Kết quả 1 tới 10 của 10
    Thành viên tích cực daochikien's Avatar
    Mar 2012
    hai duong
    Mặc định 1110i không unlock được cần ae giúp
    báo cáo các bác em có con 1110i lắp sim vào lúc nhận sim lúc không , em mang flash lại thì không unlock được , đây là log unlock và write pm full
    Code:
    Field : 1 Sub : 0 Byte(s): 120  - Ok
    Field : 1 Sub : 2 Byte(s): 90  - Ok
    Field : 1 Sub : 4 Byte(s): 110  - Ok
    Field : 1 Sub : 5 Byte(s): 2  - Ok
    Field : 1 Sub : 6 Byte(s): 90  - Ok
    Field : 1 Sub : 11 Byte(s): 2  - Ok
    Field : 1 Sub : 12 Byte(s): 2  - Ok
    Field : 2 Sub : 0 Byte(s): 132  - Ok
    Field : 3 Sub : 0 Byte(s): 3  - Ok
    Field : 4 Sub : 0 Byte(s): 1  - Ok
    Field : 4 Sub : 1 Byte(s): 8  - Ok
    Field : 4 Sub : 2 Byte(s): 44  - Ok
    Field : 4 Sub : 3 Byte(s): 10  - Ok
    Field : 4 Sub : 4 Byte(s): 8  - Ok
    Field : 4 Sub : 5 Byte(s): 8  - Ok
    Field : 4 Sub : 6 Byte(s): 8  - Ok
    Field : 4 Sub : 9 Byte(s): 5  - Ok
    Field : 5 Sub : 0 Byte(s): 78  - Ok
    Field : 7 Sub : 0 Byte(s): 4  - Ok
    Field : 7 Sub : 1 Byte(s): 32  - Ok
    Field : 7 Sub : 2 Byte(s): 4  - Ok
    Field : 8 Sub : 0 Byte(s): 12  - Ok
    Field : 11 Sub : 0 Byte(s): 4  - Ok
    Field : 11 Sub : 1 Byte(s): 4  - Ok
    Field : 11 Sub : 2 Byte(s): 4  - Ok
    Field : 11 Sub : 3 Byte(s): 4  - Ok
    Field : 11 Sub : 4 Byte(s): 1  - Ok
    Field : 11 Sub : 5 Byte(s): 6  - Ok
    Field : 11 Sub : 6 Byte(s): 4  - Ok
    Field : 11 Sub : 7 Byte(s): 2  - Ok
    Field : 11 Sub : 8 Byte(s): 1  - Ok
    Field : 11 Sub : 9 Byte(s): 4  - Ok
    Field : 11 Sub : 10 Byte(s): 31  - Ok
    Field : 11 Sub : 11 Byte(s): 2  - Ok
    Field : 11 Sub : 12 Byte(s): 1  - Ok
    Field : 11 Sub : 13 Byte(s): 1  - Ok
    Field : 11 Sub : 14 Byte(s): 1  - Ok
    Field : 11 Sub : 15 Byte(s): 1  - Ok
    Field : 11 Sub : 16 Byte(s): 8  - Ok
    Field : 11 Sub : 17 Byte(s): 1  - Ok
    Field : 11 Sub : 18 Byte(s): 1  - Ok
    Field : 11 Sub : 19 Byte(s): 4  - Ok
    Field : 11 Sub : 20 Byte(s): 2  - Ok
    Field : 11 Sub : 21 Byte(s): 2  - Ok
    Field : 11 Sub : 22 Byte(s): 1  - Ok
    Field : 11 Sub : 23 Byte(s): 8  - Ok
    Field : 11 Sub : 24 Byte(s): 1  - Ok
    Field : 11 Sub : 25 Byte(s): 2  - Ok
    Field : 11 Sub : 26 Byte(s): 2  - Ok
    Field : 11 Sub : 27 Byte(s): 2  - Ok
    Field : 11 Sub : 28 Byte(s): 2  - Ok
    Field : 11 Sub : 29 Byte(s): 2  - Ok
    Field : 11 Sub : 30 Byte(s): 4  - Ok
    Field : 11 Sub : 31 Byte(s): 4  - Ok
    Field : 11 Sub : 32 Byte(s): 4  - Ok
    Field : 11 Sub : 33 Byte(s): 4  - Ok
    Field : 11 Sub : 34 Byte(s): 4  - Ok
    Field : 11 Sub : 35 Byte(s): 4  - Ok
    Field : 11 Sub : 36 Byte(s): 16  - Ok
    Field : 11 Sub : 37 Byte(s): 4  - Ok
    Field : 11 Sub : 38 Byte(s): 2  - Ok
    Field : 11 Sub : 39 Byte(s): 4  - Ok
    Field : 11 Sub : 40 Byte(s): 2  - Ok
    Field : 11 Sub : 41 Byte(s): 2  - Ok
    Field : 11 Sub : 42 Byte(s): 1  - Ok
    Field : 11 Sub : 43 Byte(s): 1  - Ok
    Field : 11 Sub : 44 Byte(s): 4  - Ok
    Field : 11 Sub : 45 Byte(s): 4  - Ok
    Field : 11 Sub : 46 Byte(s): 4  - Ok
    Field : 11 Sub : 47 Byte(s): 4  - Ok
    Field : 11 Sub : 48 Byte(s): 4  - Ok
    Field : 11 Sub : 49 Byte(s): 4  - Ok
    Field : 11 Sub : 50 Byte(s): 4  - Ok
    Field : 11 Sub : 51 Byte(s): 4  - Ok
    Field : 11 Sub : 52 Byte(s): 4  - Ok
    Field : 11 Sub : 53 Byte(s): 4  - Ok
    Field : 11 Sub : 54 Byte(s): 4  - Ok
    Field : 11 Sub : 55 Byte(s): 4  - Ok
    Field : 11 Sub : 56 Byte(s): 4  - Ok
    Field : 11 Sub : 57 Byte(s): 4  - Ok
    Field : 11 Sub : 58 Byte(s): 4  - Ok
    Field : 11 Sub : 59 Byte(s): 4  - Ok
    Field : 11 Sub : 60 Byte(s): 4  - Ok
    Field : 11 Sub : 61 Byte(s): 4  - Ok
    Field : 11 Sub : 62 Byte(s): 4  - Ok
    Field : 11 Sub : 63 Byte(s): 4  - Ok
    Field : 11 Sub : 64 Byte(s): 4  - Ok
    Field : 11 Sub : 65 Byte(s): 4  - Ok
    Field : 11 Sub : 66 Byte(s): 4  - Ok
    Field : 11 Sub : 67 Byte(s): 4  - Ok
    Field : 11 Sub : 68 Byte(s): 4  - Ok
    Field : 11 Sub : 69 Byte(s): 4  - Ok
    Field : 11 Sub : 70 Byte(s): 4  - Ok
    Field : 11 Sub : 71 Byte(s): 4  - Ok
    Field : 11 Sub : 72 Byte(s): 4  - Ok
    Field : 11 Sub : 73 Byte(s): 4  - Ok
    Field : 11 Sub : 74 Byte(s): 4  - Ok
    Field : 11 Sub : 75 Byte(s): 4  - Ok
    Field : 11 Sub : 76 Byte(s): 4  - Ok
    Field : 11 Sub : 77 Byte(s): 4  - Ok
    Field : 11 Sub : 78 Byte(s): 4  - Ok
    Field : 11 Sub : 79 Byte(s): 4  - Ok
    Field : 11 Sub : 80 Byte(s): 4  - Ok
    Field : 11 Sub : 81 Byte(s): 4  - Ok
    Field : 11 Sub : 82 Byte(s): 2  - Ok
    Field : 11 Sub : 83 Byte(s): 4  - Ok
    Field : 11 Sub : 84 Byte(s): 2  - Ok
    Field : 11 Sub : 85 Byte(s): 1  - Ok
    Field : 11 Sub : 86 Byte(s): 16  - Ok
    Field : 11 Sub : 87 Byte(s): 88  - Ok
    Field : 11 Sub : 88 Byte(s): 2  - Ok
    Field : 11 Sub : 89 Byte(s): 4  - Ok
    Field : 11 Sub : 90 Byte(s): 2  - Ok
    Field : 11 Sub : 91 Byte(s): 2  - Ok
    Field : 11 Sub : 92 Byte(s): 2  - Ok
    Field : 11 Sub : 93 Byte(s): 2  - Ok
    Field : 11 Sub : 94 Byte(s): 2  - Ok
    Field : 11 Sub : 95 Byte(s): 2  - Ok
    Field : 11 Sub : 96 Byte(s): 2  - Ok
    Field : 11 Sub : 97 Byte(s): 2  - Ok
    Field : 11 Sub : 98 Byte(s): 2  - Ok
    Field : 11 Sub : 99 Byte(s): 2  - Ok
    Field : 11 Sub : 100 Byte(s): 2  - Ok
    Field : 11 Sub : 101 Byte(s): 2  - Ok
    Field : 11 Sub : 102 Byte(s): 2  - Ok
    Field : 11 Sub : 103 Byte(s): 2  - Ok
    Field : 11 Sub : 104 Byte(s): 2  - Ok
    Field : 11 Sub : 105 Byte(s): 2  - Ok
    Field : 11 Sub : 106 Byte(s): 2  - Ok
    Field : 11 Sub : 107 Byte(s): 2  - Ok
    Field : 11 Sub : 108 Byte(s): 2  - Ok
    Field : 11 Sub : 109 Byte(s): 2  - Ok
    Field : 11 Sub : 110 Byte(s): 2  - Ok
    Field : 11 Sub : 111 Byte(s): 2  - Ok
    Field : 11 Sub : 112 Byte(s): 2  - Ok
    Field : 11 Sub : 113 Byte(s): 2  - Ok
    Field : 11 Sub : 114 Byte(s): 2  - Ok
    Field : 13 Sub : 0 Byte(s): 34  - Ok
    Field : 13 Sub : 1 Byte(s): 34  - Ok
    Field : 13 Sub : 2 Byte(s): 34  - Ok
    Field : 13 Sub : 3 Byte(s): 34  - Ok
    Field : 13 Sub : 4 Byte(s): 34  - Ok
    Field : 13 Sub : 5 Byte(s): 34  - Ok
    Field : 13 Sub : 6 Byte(s): 34  - Ok
    Field : 13 Sub : 7 Byte(s): 34  - Ok
    Field : 13 Sub : 8 Byte(s): 34  - Ok
