Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 24
    Thành viên chính thức ngocthao_mobile's Avatar
    Nov 2012
    Mặc định e7 chạy phần mêm mất nguồn!
    tình hình là máy nó bị đơ đơ.em chạy lại phần mềm ver cao nhất rồi mà không đồng bộ được.bây giờ em nó đang ngủ ngon quá gọi dậy không được.mở nguồn chỉ rung cái thôi.em chạy bằng atf
    Number of Image Files: 5
    Processing Image File :
    RM-626_111.040.1511_79u_prd.core.fpsx
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed : 650000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 13000000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 613
    Entry Point: 0x0222
    Page Format : -1
    MAX PAGE : 0x00040000
    RM-626_111.040.1511_C02.01_SEAP_79u_prd.rofs3.fpsx
    CMT Type : BB5
    Number of Blocks : 16
    Entry Point: 0x0103
    Page Format : -1
    MAX PAGE : 0x00004A00
    RM-626_111.040.1511_38.01_Vietnam_79u_prd.rofs2.fpsx
    CMT Type : BB5
    Number of Blocks : 148
    Entry Point: 0x00FB
    Page Format : -1
    RM-626_111.040.1511_U08.01_79u.uda.fpsx
    CMT Type : BB5
    Number of Blocks : 873
    Entry Point: 0x00FB
    Page Format : -1
    RM626_APE_ONLY_ENO_11w36_v0.037.fpsx
    CMT Type : BB5
    Program Sending Speed : 6500000Hz
    Number of Blocks : 26
    Entry Point: 0x0138
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000003
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010007
    ID DWORD 3 : 600C1921
    ID DWORD 4 : 02031104
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00001040
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00001030
    4 PUBLIC_ID 12
    ID DWORD 0 : 1E900107
    ID DWORD 1 : 43D60344
    ID DWORD 2 : 1CE95164
    ID DWORD 3 : B3F6D17F
    ID DWORD 4 : 61192250
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : E693EF0D
    CRC 1 : AC22615B
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
    Secondary Loader Sent....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0020 ->
    Device ID : 0068 -> Type not in database
    Revision ID : 0031
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> Type not in database
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Revision ID : 0031
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.6
    Flash Descriptor
    Device ID : 0068
    Revision ID : 0000
    Size : 40000000 (1024 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
    Algorithm Loader Sent...
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok
    START READING RPL DATA
    IMEI: 354864042590308
    Reading : NPC... OK!
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : R&D... OK!
    NPC CERTIFICATE INFORMATION (CMT):
    IMEI : 345680424953080
    PRODUCT CODE : 059D0M7
    WLAN ID : 78:2E:EF:7942
    BLUETOOTH ID : 78:2E:EF:79:86:B2
    PUBLIC_ID : 1E90010743D603441CE95164B3F6D17F61192250
    PAPUB_KEYS_HASH: 8EABFDA6B8A757034233978C16A93B892CE2D4FA
    CCC CERTIFICATE INFORMATION (CMT):
    HWC CERTIFICATE INFORMATION (CMT):
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\354864042590308\3548640425903 08_12328.rpl
    Pabub KEY Request
    No PAPUBKeysHash Returned
    ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-626\
    ImageFilename: RM-626_111.040.1511_79u_prd.core.fpsx
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    Certificate 5
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    PARTITION_INFO_REQUEST_BB5 : 64012F5F00030000020000FFFFFFFF00000005000000030000 00020014000002A40000000000040000000202B800000D1000 0000000008000000010FC800001E4800000000002700000001 2E100000105000000000000A000000013E60000000400000D9
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0x57 (87)
    ERASE Blocks : 0x02 (2)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x23 (35)
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    0 : 00040000-0007FFFF
    1 : 000C0000-008BFFFF
    2 : 00DC0000-0FC7FFFF
    3 : 2E100000-3E5FFFFF
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x03000000
    Format Info : 000000000000000A0000000000000002000000640018000000 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5004120B000300000400000007FFFF120B000300000C000000 8BFFFF120B00030000DC00000FC7FFFF120B0003002E100000 3E5FFFFF54
    FORMAT_REQUEST_BB5 : 5001192F00030000000003000000000000000A000000000000 00020000006400180000000000020000000100000000000000 0025
    Successfully Erased...
    Total blocks to write : 613
    >> CMT Rootkey Hash CERT : ADA
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : RAP3NAND
    >> CMT Rootkey Hash CERT : SOS+PMML
    >> CMT Rootkey Hash CERT : SOS+DECOMP
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS [8EABFDA6B8A757034233978C16A93B892CE2D4FA]
    >> CMT Rootkey Hash CERT : GENIO_INIT
    >> CMT Rootkey Hash CERT : SOS+IVE3A
    >> CMT Rootkey Hash CERT : SOS*UPDAPP
    >> CMT Rootkey Hash CERT : SOS*DSP0
    >> CMT Rootkey Hash CERT : LDSP
    >> CMT Rootkey Hash CERT : SOS*ISASW
    >> CMT Rootkey Hash CERT : SOS+CORE
    >> CMT Rootkey Hash CERT : SOS+ROFS1
    ImageFilename: RM-626_111.040.1511_C02.01_SEAP_79u_prd.rofs3.fpsx
    StartErase_DCT5...
