Kết quả 1 tới 10 của 13
    Thành viên tích cực mrtranquang1993's Avatar
    Mar 2012
    Mặc định cần giúp x2-01 báo lối
    tình hình là em nhận cây x2-01 vào mang sụp nguồn chạy lại phần mềm ver 8.70 chạy song trắng màn
    Number of Image Files: 3
    Processing Image File :
    rm709__08.71.mcusw
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed : 650000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 504
    Entry Point: 0x01F2
    Page Format : -1
    MAX PAGE : 0x0000E000
    rm709__08.71.ppm_mh1
    CMT Type : BB5
    Number of Blocks : 125
    Entry Point: 0x0113
    Page Format : -1
    rm709__08.71_004.image_mh1_ctv_in_v2_9l3w2
    CMT Type : BB5
    Number of Blocks : 446
    Entry Point: 0x0147
    Page Format : -1
    []: Found 0 active devices.
    []: Not Found!
    Rebooting Phone...
    AUTO SELECTED DEAD USB FLASHING...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    Number of Sub Blocks 6 (0x06)
    1 SYSTEM_ASIC_ID 01
    Block Length : 17 (11)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000000
    ID DWORD 1 : 00000000
    ID DWORD 2 : 22000509
    ID DWORD 3 : 200C0000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00005361
    3 PUBLIC_ID 12
    Block Length : 21 (15)
    ID DWORD 1 : 0025940D
    ID DWORD 2 : 5168A55F
    ID DWORD 3 : 86B2EFD1
    ID DWORD 4 : 9C8C1381
    4 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    5 ROOT_KEY_HASH 14
    Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
    6 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : DE56D582
    CRC 1 : BDDE7A3A
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_u sb2nd.fg
    Secondary Loader Sent....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0020 ->
    Device ID : 0030 -> Type not in database
    Revision ID : 0131
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0010 ->
    Device ID : 0011 -> Type not in database
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Revision ID : 0131
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data :
    Flash Descriptor
    Device ID : 0030
    Revision ID : 0000
    Size : 08000000 (128 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_X SR16_usbalg.fg
    Algorithm Loader Sent...
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok
    START READING RPL DATA
    IMEI: 354842040910827
    Reading : NPC... OK!
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : R&D... OK!
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\354842040910827\3548420409108 27_102935.rpl
    Pabub KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    37955B6FC432998EF0DB240E332228384D19ED09
    ImagePath: C:\Documents and Settings\Mr.TranQuangmobile\Desktop\RM-709+++8.71++tv+of+8.70\RM-709 8.71 tv of 8.70\
    ImageFilename: rm709__08.71.mcusw
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    Certificate 5
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    1 PARTITION_INFO_BB5
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    Partition Version : 00010000
    Spare : FFFFFFFF
    Num Partitions : 00000004
    Partition 1
    Attribute : 00000002 RO
    Start Address : 00020000
    Partition 2
    ID : 00000008 FILESYSTEM
    Attribute : 00000001 RW
    Start Address : 02A00000
    Partition 3
    Start Address : 07540000
    Partition 4
    Start Address : 07B40000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200020000025E0000000000080000000102A0000004B400 000000000A0000000107540000006000000000000B00000001 07B40000001800000D
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0x90 (144)
    ERASE Blocks : 0x03 (3)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x2B (43)
    Device Index : 0x00
    0 : 00000000-0001FFFF
    1 : 00020000-000203FF
    2 : 00060000-012FFFFF
    3 : 01300000-01DFFFFF
    4 : 02600000-029FFFFF
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x02000000
    Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
    2 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B0003000002000000 0203FF120B00030000060000012FFFFF120B00030001300000 01DFFFFF120B00030002600000029FFFFF11
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
    Successfully Erased...
    Total blocks to write : 504
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : ADA
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : RAP3NAND
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS
    >> CMT Rootkey Hash CERT : UPDAPP
    >> CMT Rootkey Hash CERT : MCUSW
    >> CMT Rootkey Hash CERT : MCUSW1
    >> CMT Rootkey Hash CERT : GENIO_INIT
    >> CMT Rootkey Hash CERT : ISA+DYNSW
    ImageFilename: rm709__08.71.ppm_mh1
    Partition Info
    Device Index : 0x00
    Spare : FFFFFFFF
    Partition 1
    Partition 2
    Partition 3
    Partition 4
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    ERASE Blocks : 0x01 (1)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 01E00000-025FFFFF
    ERASE_REQUEST_BB5 : 5001120B00030001E00000025FFFFF9E
    Total blocks to write : 125
    ImageFilename: rm709__08.71_004.image_mh1_ctv_in_v2_9l3w2
    Partition Info
    Device Index : 0x00
    Spare : FFFFFFFF
    Partition 1
    Partition 2
    Partition 3
    Partition 4
    ProcessPartitionInfo_DCT5 : Error
    Flashing Failed....
    Booting/Flashing Failed...
    Please Try Again...
    Mar 2012
    sao không có bác nào giúp em vậy
    Thành viên chính thức ktvcuongnb's Avatar
    Mar 2010
    ca mau
    kiếm feil khác chạy lại coi máy chưa đồng bị mà chạy USB chuẩn hơn
    Flashing Failed....
    Please Try Again...
    Mar 2012
    em chay bằng usb mà em thủ file khác cúng không được
    Thành viên chính thức quangngocbk's Avatar
    Jun 2011
    cho qua phonex múc xem sao bác ơi
    hoặc cho vào bok khác lụm gạo
    học thầy không tày học ban/////////
    yahoo; motbuocgianghoqn89 gmai; quangngocbk.com
    Sóc Sơn - Hà Nội
    lỗi không đồng bộ đc ! chạy lại phát nữa xem sao ! chạy ver thấp hơn ver cũ cũng bị tình trang trên ! nếu không backup full thì xẽ trắng tay ! Cái này là phải phang ver 8.71 nhé bạn !
    Mar 2012
    mang sang mx nhưng cúng k dược
    Mar 2012
    k có bác nào có cách ak. cứ em với
    Thành viên chính thức sau666_gsm's Avatar
    BÌNH DƯƠNG
    chọn ver cao nhất để chạy lại => box khác ! ko được khò nóng cặp chạy xem được ko ?
    chúc thành công
    Muốn thành công phải qua nhiều thất bại
    Trên đường đời có dại mới lên khôn !
    Mar 2012
    em thử rồi khò thì chưa máy từ đầu vấn lên nguồn mà bác