    Field : 13 Sub : 9 Byte(s): 34  - Ok
    Field : 13 Sub : 10 Byte(s): 34  - Ok
    Field : 13 Sub : 11 Byte(s): 34  - Ok
    Field : 13 Sub : 12 Byte(s): 34  - Ok
    Field : 13 Sub : 13 Byte(s): 34  - Ok
    Field : 13 Sub : 14 Byte(s): 34  - Ok
    Field : 13 Sub : 15 Byte(s): 34  - Ok
    Field : 13 Sub : 16 Byte(s): 34  - Ok
    Field : 13 Sub : 17 Byte(s): 34  - Ok
    Field : 13 Sub : 18 Byte(s): 34  - Ok
    Field : 13 Sub : 19 Byte(s): 34  - Ok
    Field : 13 Sub : 20 Byte(s): 34  - Ok
    Field : 13 Sub : 21 Byte(s): 34  - Ok
    Field : 13 Sub : 22 Byte(s): 34  - Ok
    Field : 13 Sub : 23 Byte(s): 34  - Ok
    Field : 13 Sub : 24 Byte(s): 34  - Ok
    Field : 13 Sub : 25 Byte(s): 34  - Ok
    Field : 13 Sub : 26 Byte(s): 34  - Ok
    Field : 13 Sub : 27 Byte(s): 34  - Ok
    Field : 13 Sub : 28 Byte(s): 34  - Ok
    Field : 13 Sub : 29 Byte(s): 34  - Ok
    Field : 13 Sub : 30 Byte(s): 34  - Ok
    Field : 13 Sub : 31 Byte(s): 34  - Ok
    Field : 13 Sub : 32 Byte(s): 34  - Ok
    Field : 13 Sub : 33 Byte(s): 34  - Ok
    Field : 13 Sub : 34 Byte(s): 34  - Ok
    Field : 13 Sub : 35 Byte(s): 34  - Ok
    Field : 13 Sub : 36 Byte(s): 34  - Ok
    Field : 13 Sub : 37 Byte(s): 34  - Ok
    Field : 13 Sub : 38 Byte(s): 34  - Ok
    Field : 13 Sub : 39 Byte(s): 34  - Ok
    Field : 13 Sub : 40 Byte(s): 34  - Ok
    Field : 13 Sub : 41 Byte(s): 34  - Ok
    Field : 13 Sub : 42 Byte(s): 34  - Ok
    Field : 13 Sub : 43 Byte(s): 34  - Ok
    Field : 13 Sub : 44 Byte(s): 34  - Ok
    Field : 13 Sub : 45 Byte(s): 34  - Ok
    Field : 13 Sub : 46 Byte(s): 34  - Ok
    Field : 13 Sub : 47 Byte(s): 34  - Ok
    Field : 13 Sub : 48 Byte(s): 34  - Ok
    Field : 13 Sub : 49 Byte(s): 34  - Ok
    Field : 13 Sub : 50 Byte(s): 34  - Ok
    Field : 13 Sub : 51 Byte(s): 34  - Ok
    Field : 13 Sub : 52 Byte(s): 34  - Ok
    Field : 13 Sub : 53 Byte(s): 34  - Ok
    Field : 13 Sub : 54 Byte(s): 34  - Ok
    Field : 13 Sub : 55 Byte(s): 34  - Ok
    Field : 13 Sub : 56 Byte(s): 34  - Ok
    Field : 13 Sub : 57 Byte(s): 34  - Ok
    Field : 13 Sub : 58 Byte(s): 34  - Ok
    Field : 13 Sub : 59 Byte(s): 34  - Ok
    Field : 13 Sub : 60 Byte(s): 34  - Ok
    Field : 13 Sub : 61 Byte(s): 34  - Ok
    Field : 13 Sub : 62 Byte(s): 34  - Ok
    Field : 13 Sub : 63 Byte(s): 34  - Ok
    Field : 13 Sub : 64 Byte(s): 34  - Ok
    Field : 13 Sub : 65 Byte(s): 34  - Ok
    Field : 13 Sub : 66 Byte(s): 34  - Ok
    Field : 13 Sub : 67 Byte(s): 34  - Ok
    Field : 13 Sub : 68 Byte(s): 34  - Ok
    Field : 13 Sub : 69 Byte(s): 34  - Ok
    Field : 13 Sub : 70 Byte(s): 34  - Ok
    Field : 13 Sub : 71 Byte(s): 34  - Ok
    Field : 13 Sub : 72 Byte(s): 34  - Ok
    Field : 13 Sub : 73 Byte(s): 34  - Ok
    Field : 13 Sub : 74 Byte(s): 34  - Ok
    Field : 13 Sub : 75 Byte(s): 34  - Ok
    Field : 13 Sub : 76 Byte(s): 34  - Ok
    Field : 13 Sub : 77 Byte(s): 34  - Ok
    Field : 13 Sub : 78 Byte(s): 34  - Ok
    Field : 13 Sub : 79 Byte(s): 34  - Ok
    Field : 13 Sub : 80 Byte(s): 34  - Ok
    Field : 13 Sub : 81 Byte(s): 34  - Ok
    Field : 13 Sub : 82 Byte(s): 34  - Ok
    Field : 13 Sub : 83 Byte(s): 34  - Ok
    Field : 13 Sub : 84 Byte(s): 34  - Ok
    Field : 13 Sub : 85 Byte(s): 34  - Ok
    Field : 13 Sub : 86 Byte(s): 34  - Ok
    Field : 13 Sub : 87 Byte(s): 34  - Ok
    Field : 13 Sub : 88 Byte(s): 34  - Ok
    Field : 13 Sub : 89 Byte(s): 34  - Ok
    Field : 13 Sub : 90 Byte(s): 34  - Ok
    Field : 13 Sub : 91 Byte(s): 34  - Ok
    Field : 13 Sub : 92 Byte(s): 34  - Ok
    Field : 13 Sub : 93 Byte(s): 34  - Ok
    Field : 13 Sub : 94 Byte(s): 34  - Ok
    Field : 13 Sub : 95 Byte(s): 34  - Ok
    Field : 13 Sub : 96 Byte(s): 34  - Ok
    Field : 13 Sub : 97 Byte(s): 34  - Ok
    Field : 13 Sub : 98 Byte(s): 34  - Ok
    Field : 13 Sub : 99 Byte(s): 34  - Ok
    Field : 13 Sub : 100 Byte(s): 34  - Ok
    Field : 13 Sub : 101 Byte(s): 34  - Ok
    Field : 13 Sub : 102 Byte(s): 34  - Ok
    Field : 13 Sub : 103 Byte(s): 34  - Ok
    Field : 13 Sub : 104 Byte(s): 34  - Ok
    Field : 13 Sub : 105 Byte(s): 34  - Ok
    Field : 13 Sub : 106 Byte(s): 34  - Ok
    Field : 13 Sub : 107 Byte(s): 34  - Ok
    Field : 13 Sub : 108 Byte(s): 34  - Ok
    Field : 13 Sub : 109 Byte(s): 34  - Ok
    Field : 13 Sub : 110 Byte(s): 34  - Ok
    Field : 13 Sub : 111 Byte(s): 34  - Ok
    Field : 13 Sub : 112 Byte(s): 34  - Ok
    Field : 13 Sub : 113 Byte(s): 34  - Ok
    Field : 13 Sub : 114 Byte(s): 34  - Ok
    Field : 13 Sub : 115 Byte(s): 34  - Ok
    Field : 13 Sub : 116 Byte(s): 34  - Ok
    Field : 13 Sub : 117 Byte(s): 34  - Ok
    Field : 13 Sub : 118 Byte(s): 34  - Ok
    Field : 13 Sub : 119 Byte(s): 34  - Ok
    Field : 13 Sub : 120 Byte(s): 34  - Ok
    Field : 13 Sub : 121 Byte(s): 34  - Ok
    Field : 13 Sub : 122 Byte(s): 34  - Ok
    Field : 13 Sub : 123 Byte(s): 34  - Ok
    Field : 13 Sub : 124 Byte(s): 34  - Ok
    Field : 13 Sub : 125 Byte(s): 34  - Ok
    Field : 13 Sub : 126 Byte(s): 34  - Ok
    Field : 13 Sub : 127 Byte(s): 34  - Ok
    Field : 13 Sub : 128 Byte(s): 34  - Ok
    Field : 13 Sub : 129 Byte(s): 34  - Ok
    Field : 13 Sub : 130 Byte(s): 34  - Ok
    Field : 13 Sub : 131 Byte(s): 34  - Ok
    Field : 13 Sub : 132 Byte(s): 34  - Ok
    Field : 13 Sub : 133 Byte(s): 34  - Ok
    Field : 13 Sub : 134 Byte(s): 34  - Ok
    Field : 13 Sub : 135 Byte(s): 34  - Ok
    Field : 13 Sub : 136 Byte(s): 34  - Ok
    Field : 13 Sub : 137 Byte(s): 34  - Ok
    Field : 13 Sub : 138 Byte(s): 34  - Ok
    Field : 13 Sub : 139 Byte(s): 34  - Ok
    Field : 13 Sub : 140 Byte(s): 34  - Ok
    Field : 13 Sub : 141 Byte(s): 34  - Ok
    Field : 13 Sub : 142 Byte(s): 34  - Ok
    Field : 13 Sub : 143 Byte(s): 34  - Ok
    Field : 13 Sub : 144 Byte(s): 34  - Ok
    Field : 13 Sub : 145 Byte(s): 34  - Ok
    Field : 13 Sub : 146 Byte(s): 34  - Ok
    Field : 13 Sub : 147 Byte(s): 34  - Ok
    Field : 13 Sub : 148 Byte(s): 34  - Ok
    Field : 13 Sub : 149 Byte(s): 34  - Ok
    Field : 13 Sub : 150 Byte(s): 34  - Ok
    Field : 13 Sub : 151 Byte(s): 34  - Ok
    Field : 13 Sub : 152 Byte(s): 34  - Ok
    Field : 13 Sub : 153 Byte(s): 34  - Ok
    Field : 13 Sub : 154 Byte(s): 34  - Ok
    Field : 13 Sub : 155 Byte(s): 34  - Ok
