e có cây x1-01 khách đưa vô mất nguôn`,e đã bỏ hết mấy tụ gân` chân pin va kiểm tra đương` mang` hinh thấy ko đức nhưng vẫn ko lên nguôn` nhơ ea cưu giứp.đây la log mxkey
Using device: HTI, FW ver: 00.50, SN: 0000967F
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.24
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 0020 8804 - 23280001 [ST 58LR128U,128 Mbits]
CFI information:
Flash settings: 0/64, size: 0x01000000
2 Block regions:
127 x 0x00020000 = 0x00FE0000
4 x 0x00008000 = 0x00020000
EBL ready !
Phone type: RM-713
SW version: V 07.50 29-11-11 RM-713 (c) Nokia
Imei plain: 35328905422516-6
Product code: 059D8Q7
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MR
Language Pack:
- not available.
"C:\Program Files\Nokia\Phoenix\Products\RM-713" folder created.
Imei net: 35328905422516
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000040002
