khách mang vào bảo hack phone nen bị tình trạng mơ nguồn lên chữ nokia rồi tắt mh,nhìn kim dòng thì vẫn thấy nhích,e flash lại ver cao nhất mà vẫn vậy,e đã tháo camera ,đóng lại u và plash vẫn khong được.long cua em nó mong ae giúp.
Number of Image Files: 3
Processing Image File :
rm607__06.07.mcusw
rm607__06.07.ppm_a
rm607__06.07_006.image_a_ctv_fi_9g3z5
AUTO SELECTED DEAD USB FLASHING...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Sections : 05
Current File : rm607__06.07.mcusw
Compile Name: rm607__06.07.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 26217904 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 05
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 9899
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 05
FIRMWARE Erase Block: 0x40040000~0x4007FFFE
Start Erasing...
Block Erase Done...
Data Size: 262144 bytes
Data Checksum: 0000
Processing Section 03 of 05
FIRMWARE Erase Block: 0x40080000~0x4009FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 865C
Processing Section 04 of 05
FIRMWARE Erase Block: 0x400A0000~0x4019FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 8B26
Processing Section 05 of 05
FIRMWARE Erase Block: 0x40400000~0x41BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 24641536 bytes
Data Checksum: 8502
Data Verification Successful...
Sections : 01
Current File : rm607__06.07.ppm_a
Compile Name: package_v.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 4261656 Bytes
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x41C00000~0x421FFFFE
Start Erasing...
Block Erase Done...
Data Size: 4258312 bytes
Data Checksum: E976
PPM Data Blocks uploaded to phone...
Sections : 01
Current File : rm607__06.07_006.image_a_ctv_fi_9g3z5
Compile Name: package_a_ctv_fi.image.fls
Image Type : CONTENT Package
Data Size : 12061968 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42200000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Size: 12058624 bytes
Data Checksum: 5B6D
CONTENT Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:07:53
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
WARNING: Phone is not in the Required Mode...
Disconnect the Phone and Power it Up Manually.
Scanning USB Ports...
ERROR: Active Phone Handle was NOT DETECTED
TIP: Make sure that Phone USB Connection Mode is
OVI Suite Mode
or
PC Suite Mode
			 c1-01 flash báo lỗi
 c1-01 flash báo lỗi