    Field : 13 Sub : 156 Byte(s): 34  - Ok
    Field : 13 Sub : 157 Byte(s): 34  - Ok
    Field : 13 Sub : 158 Byte(s): 34  - Ok
    Field : 13 Sub : 159 Byte(s): 34  - Ok
    Field : 13 Sub : 160 Byte(s): 34  - Ok
    Field : 13 Sub : 161 Byte(s): 34  - Ok
    Field : 13 Sub : 162 Byte(s): 34  - Ok
    Field : 13 Sub : 163 Byte(s): 34  - Ok
    Field : 13 Sub : 164 Byte(s): 34  - Ok
    Field : 13 Sub : 165 Byte(s): 34  - Ok
    Field : 13 Sub : 166 Byte(s): 34  - Ok
    Field : 13 Sub : 167 Byte(s): 34  - Ok
    Field : 13 Sub : 168 Byte(s): 34  - Ok
    Field : 13 Sub : 169 Byte(s): 34  - Ok
    Field : 13 Sub : 170 Byte(s): 34  - Ok
    Field : 13 Sub : 171 Byte(s): 34  - Ok
    Field : 13 Sub : 172 Byte(s): 34  - Ok
    Field : 13 Sub : 173 Byte(s): 34  - Ok
    Field : 13 Sub : 174 Byte(s): 34  - Ok
    Field : 13 Sub : 175 Byte(s): 34  - Ok
    Field : 13 Sub : 176 Byte(s): 34  - Ok
    Field : 13 Sub : 177 Byte(s): 34  - Ok
    Field : 13 Sub : 178 Byte(s): 34  - Ok
    Field : 13 Sub : 179 Byte(s): 34  - Ok
    Field : 13 Sub : 180 Byte(s): 34  - Ok
    Field : 13 Sub : 181 Byte(s): 34  - Ok
    Field : 13 Sub : 182 Byte(s): 34  - Ok
    Field : 13 Sub : 183 Byte(s): 34  - Ok
    Field : 13 Sub : 184 Byte(s): 34  - Ok
    Field : 13 Sub : 185 Byte(s): 34  - Ok
    Field : 13 Sub : 186 Byte(s): 34  - Ok
    Field : 13 Sub : 187 Byte(s): 34  - Ok
    Field : 13 Sub : 188 Byte(s): 34  - Ok
    Field : 13 Sub : 189 Byte(s): 34  - Ok
    Field : 13 Sub : 190 Byte(s): 34  - Ok
    Field : 13 Sub : 191 Byte(s): 34  - Ok
    Field : 13 Sub : 192 Byte(s): 34  - Ok
    Field : 13 Sub : 193 Byte(s): 34  - Ok
    Field : 13 Sub : 194 Byte(s): 34  - Ok
    Field : 13 Sub : 195 Byte(s): 34  - Ok
    Field : 13 Sub : 196 Byte(s): 34  - Ok
    Field : 13 Sub : 197 Byte(s): 34  - Ok
    Field : 13 Sub : 198 Byte(s): 34  - Ok
    Field : 13 Sub : 199 Byte(s): 34  - Ok
    Field : 14 Sub : 0 Byte(s): 37  - Ok
    Field : 14 Sub : 1 Byte(s): 37  - Ok
    Field : 14 Sub : 2 Byte(s): 37  - Ok
    Field : 14 Sub : 3 Byte(s): 37  - Ok
    Field : 14 Sub : 4 Byte(s): 37  - Ok
    Field : 14 Sub : 5 Byte(s): 37  - Ok
    Field : 14 Sub : 6 Byte(s): 37  - Ok
    Field : 14 Sub : 7 Byte(s): 37  - Ok
    Field : 14 Sub : 8 Byte(s): 37  - Ok
    Field : 14 Sub : 9 Byte(s): 37  - Ok
    Field : 14 Sub : 10 Byte(s): 37  - Ok
    Field : 14 Sub : 11 Byte(s): 37  - Ok
    Field : 14 Sub : 12 Byte(s): 37  - Ok
    Field : 14 Sub : 13 Byte(s): 37  - Ok
    Field : 14 Sub : 14 Byte(s): 37  - Ok
    Field : 14 Sub : 15 Byte(s): 37  - Ok
    Field : 14 Sub : 16 Byte(s): 37  - Ok
    Field : 14 Sub : 17 Byte(s): 37  - Ok
    Field : 14 Sub : 18 Byte(s): 37  - Ok
    Field : 14 Sub : 19 Byte(s): 37  - Ok
    Field : 15 Sub : 0 Byte(s): 37  - Ok
    Field : 15 Sub : 1 Byte(s): 37  - Ok
    Field : 15 Sub : 2 Byte(s): 37  - Ok
    Field : 15 Sub : 3 Byte(s): 37  - Ok
    Field : 15 Sub : 4 Byte(s): 37  - Ok
    Field : 15 Sub : 5 Byte(s): 37  - Ok
    Field : 15 Sub : 6 Byte(s): 37  - Ok
    Field : 15 Sub : 7 Byte(s): 37  - Ok
    Field : 15 Sub : 8 Byte(s): 37  - Ok
    Field : 15 Sub : 9 Byte(s): 37  - Ok
    Field : 16 Sub : 0 Byte(s): 37  - Ok
    Field : 16 Sub : 1 Byte(s): 37  - Ok
    Field : 16 Sub : 2 Byte(s): 37  - Ok
    Field : 16 Sub : 3 Byte(s): 37  - Ok
    Field : 16 Sub : 4 Byte(s): 37  - Ok
    Field : 16 Sub : 5 Byte(s): 37  - Ok
    Field : 16 Sub : 6 Byte(s): 37  - Ok
    Field : 16 Sub : 7 Byte(s): 37  - Ok
    Field : 16 Sub : 8 Byte(s): 37  - Ok
    Field : 16 Sub : 9 Byte(s): 37  - Ok
    Field : 17 Sub : 0 Byte(s): 40  - Ok
    Field : 17 Sub : 1 Byte(s): 40  - Ok
    Field : 17 Sub : 2 Byte(s): 40  - Ok
    Field : 18 Sub : 0 Byte(s): 2012  - Ok
    Field : 19 Sub : 0 Byte(s): 15  - Ok
    Field : 22 Sub : 0 Byte(s): 162  - Ok
    Field : 23 Sub : 0 Byte(s): 38  - Ok
    Field : 23 Sub : 1 Byte(s): 21  - Ok
    Field : 23 Sub : 2 Byte(s): 1004  - Ok
    Field : 26 Sub : 0 Byte(s): 302  - Ok
    Field : 26 Sub : 1 Byte(s): 302  - Ok
    Field : 26 Sub : 2 Byte(s): 302  - Ok
    Field : 26 Sub : 3 Byte(s): 302  - Ok
    Field : 26 Sub : 4 Byte(s): 302  - Ok
    Field : 26 Sub : 5 Byte(s): 302  - Ok
    Field : 26 Sub : 6 Byte(s): 302  - Ok
    Field : 26 Sub : 7 Byte(s): 302  - Ok
    Field : 26 Sub : 8 Byte(s): 302  - Ok
    Field : 26 Sub : 9 Byte(s): 302  - Ok
    Field : 26 Sub : 10 Byte(s): 302  - Ok
    Field : 26 Sub : 11 Byte(s): 302  - Ok
    Field : 26 Sub : 12 Byte(s): 302  - Ok
    Field : 26 Sub : 13 Byte(s): 302  - Ok
    Field : 26 Sub : 14 Byte(s): 302  - Ok
    Field : 26 Sub : 15 Byte(s): 302  - Ok
    Field : 26 Sub : 16 Byte(s): 302  - Ok
    Field : 26 Sub : 17 Byte(s): 302  - Ok
    Field : 26 Sub : 18 Byte(s): 302  - Ok
    Field : 26 Sub : 19 Byte(s): 302  - Ok
    Field : 26 Sub : 20 Byte(s): 302  - Ok
    Field : 26 Sub : 21 Byte(s): 302  - Ok
    Field : 26 Sub : 22 Byte(s): 302  - Ok
    Field : 26 Sub : 23 Byte(s): 302  - Ok
    Field : 26 Sub : 24 Byte(s): 302  - Ok
    Field : 26 Sub : 25 Byte(s): 302  - Ok
    Field : 26 Sub : 26 Byte(s): 302  - Ok
    Field : 26 Sub : 27 Byte(s): 302  - Ok
    Field : 26 Sub : 28 Byte(s): 302  - Ok
    Field : 26 Sub : 29 Byte(s): 302  - Ok
    Field : 27 Sub : 0 Byte(s): 142  - Ok
    Field : 27 Sub : 1 Byte(s): 142  - Ok
    Field : 27 Sub : 2 Byte(s): 142  - Ok
    Field : 27 Sub : 3 Byte(s): 142  - Ok
    Field : 27 Sub : 4 Byte(s): 142  - Ok
    Field : 27 Sub : 5 Byte(s): 142  - Ok
    Field : 27 Sub : 6 Byte(s): 142  - Ok
    Field : 27 Sub : 7 Byte(s): 142  - Ok
    Field : 28 Sub : 0 Byte(s): 16  - Ok
    Field : 28 Sub : 1 Byte(s): 16  - Ok
    Field : 28 Sub : 2 Byte(s): 16  - Ok
    Field : 28 Sub : 3 Byte(s): 16  - Ok
    Field : 28 Sub : 4 Byte(s): 16  - Ok
    Field : 28 Sub : 5 Byte(s): 16  - Ok
    Field : 28 Sub : 6 Byte(s): 16  - Ok
    Field : 28 Sub : 7 Byte(s): 16  - Ok
    Field : 29 Sub : 0 Byte(s): 9008  - Ok
    Field : 29 Sub : 1 Byte(s): 9999  - Ok
    Field : 29 Sub : 2 Byte(s): 3344  - Ok
    Field : 29 Sub : 3 Byte(s): 5828  - Ok
    Field : 29 Sub : 4 Byte(s): 2512  - Ok
    Field : 30 Sub : 0 Byte(s): 136  - Ok
    Field : 32 Sub : 0 Byte(s): 10  - Ok
    Field : 32 Sub : 1 Byte(s): 1  - Ok
    Field : 32 Sub : 2 Byte(s): 2  - Ok