    BlockLength : 0x16 (22)
    ERASE Blocks : 0x01 (1)
    Block Length : 0x13 (19)
    Device Index : 0x00
    0 : 01378000-0139FFFF
    1 : 0E900000-0FC7FFFF
    ERASE_REQUEST_BB5 : 5002120B000300013780000139FFFF120B0003000E9000000F C7FFFF5B
    Total blocks to write : 16
    >> CMT Rootkey Hash CERT : SOS+ROFS3
    >> CMT Rootkey Hash CERT : SOS+IVE3B
    ImageFilename: RM-626_111.040.1511_38.01_Vietnam_79u_prd.rofs2.fpsx
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 0A580000-0E8FFFFF
    ERASE_REQUEST_BB5 : 5001120B0003000A5800000E8FFFFFE1
    Total blocks to write : 148
    >> CMT Rootkey Hash CERT : SOS+ROFS2
    ImageFilename: RM-626_111.040.1511_U08.01_79u.uda.fpsx
    StartErase_DCT5...
    Device Index : 0x00
    0 : 0FC80000-2E0FFFFF
    ERASE_REQUEST_BB5 : 5001120B0003000FC800002E0FFFFFCC
    Total blocks to write : 873
    ImageFilename: RM626_APE_ONLY_ENO_11w36_v0.037.fpsx
    StartErase_DCT5...
    Device Index : 0x00
    0 : 008C0000-00DBFFFF
    ERASE_REQUEST_BB5 : 5001120B000300008C000000DBFFFF79
    FAILED ERASING....
    Flashing Failed....
    Booting/Flashing Failed...
    Please Try Again...
    ai giúp em với.ok bao mấy chầu cafe cũng được!!!!!!!!!thank trước
    luôn luôn lắng nghe.lâu lâu mới hiểu!
    Thành viên tích cực tony.haokiet's Avatar
    Jan 2010
    mxbox xem thử bạn . nếu không có hộp thì dùng phonenix + nokia suite
  3. ( tony.haokiet ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ngocthao_mobile (30-11-2012)
    Nov 2012
    thử rồi anh ơi.nhờ anh lê trinh làm mà cũng không được!!!
    Nếu máy không bị rơi rớt gì hết mà flash lại xong mà rung cái tịt mất nguồn thì không phải liên quan tới phần cứng gì cả,nếu ngồi vọc một hồi em nó tè be tét bét thì khỏi cứu luôn á,Đem qua box mx info xong rồi quăn cái log lên đây cho tôi coi thử,rồi tôi sẻ hướng dẫn chủ thớt cứu em nó lại,em nó mất nguồn từ đâu thì cứ làm từ đó lại,chứ nhìn cái log ATF thì cũng mù tịt thôi à,muốn biết chính xác thì đem qua cái MX là ok nhất.....!
  6. ( Lính Khang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Nov 2012
    em chỉ có atf thôi anh ơi.đang nhờ anh kia xem hộ.anh ơ biên hoà hay sài gòn cho em đia chỉ cái.em mang tới giúp em cái với!
  8. #6
    Nov 2012
    nkmobile ở đâu thế?
  9. #7
    Jun 2012
    kiếm cái file chuẩn xem nhiều khi navi vẩn bi lổi nhé
  10. #8
    Moderator TÚ CÒI's Avatar
    hà nội
    Trích Được post bởi NKMobile™ Xem bài viết
    Ko đồng bộ được thì info sao được mà quang log lên
    Kiếm file chuẩn khác đập cho nó cái xem sao,mang qua thiết bị khác test luôn
    chú ý nạp Pin full trước khi chaỵ nhé
  11. #9
    Nov 2012
    làm đầy đủ rùi mà vẫn ko được mấy anh ơi
  12. #10
    Thành viên mới dtngoclinh's Avatar
    Oct 2009
    Trích Được post bởi ngocthao_mobile Xem bài viết
    best infiniti là chuẩn nhất 100% ok
  1. 1208 bi chạy lại phần mêm contecservei
    By toantkx92 in forum DCT4 - WD2
    Bài viết cuối: 11-04-2012, 07:57
  2. N70 chạy phần mêm cần ae giúp
    By HQDuan_GSM in forum BB5
    Bài viết cuối: 07-09-2011, 10:53
  3. 1110i chạy phần mêm ok bật nguồn không lên
    By ThanhHai_GSM in forum DCT4 - WD2
    Trả lời: 16
    Bài viết cuối: 27-02-2011, 22:40
  4. Chạy phần mêm máy tq bệnh lạ
    By maivanthuat in forum Phần mềm và các mã lệnh
    Bài viết cuối: 07-08-2009, 09:25
  5. bác nào cho em sin phần mêm chạy nhac 1200 vơi
    By NAMTIEN in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-05-2008, 15:30
