    Thành viên chính thức tuantu_gsm's Avatar
    Mặc định nhờ mọi người xem giúp em cai log C5-00
    Tình trạng máy mở nguồn treo
    Đây là loag chek của em nó :
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0820380
    Using device: HTI, FW ver: 00.50, SN: 000157C5
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
    CMT Data :
    SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
    EM0 ID: 00000C35
    EM1 ID: 00000C30
    PUBLIC ID: 1600021546DB0344A0CBBCE811D8FFBE7D59E1DA
    ASIC MODE ID: 00
    ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
    ROM ID: E693EF0DAC22615B
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569
    Original Imei: 35700604888043
    Original Product code: 059F0K2
    Bluetooth ID: 6CA780CBF46B
    SIMLOCK PA identifier:
    [0] PA_SIMLOC30
    Còn đây là loag chạy :
    Version from phone: 071.005
    Version from file: 071.005
    Invalid imei plain, RPL backup skipped.
    CMT Data :
    EM0 ID: 00000C35
    EM1 ID: 00000C30
    ASIC MODE ID: 00
    Processing MCU file: rm645_071.005_prd.core.fpsx
    [BB5,XSR 1.6] size: 96.64 MB
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning ...OK
    Erase size: 170.06 MB
    CMT FLASH,MuxOneNAND area [00020000-0003FFFF]
    CMT FLASH,MuxOneNAND area [00060000-004DFFFF]
    CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF]
    Formating partition ...
    Prog.status for Asic CMT ...
    NAND: OK
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT SOS+PMML block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent
    CMT GENIO_INIT block sent
    CMT SOS*UPDAPP block sent
    CMT SOS*DSP0 block sent
    CMT LDSP block sent
    CMT SOS*ISASW block sent
    CMT SOS+CORE block sent
    CMT SOS+ROFS1 block sent
    NAND: OK
    Programming completed in 4 min 26.563 s
    Processing PPM file: rm645_071.005_16.01_Vietnam_prd.rofs2.fpsx
    [BB5,XSR 1.6] size: 30.75 MB
    Erase size: 51 MB
    CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF]
    NAND: OK
    CMT SOS+ROFS2 block sent
    NAND: OK
    Programming completed in 1 min 24.843 s
    Processing PPM file: rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
    [BB5,XSR 1.6] size: 8.01 KB
    Erase size: 14 MB
    CMT FLASH,MuxOneNAND area [0A040000-0AE3FFFF]
    NAND: OK
    CMT SOS+ROFS3 block sent
    NAND: OK
    Programming completed in 0.234 s
    Processing CNT file: RM645_ENO_10wk48v0.001.fpsx
    [BB5,XSR 1.6] size: 2.25 MB
    Erase size: 4 MB
    CMT FLASH,MuxOneNAND area [004E0000-008DFFFF]
    NAND: OK
    CMT SOS*ENO block sent
    NAND: OK
    Programming completed in 6.391 s
    Processing CNT file: rm645_071.005_U000.000_prd.uda.fpsx
    [BB5,XSR 1.6] size: 1.32 MB
    Erase size: 72 MB
    CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF]
    NAND: OK
    NAND: OK
    Programming completed in 4.594 s
    Total time for flashing process(boot+erase+write) was 6 min 16.766 s
    Phone type: RM-645 (Nokia C5-00)
    SW version: V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia
    ApeCoreSw: 071.005
    Imei plain: 12345610654321-?
    Product code: 0593574
    Battery voltage: 4527 mV, current: 32 mA
    Language Pack:
    - not available.
    SLPA ver[1]: PA_SL (15 digit NCK)
    SIMLOCK invalid!
    SUPERDONGLE_KEY invalid!
    - WD timer enabled, phone will reboot itself after 3 min.
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Imei plain is invalid !!!
    SIMLOCK_DATA corrupted!
    Thành viên tích cực pEtrAngXinh's Avatar
    May 2012
    bmt daklak
    imell 12345610654321 chạy j nũa anh thay cặp thôi
    yêu em vất vả kết quả trắng tay
    yêu anh vất vả em được tayga..:D
  4. ( pEtrAngXinh ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tuantu_gsm (24-11-2012)
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    có bk nạp vào k thì 1 cặp . banh sim lock òi
  6. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ApeCoreSw: 071.005
    Language Pack:
    - not available.
    SIMLOCK invalid!
    SIMLOCK_TEST passed
    Banh không còn cái gì hết tè be tét bét hết,Nếu không có backup full PM + IMEI thì chỉ còn cách Chạy main chạy cặp cho nhanh
  8. ( Lính Khang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    hik tai máy khách đã đem đi nơi khac sửa , giờchacws phải thay thôi em tk nhìu ah
