Kết quả 1 tới 10 của 10
    Thành viên chính thức UNICEF's Avatar
    Jun 2012
    Mặc định xem giúp log 1600
    máy ko rớt , đang sử dụng thì mất nguồn, mở nguồn lúc được , lúc ko. lúc bị contact , chạy pm bằng nhiều box , nhiều ver khác nhau , xóa full chạy lại ,nhưng điều ko đồng bộ được , xin ae giúp, thanks
    đây là log check
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0855D93
    Using device: HTI, FW ver: 00.50, SN: 0000B3E9
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
    ASIC ID: 0x2201 [UPP_2M ver: 2]
    SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
    Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
    FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    FlashID1: 8080 8081 [unused/removed]
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
    UEM ID: 0014299A:2984DA60
    ASIC type: 2
    UEM Imei: 35642601164183
    Flash Imei: 35642601164183
    MasterCode: 6043362065
    RPL saved to "C:\mobileEx\3.5\data\backup\35642601164183_BACK.r pl"
    còn đây là log flash
    ASIC type: 2
    RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35642601164183_BA CK.rpl"
    Processing MCU file: rh64_07.020
    [DCT4,DCT4 ALGORITHM] size: 1.84 MB
    Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033
    Area [01000000-0100FFFF] erased in 0.453 s
    Area [01010000-013BFFFF] erased in 26.484 s
    Area [013C0000-013EFFFF] erased in 1.344 s
    Area [017C0000-017EFFFF] erased in 0.016 s
    Area [01FC0000-01FEFFFF] erased in 0.015 s
    Flash programming ...
    Programming completed in 16.125 s
    File processed in 52.422 s
    Processing CNT file: rh640_nai7.02md
    [DCT4,DCT4 ALGORITHM] size: 169.13 KB
    Area [01380000-013BFFFF] erased in 1.954 s
    Programming completed in 1.328 s
    Content extract fail, continue anyway ...
    File processed in 55.391 s
    Processing PPM file: rh64_07.02md
    [DCT4,DCT4 ALGORITHM] size: 1.68 MB
    Area [011D0000-011DFFFF] erased in 0.454 s
    Area [011E0000-0137FFFF] erased in 11.609 s
    Programming completed in 13.515 s
    File processed in 33.609 s
    Total time for flashing process(boot+erase+write) was 2 min 21.422 s
    khi flash tới file pm thì báo lổi thế này
    ip4 only bb1.59=unlock
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    đổi box flash lại coi sao , mx flash cũng hơi chuối
  3. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    UNICEF (21-11-2012)
    Jun 2012
    Trích Được post bởi duykhanh_gsm Xem bài viết
    đổi sang jaf , n-box , xóa full chạy lại cũng y chang
    Thành viên chính thức langbam's Avatar
    Mar 2012
    thay con R bsi đi
    thay con khác thì máy mới bị gây mê khi cắm box, không gây mê được thì sao đồng bộ, sao chạy được?
  6. ( langbam ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    UNICEF (21-11-2012)
    Jun 2012
    Trích Được post bởi langbam Xem bài viết
    thay con R bsi đi
    con r bis là con nào vậy anh
  8. #6
    V.I.P ĐƠ_NGUYỄN's Avatar
    che chân vpp lại xem sao bạn hiền
  9. ( ĐƠ_NGUYỄN ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    UNICEF (21-11-2012)
  10. #7
    Jun 2012
    Trích Được post bởi ĐƠ_NGUYỄN Xem bài viết
    not ok anh ơi
  11. #8
    Sóc Sơn - Hà Nội
    Nếu các cách kia không đc thì thay cặp bạn nhé !
  12. #9
    Thành viên tích cực 99999's Avatar
    Dec 2011
    cái này chắc bị u rồi
    aitun : Do1234567 - do_gsm@yahoo.com.vn ; phattaigsm@yahoo.com - Do1234567
    sicado80@gmail.com.vn - pass: oooooooo
  13. #10
    Thành viên tích cực vietdung702's Avatar
    Jul 2011
    vĩnh phúc
    bác thay con trở kép cạnh 1c nguôn + thach anh ok 90% ah. không thì bác che chân vpp đi ( xem thế nào )
    Nguyễn Việt Dũng , Cầu Tre - Hồ Sơn - Tam Đảo - VP
    YM : viet_dung702 0989 548 748 . STK : 2809205034138 Agribank ,Tam Đảo
  1. 1600 cân giúp đỡ
    By rap_3g in forum DCT4 - WD2
    Trả lời: 16
    Bài viết cuối: 21-12-2009, 13:52
  2. 1600 cần giúp
    By letamgiang in forum DCT4 - WD2
    Bài viết cuối: 29-11-2009, 11:53
  3. xin giúp 1600 ime ????????????
    By suachua.dtdd in forum DCT4 - WD2
    Bài viết cuối: 20-11-2009, 20:06
  4. đèn 1600 cần anh em giúp
    By huongkim in forum DCT4 - WD2
    Bài viết cuối: 12-11-2009, 17:03
  5. 1600 xin giúp đở.........
    By trungkiennc in forum DCT4 - WD2
    Bài viết cuối: 03-09-2009, 16:01