    Field : 33 Sub : 0 Byte(s): 4  - Ok
    Field : 33 Sub : 6 Byte(s): 3  - Ok
    Field : 33 Sub : 7 Byte(s): 3  - Ok
    Field : 33 Sub : 8 Byte(s): 3  - Ok
    Field : 33 Sub : 9 Byte(s): 3  - Ok
    Field : 33 Sub : 10 Byte(s): 3  - Ok
    Field : 33 Sub : 11 Byte(s): 3  - Ok
    Field : 33 Sub : 12 Byte(s): 3  - Ok
    Field : 33 Sub : 13 Byte(s): 3  - Ok
    Field : 34 Sub : 0 Byte(s): 8  - Ok
    Field : 34 Sub : 1 Byte(s): 8  - Ok
    Field : 34 Sub : 2 Byte(s): 8  - Ok
    Field : 34 Sub : 3 Byte(s): 8  - Ok
    Field : 34 Sub : 4 Byte(s): 8  - Ok
    Field : 34 Sub : 5 Byte(s): 8  - Ok
    Field : 34 Sub : 6 Byte(s): 1  - Ok
    Field : 34 Sub : 7 Byte(s): 1  - Ok
    Field : 35 Sub : 0 Byte(s): 1  - Ok
    Field : 36 Sub : 0 Byte(s): 32  - Ok
    Field : 36 Sub : 1 Byte(s): 32  - Ok
    Field : 36 Sub : 2 Byte(s): 1  - Ok
    Field : 36 Sub : 3 Byte(s): 1  - Ok
    Field : 36 Sub : 4 Byte(s): 1  - Ok
    Field : 36 Sub : 5 Byte(s): 4  - Ok
    Field : 36 Sub : 6 Byte(s): 4  - Ok
    Field : 36 Sub : 7 Byte(s): 2  - Ok
    Field : 36 Sub : 8 Byte(s): 120  - Ok
    Field : 36 Sub : 9 Byte(s): 1  - Ok
    Field : 36 Sub : 10 Byte(s): 2  - Ok
    Field : 36 Sub : 11 Byte(s): 6  - Ok
    Field : 36 Sub : 12 Byte(s): 17  - Ok
    Field : 36 Sub : 13 Byte(s): 3  - Ok
    Field : 36 Sub : 14 Byte(s): 450  - Ok
    Field : 36 Sub : 15 Byte(s): 37  - Ok
    Field : 36 Sub : 16 Byte(s): 38  - Ok
    Field : 36 Sub : 18 Byte(s): 450  - Ok
    Field : 37 Sub : 0 Byte(s): 1  - Ok
    Field : 37 Sub : 1 Byte(s): 30  - Ok
    Field : 37 Sub : 2 Byte(s): 16  - Ok
    Field : 38 Sub : 0 Byte(s): 13  - Ok
    Field : 38 Sub : 1 Byte(s): 13  - Ok
    Field : 38 Sub : 2 Byte(s): 13  - Ok
    Field : 38 Sub : 3 Byte(s): 13  - Ok
    Field : 38 Sub : 4 Byte(s): 13  - Ok
    Field : 38 Sub : 5 Byte(s): 13  - Ok
    Field : 38 Sub : 6 Byte(s): 40  - Ok
    Field : 38 Sub : 7 Byte(s): 40  - Ok
    Field : 38 Sub : 8 Byte(s): 40  - Ok
    Field : 38 Sub : 9 Byte(s): 40  - Ok
    Field : 38 Sub : 10 Byte(s): 40  - Ok
    Field : 39 Sub : 0 Byte(s): 17  - Ok
    Field : 40 Sub : 0 Byte(s): 4  - Ok
    Field : 40 Sub : 1 Byte(s): 4  - Ok
    Field : 40 Sub : 2 Byte(s): 4  - Ok
    Field : 40 Sub : 3 Byte(s): 4  - Ok
    Field : 40 Sub : 4 Byte(s): 4  - Ok
    Field : 40 Sub : 5 Byte(s): 4  - Ok
    Field : 40 Sub : 6 Byte(s): 4  - Ok
    Field : 40 Sub : 7 Byte(s): 4  - Ok
    Field : 41 Sub : 0 Byte(s): 10  - Ok
    Field : 46 Sub : 0 Byte(s): 1  - Ok
    Field : 46 Sub : 1 Byte(s): 2  - Ok
    Field : 50 Sub : 1 Byte(s): 11  - Ok
    Field : 50 Sub : 2 Byte(s): 1  - Ok
    Field : 50 Sub : 3 Byte(s): 1  - Ok
    Field : 51 Sub : 9 Byte(s): 296  - Ok
    Field : 51 Sub : 10 Byte(s): 87  - Ok
    Field : 51 Sub : 11 Byte(s): 318  - Ok
    Field : 51 Sub : 12 Byte(s): 87  - Ok
    Field : 51 Sub : 13 Byte(s): 1222  - Ok
    Field : 51 Sub : 14 Byte(s): 87  - Ok
    Field : 51 Sub : 15 Byte(s): 868  - Ok
    Field : 51 Sub : 16 Byte(s): 87  - Ok
    Field : 51 Sub : 19 Byte(s): 564  - Ok
    Field : 51 Sub : 20 Byte(s): 87  - Ok
    Field : 51 Sub : 21 Byte(s): 302  - Ok
    Field : 51 Sub : 22 Byte(s): 87  - Ok
    Field : 53 Sub : 1 Byte(s): 314  - Ok
    Field : 53 Sub : 2 Byte(s): 109  - Ok
    Field : 53 Sub : 3 Byte(s): 314  - Ok
    Field : 53 Sub : 4 Byte(s): 109  - Ok
    Field : 54 Sub : 0 Byte(s): 4  - Ok
    Field : 57 Sub : 0 Byte(s): 33  - Ok
    Field : 60 Sub : 0 Byte(s): 7  - Ok
    Field : 61 Sub : 0 Byte(s): 4  - Ok
    Field : 62 Sub : 0 Byte(s): 320  - Ok
    Field : 63 Sub : 0 Byte(s): 4  - Ok
    Field : 66 Sub : 0 Byte(s): 4  - Ok
    Field : 68 Sub : 0 Byte(s): 8  - Ok
    Field : 73 Sub : 0 Byte(s): 111  - Ok
    Field : 73 Sub : 1 Byte(s): 556  - Ok
    Field : 73 Sub : 2 Byte(s): 364  - Ok
    Field : 73 Sub : 3 Byte(s): 548  - Ok
    Field : 74 Sub : 0 Byte(s): 3  - Ok
    Field : 76 Sub : 0 Byte(s): 44  - Ok
    Field : 83 Sub : 0 Byte(s): 5  - Ok
    Field : 120 Sub : 0 Byte(s): 78  - Failed
    Field : 125 Sub : 0 Byte(s): 4  - Failed
    Field : 125 Sub : 1 Byte(s): 32  - Failed
    Field : 125 Sub : 2 Byte(s): 4  - Failed
    Field : 126 Sub : 0 Byte(s): 302  - Failed
    Field : 126 Sub : 1 Byte(s): 302  - Failed
    Field : 126 Sub : 2 Byte(s): 302  - Failed
    Field : 126 Sub : 3 Byte(s): 302  - Failed
    Field : 126 Sub : 4 Byte(s): 302  - Failed
    Field : 126 Sub : 5 Byte(s): 302  - Failed
    Field : 126 Sub : 6 Byte(s): 302  - Failed
    Field : 126 Sub : 7 Byte(s): 302  - Failed
    Field : 126 Sub : 8 Byte(s): 302  - Failed
    Field : 126 Sub : 9 Byte(s): 302  - Failed
    Field : 126 Sub : 10 Byte(s): 302  - Failed
    Field : 126 Sub : 11 Byte(s): 302  - Failed
    Field : 126 Sub : 12 Byte(s): 302  - Failed
    Field : 126 Sub : 13 Byte(s): 302  - Failed
    Field : 126 Sub : 14 Byte(s): 302  - Failed
    Field : 126 Sub : 15 Byte(s): 302  - Failed
    Field : 126 Sub : 16 Byte(s): 302  - Failed
    Field : 126 Sub : 17 Byte(s): 302  - Failed
    Field : 126 Sub : 18 Byte(s): 302  - Failed
    Field : 126 Sub : 19 Byte(s): 302  - Failed
    Field : 126 Sub : 20 Byte(s): 302  - Failed
    Field : 126 Sub : 21 Byte(s): 302  - Failed
    Field : 126 Sub : 22 Byte(s): 302  - Failed
    Field : 126 Sub : 23 Byte(s): 302  - Failed
    Field : 126 Sub : 24 Byte(s): 302  - Failed
    Field : 126 Sub : 25 Byte(s): 302  - Failed
    Field : 126 Sub : 26 Byte(s): 302  - Failed
    Field : 126 Sub : 27 Byte(s): 302  - Failed
    Field : 126 Sub : 28 Byte(s): 302  - Failed
    Field : 126 Sub : 29 Byte(s): 302  - Failed
    Field : 129 Sub : 0 Byte(s): 4  - Failed
    Field : 129 Sub : 1 Byte(s): 32  - Failed
    Field : 129 Sub : 2 Byte(s): 4  - Failed
    Field : 131 Sub : 0 Byte(s): 4  - Failed
    Field : 131 Sub : 6 Byte(s): 3  - Failed
    Field : 131 Sub : 7 Byte(s): 3  - Failed
    Field : 131 Sub : 8 Byte(s): 3  - Failed
    Field : 131 Sub : 9 Byte(s): 3  - Failed
    Field : 131 Sub : 10 Byte(s): 3  - Failed
    Field : 131 Sub : 11 Byte(s): 3  - Failed
    Field : 131 Sub : 12 Byte(s): 3  - Failed
    Field : 131 Sub : 13 Byte(s): 3  - Failed
    Field : 137 Sub : 0 Byte(s): 4  - Ok
    Field : 137 Sub : 1 Byte(s): 32  - Ok
    Field : 137 Sub : 2 Byte(s): 4  - Ok
    Field : 138 Sub : 0 Byte(s): 302  - Ok
