				đèn bàn phím còn sáng không anh?
quang_hhbg
01686381111
Nam Tào_Bắc Đẩu (12-12-2012)
				đây là log info = ATF
MCU: V 07.50 29-11-11 RM-713 (c) Nokia
IMEI: 353279057342423
Product Serial Number: 9DE3083AH
Product Code : 059D8Q7
Module Code : 0204727
Basic Production Code: 059N2M2
PPM SW Version : V 07.50 29-11-11 RM-713 (c) Nokia MR
ADSP Version : p V 07.50\n29-11-11\nRM-713\n(c) NMP\nmr
MCU SW Version : V 07.50 29-11-11 RM-713 (c) Nokia
HW Version : 1002
UEM Version : 1328
UPP Version : 8850
LCD Version : WIN:BARACOAv95 NT39121
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000040002
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST : PASSED
Make sure you have installed the
COMPLETE Flash Package for this Phone...
Goto "Settings" --> "Nokia Settings" and verify that
the Folder where you installed your Flash Files are
in the "PRODUCT PATH TO SCAN" List...
				đây là log FLASH =ATF
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: STMicroelectronics
Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-713\X1-01 RM-713 v07.50 ppm_mr Full\rm713_007.500
FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 03
FIRMWARE Erase Block: 0x00000000~0x0001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 24576 bytes
Data Checksum: 55FD
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 03
FIRMWARE Erase Block: 0x00800000~0x00BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 4128768 bytes
Data Checksum: AA06
Processing Section 03 of 03
FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE
Start Erasing...
Block Erase Done...
Data Size: 1697536 bytes
Data Checksum: C1B9
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-713\X1-01 RM-713 v07.50 ppm_mr Full\rm713_007.50mr
PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x00100000~0x006120BE
Start Erasing...
Block Erase Done...
Data Size: 5316800 bytes
Data Checksum: 93CE
PPM Data Blocks uploaded to phone...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-713\X1-01 RM-713 v07.50 ppm_mr Full\rm7130_nai07.50mr
CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00E60000~0x00F0E53E
Start Erasing...
Block Erase Done...
Data Size: 714048 bytes
Data Checksum: 111B
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:04:21
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
HW Version : 1002
UEM Version : 1328
UPP Version : 8850
ASIC : 11
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
				mình cũng dang gặp 1 em như bạn làm dủ cách rồi mà vẫn ko dược nè ,còn dang kiếm cách,ae có phương án nào up phụ một tay.
				bác kiểm tra hàn lại màn hình đi. e gặp mấy e đứt màn là ko thấy gì đâu bật cũng ko lên
				a cứ thử câu tất cả các đường màn hình đi.thông cũng câu xem thế nào?
quang_hhbg
01686381111
