Kết quả 1 tới 10 của 17
    Thành viên chính thức ktvcuongnb's Avatar
    Mar 2010
    ca mau
    Mặc định ace giúp 6300 nươc ngoài đem về không unlock đươc
    Driver: UFS2XX, ver: 3.1.5.0 , NTMP ver: 2.4.16.0
    Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
    Reading Important data ...
    Reading RPL backup ...
    Reading Secure Storage ...
    Reading SIMLOCK data ...
    Reading CERT data ...
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 0EE00107C20D6D5679CEEF3D10E07280D9A96026
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
    eBB5ProtocolType: OLD
    Storage0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
    TransmissionMode: DDR&TX2
    Reading CMT HWC (0xD4 bytes).
    Flash Imei: 35864701635741
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    SUPERDONGLE_KEY_DATA saved OK
    CMLA_KEY_DATA saved OK
    WMDRM_PD_DATA saved OK
    RF_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.5\data\backup\BB5_3586470163574 1_BA CK.rpl"
    Preparing phone for SW downgrade ...
    Phone is ready for SW downgrade.
    Processing MCU file: rm217__vietnamese.mcusw
    [BB5,BB5 ALGORITHM] size: 14.50 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.469 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.171 s
    CMT FLASH,NOR area [00020000-0007FFFF] erased in 1.141 s
    CMT FLASH,NOR area [00080000-000DFFFF] erased in 0.203 s
    CMT FLASH,NOR area [00100000-001FFFFF] erased in 0.344 s
    CMT FLASH,NOR area [00200000-0031FFFF] erased in 3.235 s
    CMT FLASH,NOR area [00320000-0105FFFF] erased in 36.203 s
    CMT FLASH,NOR area [01060000-01067FFF] erased in 0.453 s
    CMT FLASH,NOR area [01068000-0107FFFF] erased in 0.172 s
    Prog.status for Asic CMT ...
    NOR: Success
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 7F7E6491 [RAP Certificate 52 v1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    NOR: Success
    Programming completed in 7 min 59.172 s
    Processing PPM file: rm217__vietnamese.ppm_v
    [BB5,BB5 ALGORITHM] size: 5.16 MB
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 5.50 MB
    CMT FLASH,NOR area [01080000-015FFFFF] erased in 14.609 s
    NOR: Success
    NOR: Success
    Programming completed in 2 min 56.625 s
    Processing CNT file: rm217__vietnamese.image_v_128
    [BB5,BB5 ALGORITHM] page size: 128 K size: 7.32 MB
    NOR page size in the phone is 128 K.
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Erase size: 9.87 MB
    CMT FLASH,NOR area [01600000-01FDFFFF] erased in 27.485 s
    NOR: Success
    UCP page size is 128 K.
    NOR: Success
    Programming completed in 4 min 1.734 s
    Total time for flashing process(boot+erase+write) was 17 min 20.265 s
    Phone type: RM-217 (Nokia 6300)
    SW version: V 07.30 07-05-09 RM-217 (c) Nokia.
    Imei plain: 35864701635741-6
    Product code: 0548156
    Battery voltage: 4636 mV, current: 83 mA
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 358647016357416
    Version: SIMLOCK SERVER VERSION 63
    Provider: Vodafone Network Pty. Ltd. , Country: Australia
    Counter: 0/3, 0/10
    CONFIG_DATA: 5050300014981890
    BLOCK1: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ]
    BLOCK2: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ]
    ace ai lam qua rồi giúp thank
    Thành viên kỳ cựu lethanhtam92's Avatar
    https://t.me/pump_upp
    flash lại cho em nó cái rồi fullfactory xem có ok không
  3. ( lethanhtam92 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ktvcuongnb (20-11-2012)
    Jan 2009
    Hải Phòng
    flash + write pm done unlock vẫn not ok thì chuyển box chắc chắn sẽ có lúa
  5. ( tuân gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Mar 2010
    ca mau
    đã chạy jaf mekey đêu không được
    Nov 2012
    ĐỒNG THÁP
    lấy cáp úp lưng mang qua atf cho lẹ bạn
  8. ( phithanhmobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    mx làm dụ này ngọt
  10. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  11. #7
    Mxkey dùng với nbox thì không được, nó khoá từ lâu bắt qua mxbox rồi , không thì tải cái best tool crack về unlock done thôi ........!
  12. ( Lính Khang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  13. #8
    Nov 2012
    ĐỒNG THÁP
    chủ ther đâu rùi ,6300 bb5 mx box làm ngọt
  14. #9
    Mar 2010
    ca mau
    best tool crack bạn co cho minh với thank
  15. #10
    Aug 2011
    khu đèn đỏ
    Trích Được post bởi ktvcuongnb Xem bài viết
    hàng đây
    BEST infinity.rar
  1. cần giúp 6300 mất loa ngoài
    By mrtranquang1993 in forum BB5
    Trả lời: 15
    Bài viết cuối: 01-12-2012, 11:27
  2. 6300 mất loa ngoài
    By ngocdungmobi in forum BB5
    Bài viết cuối: 28-09-2012, 06:41
  3. 6300 TQ loa ngoài rè cần ae giúp đỏ
    By TLmobi in forum Sửa chữa phần cứng
    Bài viết cuối: 09-12-2010, 12:36
  4. 6300 không loa ngoài
    By duongmanhcuong in forum Máy Trung Quốc
    Bài viết cuối: 09-05-2009, 10:15
  5. 6300 TQ loa ngoài
    By theanh132 in forum Sửa chữa phần cứng
    Bài viết cuối: 25-12-2008, 15:25