    Field : 138 Sub : 1 Byte(s): 302  - Ok
    Field : 138 Sub : 2 Byte(s): 302  - Ok
    Field : 138 Sub : 3 Byte(s): 302  - Ok
    Field : 138 Sub : 4 Byte(s): 302  - Ok
    Field : 138 Sub : 5 Byte(s): 302  - Ok
    Field : 138 Sub : 6 Byte(s): 302  - Ok
    Field : 138 Sub : 7 Byte(s): 302  - Ok
    Field : 138 Sub : 8 Byte(s): 302  - Ok
    Field : 138 Sub : 9 Byte(s): 302  - Ok
    Field : 138 Sub : 10 Byte(s): 302  - Ok
    Field : 138 Sub : 11 Byte(s): 302  - Ok
    Field : 138 Sub : 12 Byte(s): 302  - Ok
    Field : 138 Sub : 13 Byte(s): 302  - Ok
    Field : 138 Sub : 14 Byte(s): 302  - Ok
    Field : 138 Sub : 15 Byte(s): 302  - Ok
    Field : 138 Sub : 16 Byte(s): 302  - Ok
    Field : 138 Sub : 17 Byte(s): 302  - Ok
    Field : 138 Sub : 18 Byte(s): 302  - Ok
    Field : 138 Sub : 19 Byte(s): 302  - Ok
    Field : 138 Sub : 20 Byte(s): 302  - Ok
    Field : 138 Sub : 21 Byte(s): 302  - Ok
    Field : 138 Sub : 22 Byte(s): 302  - Ok
    Field : 138 Sub : 23 Byte(s): 302  - Ok
    Field : 138 Sub : 24 Byte(s): 302  - Ok
    Field : 138 Sub : 25 Byte(s): 302  - Ok
    Field : 138 Sub : 26 Byte(s): 302  - Ok
    Field : 138 Sub : 27 Byte(s): 302  - Ok
    Field : 138 Sub : 28 Byte(s): 302  - Ok
    Field : 138 Sub : 29 Byte(s): 302  - Ok
    Field : 141 Sub : 0 Byte(s): 4  - Failed
    Field : 141 Sub : 1 Byte(s): 32  - Failed
    Field : 141 Sub : 2 Byte(s): 4  - Failed
    Field : 143 Sub : 0 Byte(s): 17  - Failed
    Field : 144 Sub : 0 Byte(s): 4  - Failed
    Field : 144 Sub : 1 Byte(s): 32  - Failed
    Field : 144 Sub : 2 Byte(s): 4  - Failed
    Field : 149 Sub : 0 Byte(s): 4  - Ok
    Field : 149 Sub : 1 Byte(s): 32  - Ok
    Field : 149 Sub : 2 Byte(s): 4  - Ok
    Field : 150 Sub : 0 Byte(s): 302  - Ok
    Field : 150 Sub : 1 Byte(s): 302  - Ok
    Field : 150 Sub : 2 Byte(s): 302  - Ok
    Field : 150 Sub : 3 Byte(s): 302  - Ok
    Field : 150 Sub : 4 Byte(s): 302  - Ok
    Field : 150 Sub : 5 Byte(s): 302  - Ok
    Field : 150 Sub : 6 Byte(s): 302  - Ok
    Field : 150 Sub : 7 Byte(s): 302  - Ok
    Field : 150 Sub : 8 Byte(s): 302  - Ok
    Field : 150 Sub : 9 Byte(s): 302  - Ok
    Field : 150 Sub : 10 Byte(s): 302  - Ok
    Field : 150 Sub : 11 Byte(s): 302  - Ok
    Field : 150 Sub : 12 Byte(s): 302  - Ok
    Field : 150 Sub : 13 Byte(s): 302  - Ok
    Field : 150 Sub : 14 Byte(s): 302  - Ok
    Field : 150 Sub : 15 Byte(s): 302  - Ok
    Field : 150 Sub : 16 Byte(s): 302  - Ok
    Field : 150 Sub : 17 Byte(s): 302  - Ok
    Field : 150 Sub : 18 Byte(s): 302  - Ok
    Field : 150 Sub : 19 Byte(s): 302  - Ok
    Field : 150 Sub : 20 Byte(s): 302  - Ok
    Field : 150 Sub : 21 Byte(s): 302  - Ok
    Field : 150 Sub : 22 Byte(s): 302  - Ok
    Field : 150 Sub : 23 Byte(s): 302  - Ok
    Field : 150 Sub : 24 Byte(s): 302  - Ok
    Field : 150 Sub : 25 Byte(s): 302  - Ok
    Field : 150 Sub : 26 Byte(s): 302  - Ok
    Field : 150 Sub : 27 Byte(s): 302  - Ok
    Field : 150 Sub : 28 Byte(s): 302  - Ok
    Field : 150 Sub : 29 Byte(s): 302  - Ok
    Field : 153 Sub : 0 Byte(s): 4  - Failed
    Field : 153 Sub : 1 Byte(s): 32  - Failed
    Field : 153 Sub : 2 Byte(s): 4  - Failed
    Field : 156 Sub : 0 Byte(s): 4  - Failed
    Field : 156 Sub : 1 Byte(s): 32  - Failed
    Field : 156 Sub : 2 Byte(s): 4  - Failed
    Field : 161 Sub : 0 Byte(s): 4  - Ok
    Field : 161 Sub : 1 Byte(s): 32  - Ok
    Field : 161 Sub : 2 Byte(s): 4  - Ok
    Field : 162 Sub : 0 Byte(s): 302  - Ok
    Field : 162 Sub : 1 Byte(s): 302  - Ok
    Field : 162 Sub : 2 Byte(s): 302  - Ok
    Field : 162 Sub : 3 Byte(s): 302  - Ok
    Field : 162 Sub : 4 Byte(s): 302  - Ok
    Field : 162 Sub : 5 Byte(s): 302  - Ok
    Field : 162 Sub : 6 Byte(s): 302  - Ok
    Field : 162 Sub : 7 Byte(s): 302  - Ok
    Field : 162 Sub : 8 Byte(s): 302  - Ok
    Field : 162 Sub : 9 Byte(s): 302  - Ok
    Field : 162 Sub : 10 Byte(s): 302  - Ok
    Field : 162 Sub : 11 Byte(s): 302  - Ok
    Field : 162 Sub : 12 Byte(s): 302  - Ok
    Field : 162 Sub : 13 Byte(s): 302  - Ok
    Field : 162 Sub : 14 Byte(s): 302  - Ok
    Field : 162 Sub : 15 Byte(s): 302  - Ok
    Field : 162 Sub : 16 Byte(s): 302  - Ok
    Field : 162 Sub : 17 Byte(s): 302  - Ok
    Field : 162 Sub : 18 Byte(s): 302  - Ok
    Field : 162 Sub : 19 Byte(s): 302  - Ok
    Field : 162 Sub : 20 Byte(s): 302  - Ok
    Field : 162 Sub : 21 Byte(s): 302  - Ok
    Field : 162 Sub : 22 Byte(s): 302  - Ok
    Field : 162 Sub : 23 Byte(s): 302  - Ok
    Field : 162 Sub : 24 Byte(s): 302  - Ok
    Field : 162 Sub : 25 Byte(s): 302  - Ok
    Field : 162 Sub : 26 Byte(s): 302  - Ok
    Field : 162 Sub : 27 Byte(s): 302  - Ok
    Field : 162 Sub : 28 Byte(s): 302  - Ok
    Field : 162 Sub : 29 Byte(s): 302  - Ok
    Field : 165 Sub : 0 Byte(s): 4  - Failed
    Field : 165 Sub : 1 Byte(s): 32  - Failed
    Field : 165 Sub : 2 Byte(s): 4  - Failed
    Field : 173 Sub : 0 Byte(s): 4  - Ok
    Field : 173 Sub : 1 Byte(s): 32  - Ok
    Field : 173 Sub : 2 Byte(s): 4  - Ok
    Field : 174 Sub : 0 Byte(s): 302  - Ok
    Field : 174 Sub : 1 Byte(s): 302  - Ok
    Field : 174 Sub : 2 Byte(s): 302  - Ok
    Field : 174 Sub : 3 Byte(s): 302  - Ok
    Field : 174 Sub : 4 Byte(s): 302  - Ok
    Field : 174 Sub : 5 Byte(s): 302  - Ok
    Field : 174 Sub : 6 Byte(s): 302  - Ok
    Field : 174 Sub : 7 Byte(s): 302  - Ok
    Field : 174 Sub : 8 Byte(s): 302  - Ok
    Field : 174 Sub : 9 Byte(s): 302  - Ok
    Field : 174 Sub : 10 Byte(s): 302  - Ok
    Field : 174 Sub : 11 Byte(s): 302  - Ok
    Field : 174 Sub : 12 Byte(s): 302  - Ok
    Field : 174 Sub : 13 Byte(s): 302  - Ok
    Field : 174 Sub : 14 Byte(s): 302  - Ok
    Field : 174 Sub : 15 Byte(s): 302  - Ok
    Field : 174 Sub : 16 Byte(s): 302  - Ok
    Field : 174 Sub : 17 Byte(s): 302  - Ok
    Field : 174 Sub : 18 Byte(s): 302  - Ok
    Field : 174 Sub : 19 Byte(s): 302  - Ok
    Field : 174 Sub : 20 Byte(s): 302  - Ok
    Field : 174 Sub : 21 Byte(s): 302  - Ok
    Field : 174 Sub : 22 Byte(s): 302  - Ok
    Field : 174 Sub : 23 Byte(s): 302  - Ok
    Field : 174 Sub : 24 Byte(s): 302  - Ok
    Field : 174 Sub : 25 Byte(s): 302  - Ok
    Field : 174 Sub : 26 Byte(s): 302  - Ok
    Field : 174 Sub : 27 Byte(s): 302  - Ok
    Field : 174 Sub : 28 Byte(s): 302  - Ok
