03mr
[DCT4,DCT4 ALGORITHM] size: 110.54 KB
Supported Ids: 2293
Area [01380000-013AFFFF] erased in 3.188 s
Programming completed in 0.687 s
Content extract fail, continue anyway ...
File processed in 2 min 49.656 s
Processing PPM file: rh112_004.03mr
[DCT4,DCT4 ALGORITHM] size: 1.15 MB
Supported Ids: 2293
Area [01240000-0124FFFF] erased in 1.062 s
Area [01250000-0137FFFF] erasing ...
Error while erasing 0x01350000-0x0136FFFF, Result: 00000000
flashing terminated !
			 pro nào tạt qua xem dùm log 1202
