máy em đang dùng win xp vào tiny nó báo thế này là bị làm sao mọi người giúp em phát e đang cần vào để lưu SHSH để hạ ver
Request SHSH from cydia is currently set. this can cause issues if you are trying to save current SHSH as cydia is no longer able to reliably proxy SHSH requests. please change yuor setting in the advance tab and click the apply changes’ button or use the edit menu to apply changes.
you currently have set hosts to cydia on exit set. if you having issues restoring you need to uncheck this box and apply changes .be waened !if you restore stock apple firmware,your baseband can and likely will be updated
cannot start Tss service do not try restoring your device Tinyumbrella must run as adminstrator