    Field : 174 Sub : 29 Byte(s): 302  - Ok
    Field : 177 Sub : 0 Byte(s): 4  - Failed
    Field : 177 Sub : 1 Byte(s): 32  - Failed
    Field : 177 Sub : 2 Byte(s): 4  - Failed
    Field : 185 Sub : 0 Byte(s): 4  - Ok
    Field : 185 Sub : 1 Byte(s): 32  - Ok
    Field : 185 Sub : 2 Byte(s): 4  - Ok
    Field : 186 Sub : 0 Byte(s): 302  - Ok
    Field : 186 Sub : 1 Byte(s): 302  - Ok
    Field : 186 Sub : 2 Byte(s): 302  - Ok
    Field : 186 Sub : 3 Byte(s): 302  - Ok
    Field : 186 Sub : 4 Byte(s): 302  - Ok
    Field : 186 Sub : 5 Byte(s): 302  - Ok
    Field : 186 Sub : 6 Byte(s): 302  - Ok
    Field : 186 Sub : 7 Byte(s): 302  - Ok
    Field : 186 Sub : 8 Byte(s): 302  - Ok
    Field : 186 Sub : 9 Byte(s): 302  - Ok
    Field : 186 Sub : 10 Byte(s): 302  - Ok
    Field : 186 Sub : 11 Byte(s): 302  - Ok
    Field : 186 Sub : 12 Byte(s): 302  - Ok
    Field : 186 Sub : 13 Byte(s): 302  - Ok
    Field : 186 Sub : 14 Byte(s): 302  - Ok
    Field : 186 Sub : 15 Byte(s): 302  - Ok
    Field : 186 Sub : 16 Byte(s): 302  - Ok
    Field : 186 Sub : 17 Byte(s): 302  - Ok
    Field : 186 Sub : 18 Byte(s): 302  - Ok
    Field : 186 Sub : 19 Byte(s): 302  - Ok
    Field : 186 Sub : 20 Byte(s): 302  - Ok
    Field : 186 Sub : 21 Byte(s): 302  - Ok
    Field : 186 Sub : 22 Byte(s): 302  - Ok
    Field : 186 Sub : 23 Byte(s): 302  - Ok
    Field : 186 Sub : 24 Byte(s): 302  - Ok
    Field : 186 Sub : 25 Byte(s): 302  - Ok
    Field : 186 Sub : 26 Byte(s): 302  - Ok
    Field : 186 Sub : 27 Byte(s): 302  - Ok
    Field : 186 Sub : 28 Byte(s): 302  - Ok
    Field : 186 Sub : 29 Byte(s): 302  - Ok
    Field : 189 Sub : 0 Byte(s): 4  - Failed
    Field : 189 Sub : 1 Byte(s): 32  - Failed
    Field : 189 Sub : 2 Byte(s): 4  - Failed
    Field : 197 Sub : 0 Byte(s): 4  - Ok
    Field : 197 Sub : 1 Byte(s): 32  - Ok
    Field : 197 Sub : 2 Byte(s): 4  - Ok
    Field : 198 Sub : 0 Byte(s): 302  - Ok
    Field : 198 Sub : 1 Byte(s): 302  - Ok
    Field : 198 Sub : 2 Byte(s): 302  - Ok
    Field : 198 Sub : 3 Byte(s): 302  - Ok
    Field : 198 Sub : 4 Byte(s): 302  - Ok
    Field : 198 Sub : 5 Byte(s): 302  - Ok
    Field : 198 Sub : 6 Byte(s): 302  - Ok
    Field : 198 Sub : 7 Byte(s): 302  - Ok
    Field : 198 Sub : 8 Byte(s): 302  - Ok
    Field : 198 Sub : 9 Byte(s): 302  - Ok
    Field : 198 Sub : 10 Byte(s): 302  - Ok
    Field : 198 Sub : 11 Byte(s): 302  - Ok
    Field : 198 Sub : 12 Byte(s): 302  - Ok
    Field : 198 Sub : 13 Byte(s): 302  - Ok
    Field : 198 Sub : 14 Byte(s): 302  - Ok
    Field : 198 Sub : 15 Byte(s): 302  - Ok
    Field : 198 Sub : 16 Byte(s): 302  - Ok
    Field : 198 Sub : 17 Byte(s): 302  - Ok
    Field : 198 Sub : 18 Byte(s): 302  - Ok
    Field : 198 Sub : 19 Byte(s): 302  - Ok
    Field : 198 Sub : 20 Byte(s): 302  - Ok
    Field : 198 Sub : 21 Byte(s): 302  - Ok
    Field : 198 Sub : 22 Byte(s): 302  - Ok
    Field : 198 Sub : 23 Byte(s): 302  - Ok
    Field : 198 Sub : 24 Byte(s): 302  - Ok
    Field : 198 Sub : 25 Byte(s): 302  - Ok
    Field : 198 Sub : 26 Byte(s): 302  - Ok
    Field : 198 Sub : 27 Byte(s): 302  - Ok
    Field : 198 Sub : 28 Byte(s): 302  - Ok
    Field : 198 Sub : 29 Byte(s): 302  - Ok
    Field : 201 Sub : 0 Byte(s): 4  - Failed
    Field : 201 Sub : 1 Byte(s): 32  - Failed
    Field : 201 Sub : 2 Byte(s): 4  - Failed
    Field : 209 Sub : 0 Byte(s): 4  - Ok
    Field : 209 Sub : 1 Byte(s): 32  - Ok
    Field : 209 Sub : 2 Byte(s): 4  - Ok
    Field : 210 Sub : 0 Byte(s): 302  - Ok
    Field : 210 Sub : 1 Byte(s): 302  - Ok
    Field : 210 Sub : 2 Byte(s): 302  - Ok
    Field : 210 Sub : 3 Byte(s): 302  - Ok
    Field : 210 Sub : 4 Byte(s): 302  - Ok
    Field : 210 Sub : 5 Byte(s): 302  - Ok
    Field : 210 Sub : 6 Byte(s): 302  - Ok
    Field : 210 Sub : 7 Byte(s): 302  - Ok
    Field : 210 Sub : 8 Byte(s): 302  - Ok
    Field : 210 Sub : 9 Byte(s): 302  - Ok
    Field : 210 Sub : 10 Byte(s): 302  - Ok
    Field : 210 Sub : 11 Byte(s): 302  - Ok
    Field : 210 Sub : 12 Byte(s): 302  - Ok
    Field : 210 Sub : 13 Byte(s): 302  - Ok
    Field : 210 Sub : 14 Byte(s): 302  - Ok
    Field : 210 Sub : 15 Byte(s): 302  - Ok
    Field : 210 Sub : 16 Byte(s): 302  - Ok
    Field : 210 Sub : 17 Byte(s): 302  - Ok
    Field : 210 Sub : 18 Byte(s): 302  - Ok
    Field : 210 Sub : 19 Byte(s): 302  - Ok
    Field : 210 Sub : 20 Byte(s): 302  - Ok
    Field : 210 Sub : 21 Byte(s): 302  - Ok
    Field : 210 Sub : 22 Byte(s): 302  - Ok
    Field : 210 Sub : 23 Byte(s): 302  - Ok
    Field : 210 Sub : 24 Byte(s): 302  - Ok
    Field : 210 Sub : 25 Byte(s): 302  - Ok
    Field : 210 Sub : 26 Byte(s): 302  - Ok
    Field : 210 Sub : 27 Byte(s): 302  - Ok
    Field : 210 Sub : 28 Byte(s): 302  - Ok
    Field : 210 Sub : 29 Byte(s): 302  - Ok
    Field : 213 Sub : 0 Byte(s): 4  - Failed
    Field : 213 Sub : 1 Byte(s): 32  - Failed
    Field : 213 Sub : 2 Byte(s): 4  - Failed
    Field : 214 Sub : 0 Byte(s): 120  - Failed
    Field : 214 Sub : 2 Byte(s): 90  - Failed
    Field : 214 Sub : 4 Byte(s): 110  - Failed
    Field : 214 Sub : 5 Byte(s): 2  - Failed
    Field : 214 Sub : 6 Byte(s): 90  - Failed
    Field : 214 Sub : 11 Byte(s): 2  - Failed
    Field : 214 Sub : 12 Byte(s): 2  - Failed
    Field : 216 Sub : 0 Byte(s): 4  - Failed
    Field : 216 Sub : 1 Byte(s): 4  - Failed
    Field : 216 Sub : 2 Byte(s): 4  - Failed
    Field : 216 Sub : 3 Byte(s): 4  - Failed
    Field : 216 Sub : 4 Byte(s): 1  - Failed
    Field : 216 Sub : 5 Byte(s): 6  - Failed
    Field : 216 Sub : 6 Byte(s): 4  - Failed
    Field : 216 Sub : 7 Byte(s): 2  - Failed
    Field : 216 Sub : 8 Byte(s): 1  - Failed
    Field : 216 Sub : 9 Byte(s): 4  - Failed
    Field : 216 Sub : 10 Byte(s): 31  - Failed
    Field : 216 Sub : 11 Byte(s): 2  - Failed
    Field : 216 Sub : 12 Byte(s): 1  - Failed
    Field : 216 Sub : 13 Byte(s): 1  - Failed
    Field : 216 Sub : 14 Byte(s): 1  - Failed
    Field : 216 Sub : 15 Byte(s): 1  - Failed
    Field : 216 Sub : 16 Byte(s): 8  - Failed
    Field : 216 Sub : 17 Byte(s): 1  - Failed
    Field : 216 Sub : 18 Byte(s): 1  - Failed
    Field : 216 Sub : 19 Byte(s): 4  - Failed
    Field : 216 Sub : 20 Byte(s): 2  - Failed
    Field : 216 Sub : 21 Byte(s): 2  - Failed
    Field : 216 Sub : 22 Byte(s): 1  - Failed
