máy thay cpu, giờ flash báo lổi mình ko biết lổi do cpu hay con flash nhờ ae giúp
thank all
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0855D93
Using device: HTI, FW ver: 00.50, SN: 0000B3E9
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
ASIC ID: 0x2201 [UPP_2M ver: 2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF - COMBO FLASH
ExtBUSC: AD7E BE1A 1BBE 0BF2 7D58 6BF4 DBFE 6D14
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
UEM ID: 001756DD:2984DA60
ASIC type: 2
UEM Imei: 35899501649186
Flash Imei: Empty
Invalid imei checksum !
Processing MCU file: rh64_06.400
[DCT4,DCT4 ALGORITHM] size: 1.84 MB
Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033
Area [01000000-0100FFFF] erased in 0.516 s
Area [01010000-013BFFFF] erased in 29.406 s
Area [013C0000-013EFFFF] erased in 1.547 s
Area [017C0000-017EFFFF] erased in 0.015 s
Area [01FC0000-01FEFFFF] erased in 0.032 s
Flash programming ...
The semaphore timeout period has expired
Error while programming [14] at 0x01000064, Result: 0000
flashing terminated !