    Field : 216 Sub : 23 Byte(s): 8  - Failed
    Field : 216 Sub : 24 Byte(s): 1  - Failed
    Field : 216 Sub : 25 Byte(s): 2  - Failed
    Field : 216 Sub : 26 Byte(s): 2  - Failed
    Field : 216 Sub : 27 Byte(s): 2  - Failed
    Field : 216 Sub : 28 Byte(s): 2  - Failed
    Field : 216 Sub : 29 Byte(s): 2  - Failed
    Field : 216 Sub : 30 Byte(s): 4  - Failed
    Field : 216 Sub : 31 Byte(s): 4  - Failed
    Field : 216 Sub : 32 Byte(s): 4  - Failed
    Field : 216 Sub : 33 Byte(s): 4  - Failed
    Field : 216 Sub : 34 Byte(s): 4  - Failed
    Field : 216 Sub : 35 Byte(s): 4  - Failed
    Field : 216 Sub : 36 Byte(s): 16  - Failed
    Field : 216 Sub : 37 Byte(s): 4  - Failed
    Field : 216 Sub : 38 Byte(s): 2  - Failed
    Field : 216 Sub : 39 Byte(s): 4  - Failed
    Field : 216 Sub : 40 Byte(s): 2  - Failed
    Field : 216 Sub : 41 Byte(s): 2  - Failed
    Field : 216 Sub : 42 Byte(s): 1  - Failed
    Field : 216 Sub : 43 Byte(s): 1  - Failed
    Field : 216 Sub : 44 Byte(s): 4  - Failed
    Field : 216 Sub : 45 Byte(s): 4  - Failed
    Field : 216 Sub : 46 Byte(s): 4  - Failed
    Field : 216 Sub : 47 Byte(s): 4  - Failed
    Field : 216 Sub : 48 Byte(s): 4  - Failed
    Field : 216 Sub : 49 Byte(s): 4  - Failed
    Field : 216 Sub : 50 Byte(s): 4  - Failed
    Field : 216 Sub : 51 Byte(s): 4  - Failed
    Field : 216 Sub : 52 Byte(s): 4  - Failed
    Field : 216 Sub : 53 Byte(s): 4  - Failed
    Field : 216 Sub : 54 Byte(s): 4  - Failed
    Field : 216 Sub : 55 Byte(s): 4  - Failed
    Field : 216 Sub : 56 Byte(s): 4  - Failed
    Field : 216 Sub : 57 Byte(s): 4  - Failed
    Field : 216 Sub : 58 Byte(s): 4  - Failed
    Field : 216 Sub : 59 Byte(s): 4  - Failed
    Field : 216 Sub : 60 Byte(s): 4  - Failed
    Field : 216 Sub : 61 Byte(s): 4  - Failed
    Field : 216 Sub : 62 Byte(s): 4  - Failed
    Field : 216 Sub : 63 Byte(s): 4  - Failed
    Field : 216 Sub : 64 Byte(s): 4  - Failed
    Field : 216 Sub : 65 Byte(s): 4  - Failed
    Field : 216 Sub : 66 Byte(s): 4  - Failed
    Field : 216 Sub : 67 Byte(s): 4  - Failed
    Field : 216 Sub : 68 Byte(s): 4  - Failed
    Field : 216 Sub : 69 Byte(s): 4  - Failed
    Field : 216 Sub : 70 Byte(s): 4  - Failed
    Field : 216 Sub : 71 Byte(s): 4  - Failed
    Field : 216 Sub : 72 Byte(s): 4  - Failed
    Field : 216 Sub : 73 Byte(s): 4  - Failed
    Field : 216 Sub : 74 Byte(s): 4  - Failed
    Field : 216 Sub : 75 Byte(s): 4  - Failed
    Field : 216 Sub : 76 Byte(s): 4  - Failed
    Field : 216 Sub : 77 Byte(s): 4  - Failed
    Field : 216 Sub : 78 Byte(s): 4  - Failed
    Field : 216 Sub : 79 Byte(s): 4  - Failed
    Field : 216 Sub : 80 Byte(s): 4  - Failed
    Field : 216 Sub : 81 Byte(s): 4  - Failed
    Field : 216 Sub : 82 Byte(s): 2  - Failed
    Field : 216 Sub : 83 Byte(s): 4  - Failed
    Field : 216 Sub : 84 Byte(s): 2  - Failed
    Field : 216 Sub : 85 Byte(s): 1  - Failed
    Field : 216 Sub : 86 Byte(s): 16  - Failed
    Field : 216 Sub : 87 Byte(s): 88  - Failed
    Field : 216 Sub : 88 Byte(s): 2  - Failed
    Field : 216 Sub : 89 Byte(s): 4  - Failed
    Field : 216 Sub : 90 Byte(s): 2  - Failed
    Field : 216 Sub : 91 Byte(s): 2  - Failed
    Field : 216 Sub : 92 Byte(s): 2  - Failed
    Field : 216 Sub : 93 Byte(s): 2  - Failed
    Field : 216 Sub : 94 Byte(s): 2  - Failed
    Field : 216 Sub : 95 Byte(s): 2  - Failed
    Field : 216 Sub : 96 Byte(s): 2  - Failed
    Field : 216 Sub : 97 Byte(s): 2  - Failed
    Field : 216 Sub : 98 Byte(s): 2  - Failed
    Field : 216 Sub : 99 Byte(s): 2  - Failed
    Field : 216 Sub : 100 Byte(s): 2  - Failed
    Field : 216 Sub : 101 Byte(s): 2  - Failed
    Field : 216 Sub : 102 Byte(s): 2  - Failed
    Field : 216 Sub : 103 Byte(s): 2  - Failed
    Field : 216 Sub : 104 Byte(s): 2  - Failed
    Field : 216 Sub : 105 Byte(s): 2  - Failed
    Field : 216 Sub : 106 Byte(s): 2  - Failed
    Field : 216 Sub : 107 Byte(s): 2  - Failed
    Field : 216 Sub : 108 Byte(s): 2  - Failed
    Field : 216 Sub : 109 Byte(s): 2  - Failed
    Field : 216 Sub : 110 Byte(s): 2  - Failed
    Field : 216 Sub : 111 Byte(s): 2  - Failed
    Field : 216 Sub : 112 Byte(s): 2  - Failed
    Field : 216 Sub : 113 Byte(s): 2  - Failed
    Field : 216 Sub : 114 Byte(s): 2  - Failed
    Field : 221 Sub : 0 Byte(s): 4  - Ok
    Field : 221 Sub : 1 Byte(s): 32  - Ok
    Field : 221 Sub : 2 Byte(s): 4  - Ok
    Field : 222 Sub : 0 Byte(s): 302  - Ok
    Field : 222 Sub : 1 Byte(s): 302  - Failed
    Field : 222 Sub : 2 Byte(s): 302  - Failed
    Field : 222 Sub : 3 Byte(s): 302  - Failed
    Field : 222 Sub : 4 Byte(s): 302  - Failed
    Field : 222 Sub : 5 Byte(s): 302  - Failed
    Field : 222 Sub : 6 Byte(s): 302  - Failed
    Field : 222 Sub : 7 Byte(s): 302  - Failed
    Field : 222 Sub : 8 Byte(s): 302  - Failed
    Field : 222 Sub : 9 Byte(s): 302  - Failed
    Field : 222 Sub : 10 Byte(s): 302  - Failed
    Field : 222 Sub : 11 Byte(s): 302  - Failed
    Field : 222 Sub : 12 Byte(s): 302  - Failed
    Field : 222 Sub : 13 Byte(s): 302  - Failed
    Field : 222 Sub : 14 Byte(s): 302  - Failed
    Field : 222 Sub : 15 Byte(s): 302  - Failed
    Field : 222 Sub : 16 Byte(s): 302  - Failed
    Field : 222 Sub : 17 Byte(s): 302  - Failed
    Field : 222 Sub : 18 Byte(s): 302  - Failed
    Field : 222 Sub : 19 Byte(s): 302  - Failed
    Field : 222 Sub : 20 Byte(s): 302  - Failed
    Field : 222 Sub : 21 Byte(s): 302  - Failed
    Field : 222 Sub : 22 Byte(s): 302  - Failed
    Field : 222 Sub : 23 Byte(s): 302  - Failed
    Field : 222 Sub : 24 Byte(s): 302  - Failed
    Field : 222 Sub : 25 Byte(s): 302  - Failed
    Field : 222 Sub : 26 Byte(s): 302  - Failed
    Field : 222 Sub : 27 Byte(s): 302  - Failed
    Field : 222 Sub : 28 Byte(s): 302  - Failed
    Field : 222 Sub : 29 Byte(s): 302  - Failed
    Field : 225 Sub : 0 Byte(s): 4  - Failed
    Field : 225 Sub : 1 Byte(s): 32  - Failed
    Field : 225 Sub : 2 Byte(s): 4  - Failed
    Field : 226 Sub : 0 Byte(s): 120  - Failed
    Field : 226 Sub : 2 Byte(s): 90  - Failed
    Field : 226 Sub : 4 Byte(s): 110  - Failed
    Field : 226 Sub : 5 Byte(s): 2  - Failed
    Field : 226 Sub : 6 Byte(s): 90  - Failed
    Field : 226 Sub : 11 Byte(s): 2  - Failed
    Field : 226 Sub : 12 Byte(s): 2  - Failed
    Field : 228 Sub : 0 Byte(s): 1  - Failed
    Field : 228 Sub : 1 Byte(s): 8  - Failed
    Field : 228 Sub : 2 Byte(s): 44  - Failed
    Field : 228 Sub : 3 Byte(s): 10  - Failed
    Field : 228 Sub : 4 Byte(s): 8  - Failed
    Field : 228 Sub : 5 Byte(s): 8  - Failed
    Field : 228 Sub : 6 Byte(s): 8  - Failed
    Field : 228 Sub : 9 Byte(s): 5  - Failed
    Field : 233 Sub : 0 Byte(s): 4  - Ok
    Field : 233 Sub : 1 Byte(s): 32  - Ok
    Field : 233 Sub : 2 Byte(s): 4  - Ok
    Field : 234 Sub : 0 Byte(s): 9008  - Failed
    Field : 234 Sub : 1 Byte(s): 9999  - Failed
    Field : 234 Sub : 2 Byte(s): 3344  - Failed
    Field : 234 Sub : 3 Byte(s): 5828  - Failed
    Field : 234 Sub : 4 Byte(s): 2512  - Failed
    Field : 235 Sub : 0 Byte(s): 2012  - Failed
    Field : 237 Sub : 0 Byte(s): 4  - Failed
    Field : 237 Sub : 1 Byte(s): 32  - Failed
    Field : 237 Sub : 2 Byte(s): 4  - Failed
    Field : 238 Sub : 0 Byte(s): 120  - Failed
    Field : 238 Sub : 2 Byte(s): 90  - Failed
    Field : 238 Sub : 4 Byte(s): 110  - Failed
    Field : 238 Sub : 5 Byte(s): 2  - Failed
    Field : 238 Sub : 6 Byte(s): 90  - Failed
    Field : 238 Sub : 11 Byte(s): 2  - Failed
    Field : 238 Sub : 12 Byte(s): 2  - Failed
    Field : 240 Sub : 0 Byte(s): 4  - Failed
    Field : 240 Sub : 1 Byte(s): 32  - Failed
    Field : 240 Sub : 2 Byte(s): 4  - Failed
    Field : 245 Sub : 0 Byte(s): 4  - Ok
    Field : 245 Sub : 1 Byte(s): 32  - Ok
    Field : 245 Sub : 2 Byte(s): 4  - Ok
    Field : 246 Sub : 0 Byte(s): 9008  - Failed
    Field : 246 Sub : 1 Byte(s): 9999  - Failed
    Field : 246 Sub : 2 Byte(s): 3344  - Failed
    Field : 246 Sub : 3 Byte(s): 5828  - Failed
    Field : 246 Sub : 4 Byte(s): 2512  - Failed
    Field : 247 Sub : 0 Byte(s): 37  - Failed
    Field : 247 Sub : 1 Byte(s): 37  - Failed
    Field : 247 Sub : 2 Byte(s): 37  - Failed
    Field : 247 Sub : 3 Byte(s): 37  - Failed
    Field : 247 Sub : 4 Byte(s): 37  - Failed
    Field : 247 Sub : 5 Byte(s): 37  - Failed
    Field : 247 Sub : 6 Byte(s): 37  - Failed
    Field : 247 Sub : 7 Byte(s): 37  - Failed
    Field : 247 Sub : 8 Byte(s): 37  - Failed
    Field : 247 Sub : 9 Byte(s): 37  - Failed
    Field : 249 Sub : 0 Byte(s): 4  - Failed
    Field : 249 Sub : 1 Byte(s): 32  - Failed
    Field : 249 Sub : 2 Byte(s): 4  - Failed
    Field : 250 Sub : 0 Byte(s): 120  - Failed
    Field : 250 Sub : 2 Byte(s): 90  - Failed
    Field : 250 Sub : 4 Byte(s): 110  - Failed
    Field : 250 Sub : 5 Byte(s): 2  - Failed
    Field : 250 Sub : 6 Byte(s): 90  - Failed
    Field : 250 Sub : 11 Byte(s): 2  - Failed
    Field : 250 Sub : 12 Byte(s): 2  - Failed
    Field : 252 Sub : 0 Byte(s): 4  - Failed
    Field : 252 Sub : 1 Byte(s): 32  - Failed
    Field : 252 Sub : 2 Byte(s): 4  - Failed
    PM  Upload Done!...
     đây là log unlock
    MCU: V 6.93 10-08-07 RH-93 (c) NMP
    IMEI: 357680010358966
    Product Serial Number: KIO745705
    Product Code         : 0533137
    Module Code          : 0203167
    Basic Production Code: 0532665
    PPM SW Version       : V 6.93 10-08-07 RH-93 (c) NMP MD
    ADSP Version         : p V 6.93\n10-08-07\nRH-93\n(c) NMP\nmd
    MCU SW Version       : V 6.93 10-08-07 RH-93 (c) NMP
    HW Version           : 0526
    UEM Version          : 1328
    UPP Version          : 8705
    RFIC Version         : 0500
    DSP Version          : P05w06.v34
    LCD Version          : UNKWN: IDs: 00:ff:00
      ********** SIMLOCK INFO  **********
    CONFIG_DATA  : 0010100000000000
    PROFILE_BITS : 0000000000010002
    ASIC         : 2
    PROVIDER     : Default Test Operator
       Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
    ST_SIMLOCK_TEST       : PASSED
    ST_LCD_TEST     : FAILED
    SECURITY_CODE          : ÿ
    MASTER_CODE             : 2520353555
    PHONE_MODE              : LOCAL
    Generating Simlock Table...
    Uploading Default Simlock Table...
    ERROR: Wrong Simlock Table Data
    ae ai biết cách giải quyết giúp hộ em với . thanks
    Quân đến thì tướng đánh _ Nước mạnh thì đắp đê...!
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    lock này đã unlok đone mà
  3. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    daochikien (07-12-2012)
    Mar 2012
    hai duong
    vậy cái này là bị gì vậy bác ơi ?
    Mar 2012
    nam định
    unlock ko dk thé cái này nó là cái gì
    j
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
  6. ( A & T Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Thành viên kỳ cựu lethanhtam92's Avatar
    https://t.me/pump_upp
    thế máy bây giờ nó bị làm sao thử cho ít thông tin coi sao
  8. ( lethanhtam92 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    Mar 2012
    hai duong
    bây giờ lắp sim vào máy nó lúc nhận sim lúc không , nó không báo là không nhận đăng ký thẻ sim mà nó thay đổi màn hình từ màn hình bình thường sang màn hình lắp thẻ sim liên tục , em đang dùng ATF em cũng chưa biết Format file system là làm như nào , thật ra em vẫn chưa hiểu hết các tính năng của ATF , ae ai biết vào giúp hộ em với . thanks !
  10. #7
    Mar 2012
    hai duong
    để em làm rồi báo lại các bác sau nha
  11. #8
    Thành viên kỳ cựu phamdienmobile's Avatar
    biên hòa - đồng nai
    câu kéo đi bạn ơi ?! 3 cọng dây đồng thui mà !
    KHÔNG CÓ PAN NÀO KHÓ ! CHỈ SỢ KHÔNG " MẠNH TAY" ^_^
    YM!: phamdienmobile phone mình : 0918545113
  12. ( phamdienmobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    daochikien (13-12-2012)
  13. #9
    Mar 2012
    hai duong
    báo cáo các bác em nó bị hỏng ở ic nguồn , em đóng lại ok rồi
  14. #10
    Mar 2012
    hai duong
    ae nào đi qua đóng topic lại hộ em với nha . thanks
  1. 1110i cần giúp
    By sonfa139 in forum DCT4 - WD2
    Bài viết cuối: 24-07-2011, 19:55
  2. 1110i rớt nước xin giúp
    By thanhhp in forum DCT4 - WD2
    Bài viết cuối: 14-09-2010, 08:49
  3. 1110i cần giúp gáp
    By hungmobile_90 in forum DCT4 - WD2
    Bài viết cuối: 31-10-2009, 22:07
  4. 1110i cần giúp đỡ
    By buivanthe in forum DCT4 - WD2
    Bài viết cuối: 03-11-2008, 09:12
  5. UNLOCK YOUR 1112,2310,2610,6030,1110i USING UFS
    By suwaree in forum SƠ ĐỒ & HÌNH ẢNH Soft free dành cho Nokia
    Trả lời: 18
    Bài viết cuối: 24-01-2008, 14:44
